This should be fixed now with garuda-libs 1.4.7-2. fix(pkexec-gui): launch dbus session (!22) · Merge requests · Garuda Linux 🦅 / PKGBUILDs · GitLab
More specifically, the fix is to launch dbus session in the pkexec-gui tool.
#!/bin/bash
# Elevate
if [[ $EUID -ne 0 ]]; then
exec pkexec /usr/lib/garuda/pkexec-gui "$@"
exit 1
fi
+ # Launch dbus session if not already running
+ if [ -z "$DBUS_SESSION_BUS_ADDRESS" ]; then
+ eval $(dbus-launch --sh-syntax --exit-with-session)
+ fi
# Restore some variables from parent process
while IFS= read -rd '' var; do export "$var"; done < <(grep --null-data -ae "^\(XDG_CURRENT_DESKTOP\|WAYLAND_DISPLAY\|XDG_RUNTIME_DIR\|XDG_SESSION_TYPE\|XCURSOR_SIZE\|LC_.*\|LANG\|LANGUAGE\|QT_WAYLAND_FORCE_DPI\|QT_QPA_PLATFORMTHEME\|QT_STYLE_OVERRIDE\|\)=.*\$" /proc/$PPID/environ)
if [[ -v WAYLAND_DISPLAY ]]; then
export WAYLAND_DISPLAY="$XDG_RUNTIME_DIR/$WAYLAND_DISPLAY"
fi
export XDG_RUNTIME_DIR="/run/user/0"
exec "$@"
