Hello,
I'm trying to setup facial recognition for my ASUS ZenBook ux425e. Everything is looking great, but PAM just does not do anything. It's my first time tinkering with PAM and I suspect I'm just to dense. I've read the arch-wiki pages on PAM and configured several files in /etc/pam.d/ like login, sudo, system* but nothing changes at all. How do I know or check if any changes are taking effect?
Here is my /etc/pam.d/login:
#%PAM-1.0
auth sufficient pam_unix.so try_first_pass likeauth nullok
#für Gesichtserkennung
auth required pam_securetty.so
auth requisite pam_nologin.so
auth include system-local-login
account include system-local-login
session include system-local-login
password include system-local-login
auth sufficient pam_python.so /lib/security/howdy/pam.py
Thanks in advance!
xfeldt
As requested by the forum my garuda-inxi:
Kernel: 6.2.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=90037c42-b571-4c45-8b08-1c85d7f7c21e rw rootflags=subvol=@
resume=UUID=dd8c40ac-6ef7-444a-9a79-89fb7aea15e3 loglevel=3 ibt=off
Desktop: i3 v: 4.22 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: ASUSTeK product: ZenBook UX425EA_UX425EA v: 1.0
Mobo: ASUSTeK model: UX425EA v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: UX425EA.317 date: 08/09/2022
ID-1: BAT0 charge: 40.8 Wh (80.0%) condition: 51.0/67.1 Wh (76.0%)
volts: 15.9 min: 15.9 model: ASUSTeK UX425 type: Li-ion serial: <filter>
status: not charging cycles: 413
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
microcode: 0xA6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1454 high: 1500 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 1500 2: 1500 3: 1250
4: 1500 5: 1500 6: 1500 7: 1388 8: 1498 bogomips: 44851
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1, HDMI-A-2,
HDMI-A-3, HDMI-A-4, HDMI-A-5 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 2-6:2 chip-ID: 13d3:56eb class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: Picom v: git-b700a
driver: X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris
Monitor-1: eDP-1 model: AU Optronics 0xa48f built: 2020 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound API: ALSA v: k6.2.6-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
bus-ID: 2-10:3 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 5 state: down
address: <filter>
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 23.69 GiB (5.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 type: SSD serial: <filter> rev: 004C temp: 36.9 C scheme: GPT
ID-1: / raw-size: 229.89 GiB size: 229.89 GiB (100.00%)
used: 23.66 GiB (10.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 25.9 MiB (8.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 229.89 GiB size: 229.89 GiB (100.00%)
ID-4: /var/log raw-size: 229.89 GiB size: 229.89 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.89 GiB size: 229.89 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.86 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.32 GiB used: 181.7 MiB (1.2%)
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 296 Uptime: 2d 2h 16m wakeups: 4421 Memory: 15.32 GiB
used: 3.04 GiB (19.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1351
libs: 373 tools: pamac,paru Shell: Bash v: 5.1.16 running-in: alacritty
inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-01-04
Last full system update: 2023-03-17 ↻
Relevant software: snapper tlp NetworkManager mkinitcpio
