# pamac upgrade
Warning: Building packages as root
Warning: Setting build directory to /var/cache/pamac
Preparing...
Cloning firefox-appmenu build files...
Running as unit: run-u63.service
Finished with result: success
Main processes terminated with: code=exited/status=0
Service runtime: 414ms
CPU time consumed: 0
Running as unit: run-u64.service
Service runtime: 39ms
Checking firefox-appmenu dependencies...
Synchronizing package databases...
cp: cannot stat '/tmp/pamac/dbs/sync/*': No such file or directory
Refreshing community.db...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
firefox-appmenu 89.0.1-1 (85.0-1) AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building firefox-appmenu...
Running as unit: run-u66.service
Press ^] three times within 1s to disconnect TTY.
==> Making package: firefox-appmenu 89.0.1-1 (Tue 22 Jun 2021 02:15:02 PM EDT)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving sources...
-> Found firefox-89.0.1.source.tar.xz
-> Found firefox-89.0.1.source.tar.xz.asc
-> Found 0001-Use-remoting-name-for-GDK-application-names.patch
-> Found firefox.desktop
-> Found unity-menubar.patch
-> Found fix_csd_window_buttons.patch
==> Validating source files with sha256sums...
firefox-89.0.1.source.tar.xz ... Passed
firefox-89.0.1.source.tar.xz.asc ... Skipped
0001-Use-remoting-name-for-GDK-application-names.patch ... Passed
firefox.desktop ... Passed
unity-menubar.patch ... Passed
fix_csd_window_buttons.patch ... Passed
==> Verifying source file signatures with gpg...
firefox-89.0.1.source.tar.xz ... cat: write error: Broken pipe
FAILED
==> ERROR: One or more PGP signatures could not be verified!
Finished with result: exit-code
Main processes terminated with: code=exited/status=1
Service runtime: 5.823s
Error: Failed to build firefox-appmenu
==> Making package: firefox-appmenu 89.0.2-1 (Mon 28 Jun 2021 11:32:30 AM EDT)
-> Downloading firefox-89.0.2.source.tar.xz...
Warning: No home dir, couldn't find known_hosts file! % Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 353M 100 353M 0 0 4025k 0 0:01:30 0:01:30 --:--:-- 5523k
-> Downloading firefox-89.0.2.source.tar.xz.asc...
100 833 100 833 0 0 6474 0 --:--:-- --:--:-- --:--:-- 6507
firefox-89.0.2.source.tar.xz ... Passed
firefox-89.0.2.source.tar.xz.asc ... Skipped
firefox-89.0.2.source.tar.xz ... cat: write error: Broken pipe
FAILED
Service runtime: 1min 33.506s
I mean it's "another issue" as before but still the same topic actually. Opening new topics won't really change the situation, it just clutters the forum.
I would say the matter is not Garuda related so the better idea would be to ask at the AUR page after having done some troubleshooting. (we can't really help with compiling every package taken from the AUR)
This implies you ran out of memory and the compilation process was ended. There is no fix for this other than for you to add more RAM to your system (or use a pre-compiled package).
Perhaps not building the package in /tmp may help. That way he shouldn't run out of space (ram). I used to have to do this on an old computer with limited ram when building Firefox.
Oops, I don't know how this thread popped up on me. Sorry for the necro, closing now.
