Hi team,
Garuda inxi first:
Kernel: 6.9.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=e69eb184-4f60-4c60-a81f-aa5e53e9580b rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.0 tk: Qt v: N/A info: frameworks v: 6.3.0
Mobo: ASUSTeK model: ROG STRIX B650E-F GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 2616 date: 04/29/2024
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 2146 high: 5049 min/max: 545/5050 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 545 2: 4039 3: 545
4: 4039 5: 545 6: 5049 7: 3985 8: 4234 9: 545 10: 4057 11: 545 12: 4028
13: 545 14: 545 15: 545 16: 545 bogomips: 134400
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Sapphire NITRO+ driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1 empty: DP-2, HDMI-A-1, HDMI-A-2, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-3,HDMI-A-3,Writeback-2 bus-ID: 0e:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 44.0 C
gpu: amdgpu,amdgpu display-ID: 0
Monitor-1: DP-1 res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.2-arch1.1
navi31 LLVM 17.0.6 DRM 3.57 6.9.6-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.1.2-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 24.1.2-arch1.1 device-ID: 1002:164e
17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.2-arch1.1 (LLVM 17.0.6)
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 0e:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
API: ALSA v: k6.9.6-zen1-1-zen status: kernel-api with: aoss
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0 chip-ID: 8086:15f3
Local Storage: total: 2.73 TiB used: 259.89 GiB (9.3%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 36.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 39.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 78.88 GiB (4.2%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
used: 78.88 GiB (4.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
ID-1: swap-1 type: zram size: 62.02 GiB used: 9.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 71.8 C mobo: N/A
GPU: device: amdgpu temp: 38.0 C mem: 44.0 C fan: 0 watts: 12.00
device: amdgpu temp: 43.0 C
Memory: total: 64 GiB available: 62.02 GiB used: 4.11 GiB (6.6%)
Processes: 358 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.8 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 1553 libs: 474 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-01-25
Last full system update: 2024-06-23
I am getting this warning in KDE Partition Manager:
Partition ‘/dev/nvme0n1p2’ is not properly aligned (last sector: 3 907 024 064, modulo: 1 217).
╰─λ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
zram0 254:0 0 62G 0 disk [SWAP]
nvme1n1 259:0 0 931,5G 0 disk
└─nvme1n1p1 259:1 0 931,5G 0 part
nvme0n1 259:2 0 1,8T 0 disk
├─nvme0n1p1 259:3 0 300M 0 part /boot/efi
└─nvme0n1p2 259:4 0 1,8T 0 part /home
/var/cache
/root
/var/log
/srv
/var/tmp
I did not find anything on this forum about, only another Arch Linux forum (not sure if I should post the link here). The suggestion was to use Gparted to add 1-2MB to the main partition to align it.
Looking for some input. Is it even a warning to be concerned with? Can I take the 1MB from one of the unalocated spaces? I am not even sure if these are SWAP partitions or something else. Thanks.
