I have been using pamac-flatpak
, the GUI for pacman, ever since I moved to Garuda, but recently I am not seeing packages from the AUR, or chaotic-aur
I have tried reinstalling, and switching to pamac-aur
, but nothing seems to help
I also faintly recall there being an “All” section in pamac, but I don’t see that there anymore either
Is anyone else having this issue?
Kernel: 6.8.9-x64v-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod
root=UUID=30342c7e-f5f2-4539-b072-b8c3e5701d39 rw rootflags=subvol=@
Desktop: GNOME v: 46.1 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: 1: GDM v: 46.0 note: stopped 2: SDDM
Type: Desktop Mobo: ASRock model: B550 Phantom Gaming 4/ac
Megatrends LLC. v: P2.20 date: 02/24/2022
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3800 min/max: 2200/4850 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3800 3: 3800
4: 3800 5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800
13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121371
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: Micro-Star MSI
driver: nvidia v: 550.78 alternate: nvidiafb,nouveau,nvidia_drm
non-free: 550.xx+ status: current (as of 2024-04; EOL~2026-12-xx)
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 06:00.0
chip-ID: 10de:2482 class-ID: 0300
Device-2: Microdia Dual Mode Camera (8006 VGA) driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2
chip-ID: 0c45:8006 class-ID: 0301
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.7
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
Screen-1: 0 s-res: 3520x1152 s-dpi: 96 s-size: 931x305mm (36.65x12.01")
s-diag: 980mm (38.57")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,top-left
model: Sceptre K25 built: 2022 res: 1920x1080 dpi: 90 gamma: 1.2
size: 543x302mm (21.38x11.89") diag: 621mm (24.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: bottom-r
model: HP V20 serial: <filter> built: 2021 res: 1600x900 hz: 60 dpi: 94
gamma: 1.2 size: 432x240mm (17.01x9.45") diag: 501mm (19.7") ratio: 16:9
modes: max: 1600x900 min: 640x480
Monitor-3: Unknown-1 mapped: None-1-1 note: disabled size-res: N/A
modes: 1920x1080
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti driver: nvidia v: 550.78 device-ID: 10de:2482
surfaces: xcb,xlib
Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
bus-ID: 06:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.8.9-x64v-xanmod1-1 status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0
IF-ID-1: eth0 state: down mac: <filter>
IF-ID-2: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5.1:6 chip-ID: 0bda:8771
Local Storage: total: 4.55 TiB used: 860.56 GiB (18.5%)
model: WD10EZEX-00BBHA0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 QVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-1: / raw-size: 1.2 TiB size: 1.2 TiB (100.00%) used: 860.53 GiB (70.1%)
fs: btrfs dev: /dev/sdb5 maj-min: 8:21
used: 28.1 MiB (29.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 1.2 TiB size: 1.2 TiB (100.00%)
used: 860.53 GiB (70.1%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21
ID-4: /var/log raw-size: 1.2 TiB size: 1.2 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.2 TiB size: 1.2 TiB (100.00%)
zswap: no
System Temperatures: cpu: 45.1 C mobo: N/A gpu: nvidia temp: 53 C
Memory: total: 32 GiB available: 31.27 GiB used: 5.36 GiB (17.1%)
Processes: 484 Power: uptime: 27m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: gsd-power,
Packages: 1843 pm: pacman pkgs: 1761 libs: 529 tools: octopi,paru
pm: flatpak pkgs: 82 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: gnome-terminal inxi: 3.3.34
System install date: 2024-05-05
Last full system update: 2024-05-16 ↻
