Another issue after update… Some application icons that used to minimize and run in background not showing in the tray like they used to… Also when attempting to expand the tray it does not show expansion menu
Please advise
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
root=UUID=86610dfc-7685-4c6a-95b3-2ae213cf3d58 rw rootflags=subvol=@ quiet
rd.luks.uuid=5318fdb5-0d15-4992-8460-566ef494dc78
rd.luks.uuid=e4abcb24-e541-4f0e-956a-bfa10df8475b
resume=/dev/mapper/luks-e4abcb24-e541-4f0e-956a-bfa10df8475b loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.1.0 wm: kwin_wayland vt: 1
Type: Laptop System: Acer product: Predator PH315-52 v: V1.12 serial: <superuser required>
Chassis: type: 10 serial: <superuser required>
Mobo: CFL model: Covini_CFS v: V1.12 serial: <superuser required> part-nu: 0000000000000000
uuid: <superuser required> UEFI: Insyde v: 1.12 date: 07/28/2020
ID-1: BAT0 charge: 39.2 Wh (100.0%) condition: 39.2/39.2 Wh (100.0%) volts: 16.4 min: 15.4
model: SMP KT00407009 AP18E7M type: Li-ion serial: <filter> status: full
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake gen: core 9 level: v3
note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF6
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3999 high: 4001 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 4000 2: 4000 3: 3998 4: 4001 5: 4000 6: 4000 7: 4000 8: 3995
bogomips: 38400
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Acer Incorporated ALI driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: DP-2,
DP-3, DP-4, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Acer Incorporated ALI driver: nvidia
v: 550.76 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of 2024-04;
EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-7:3 chip-ID: 0408:a061 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6 compositor: kwin_wayland
driver: X: loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: iris
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: iris device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: iris x11:
drv: iris inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.5-arch1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL GT2) device-ID: 8086:3e9b
memory: 30.45 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: integrated-gpu name: Intel UHD Graphics 630
(CFL GT2) driver: mesa intel v: 24.0.5-arch1.1 device-ID: 8086:3e9b surfaces: xcb,xlib,wayland
device: 1 type: discrete-gpu name: NVIDIA GeForce RTX 2060 driver: nvidia v: 550.76
device-ID: 10de:1f11 surfaces: xcb,xlib,wayland device: 2 type: cpu name: llvmpipe (LLVM
17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348
6 High Definition Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse status: active
Device-1: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Acer Incorporated ALI
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 08:00.0
chip-ID: 1969:e0b1 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer driver: iwlwifi v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0029 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter> bt-v: 5.2 lmp-v: 11 status: discoverable: no
pairing: no
Local Storage: total: 3.72 TiB used: 85.86 GiB (2.3%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Fanxiang model: S790 2TB size: 1.82 TiB block-size:
physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: SN13683 temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Asgard model: AN3 1TNVMe-M.2 80 size: 953.87 GiB
fw-rev: 42A7T36A temp: 32.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630 size: 931.51 GiB
fw-rev: A3J0 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Chipsbank model: ChipsBnk Flash size: 58.94 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: SSD serial: <filter> fw-rev: 5.00 scheme: GPT
ID-1: / raw-size: 919.26 GiB size: 919.26 GiB (100.00%) used: 34.99 GiB (3.8%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-5318fdb5-0d15-4992-8460-566ef494dc78
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 728 KiB (0.2%) fs: vfat
dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 919.26 GiB size: 919.26 GiB (100.00%) used: 34.99 GiB (3.8%) fs: btrfs
ID-4: /var/log raw-size: 919.26 GiB size: 919.26 GiB (100.00%) used: 34.99 GiB (3.8%) fs: btrfs
ID-5: /var/tmp raw-size: 919.26 GiB size: 919.26 GiB (100.00%) used: 34.99 GiB (3.8%) fs: btrfs
ID-1: swap-1 type: partition size: 34.3 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
maj-min: 254:1 mapped: luks-e4abcb24-e541-4f0e-956a-bfa10df8475b
ID-2: swap-2 type: zram size: 31.19 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 8 dev: /dev/zram0
System Temperatures: cpu: 51.0 C pch: 54.0 C mobo: N/A
Memory: total: 32 GiB available: 31.19 GiB used: 4.16 GiB (13.4%)
Processes: 306 Power: uptime: 24m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail:
shutdown, reboot, suspend, test_resume image: 12.43 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 255
Packages: pm: pacman pkgs: 2164 libs: 596 tools: octopi,paru Compilers: clang: 17.0.6
gcc: 13.2.1 Client: shell wrapper v: 5.2.26-release inxi: 3.3.34
System install date: 2024-04-21
Last full system update: 2024-04-21 ↻
