Hello, I've been using Garuda for maybe a month now, and a problem which has been prevalent from the beginning is that a partition on my secondary drive (/mnt/Storage - /dev/sda2) slowly stops reading over a few hours. I have the partition mounted on boot using the Gnome Disks program, and the partition works fine and is readable at the start, but a few hours later I notice that it no longer reads much data on the disk and only displays some of the folders which were on the drive but clicking them will show only a few files, I'm assuming maybe only previously cached directories and files are shown? Eventually, it stops reading all together and I receive an input/output error number 5 when trying to access through Dolphin.
I've tried unmounting and then mounting again but after unmounting, Gnome Disks just says the partition type is unknown and doesn't let me mount it again. If I try using sudo mount /dev/sda2 /mnt/Storage
I receive the following error: mount: /mnt/Storage: can't read superblock on /dev/sda2.
The partition worked completely fine on Windows as well as a different Arch based distro before I moved to Garuda.
Kernel: 5.15.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a3e426c7-a9dc-4788-8231-e69d5ccee7b3 rw [email protected]
resume=UUID=05d5d275-9d5d-4068-972e-e3a74cc04a7d loglevel=3
Type: Desktop System: LENOVO product: 3227AC4 v: ThinkCentre M92p
Mobo: LENOVO model: MAHOBAY serial: <superuser required> UEFI: LENOVO
v: 9SKT99AUS date: 06/30/2017
Info: model: Intel Core i5-2400 bits: 64 type: MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
desc: 1x6 MiB
Speed (MHz): avg: 2027 high: 2800 min/max: 1600/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2800 2: 1710 3: 1676
4: 1923 bogomips: 24744
Type: itlb_multihit status: KVM: Split huge pages
Type: l1tf
IBRS_FW, STIBP: disabled, RSB filling
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ASUSTeK driver: nvidia
v: 470.94 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:128b
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
Monitor-1: VGA-0 res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e0f
Sound Server-1: ALSA v: k5.15.11-zen1-1-zen running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Local Storage: total: 1.24 TiB used: 834.01 GiB (65.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD110
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A8R0
ID-2: /dev/sdb maj-min: 8:16 vendor: SK Hynix model: HFS120G32TND-N1A2A
size: 111.79 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0P10 scheme: GPT
model: WDS240G2G0A-00JH30 size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 0400
ID-1: / raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
used: 49.05 GiB (47.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
ID-4: /var/log raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
ID-5: /var/tmp raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.69 GiB used: 3.82 GiB (49.7%)
System Temperatures: cpu: 53.0 C mobo: 27.8 C gpu: nvidia temp: 63 C
Processes: 268 Uptime: 11h 4m wakeups: 0 Memory: 7.69 GiB
used: 6.28 GiB (81.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1522 lib: 457 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
