Pacman -Q Timeline
I know I can use pacman -Q to list everything that is installed. I would like to know if there is a way to include the install dates and perhaps sort by the date? I want to do a rollback to see if I can address a Krunner issue I posted about earlier, but with the snapshots that are saved the safest one would be from the 24th of last month (cause it’s the only one left from before the Krunner issue) and I’ve replaced a few programs I normally install with ones I felt better suited my needs. So it would help me greatly to be able to reinstall those apps if I had dates for when I installed them.
~  garuda-inxi         ✔  03:11:13 PM
Kernel: 6.13.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=cb75597d-2efc-4252-81f8-cb85725126aa rw rootflags=subvol=@
Type: Desktop Mobo: Gigabyte model: X670 AORUS ELITE AX v: x.x
Megatrends LLC. v: FB1 date: 05/22/2024
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 4
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3437 min/max: 545/5573 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3437 2: 3437 3: 3437
4: 3437 5: 3437 6: 3437 7: 3437 8: 3437 9: 3437 10: 3437 11: 3437 12: 3437
13: 3437 14: 3437 15: 3437 16: 3437 bogomips: 143732
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Gigabyte
empty: DP-4, DP-5, DP-6, HDMI-A-2, Writeback-1 bus-ID: 17:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 39.0 C
Monitor-1: HDMI-A-1 model: Dell S3221QS serial: <filter> built: 2024 res:
mode: 3840x2160 hz: 60 scale: 150% (1.5) to: 2560x1440 dpi: 139 gamma: 1.2
size: 697x392mm (27.44x15.43") diag: 806mm (31.7") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
drv: nvidia device: 1 drv: radeonsi gbm: drv: radeonsi surfaceless:
drv: nvidia wayland: drv: nvidia x11: drv: nvidia
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 570.86.16
API: Vulkan v: 1.4.303 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: N/A device-ID: 10de:2504
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
Device-2: Creative Labs CA0108/CA10300 [Sound Blaster Audigy Series]
driver: snd_emu10k1 v: kernel bus-ID: 0d:00.0 chip-ID: 1102:0008
class-ID: 0401
Device-3: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
speed: 16 GT/s lanes: 16 bus-ID: 17:00.1 chip-ID: 1002:1640 class-ID: 0403
lanes: 16 bus-ID: 17:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.13.1-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network vendor: AzureWave
port: c000 bus-ID: 0e:00.0 chip-ID: 10ec:c852 class-ID: 0280
IF: wlp14s0 state: up mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: b000 bus-ID: 0f:00.0
IF: enp15s0 state: down mac: <filter>
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:4 chip-ID: 13d3:3586
Local Storage: total: 36.38 TiB used: 20.24 TiB (55.6%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 990 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QKXJ7 temp: 38.9 C
ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR313 temp: 30.9 C
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Crucial model: CT1000T500SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P8CR002 temp: 31.9 C
ID-4: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion HDD
fw-rev: 1801 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Seagate model: Expansion HDD
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 0003 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: Seagate model: Expansion HDD
size: 14.55 TiB block-size: physical: 4096 B logical: 512 B type: USB
ID-1: / raw-size: 465.68 GiB size: 465.68 GiB (100.00%)
used: 37.4 GiB (8.0%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:5
used: 1.7 MiB (0.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 465.68 GiB size: 465.68 GiB (100.00%)
ID-4: /var/log raw-size: 465.68 GiB size: 465.68 GiB (100.00%)
ID-5: /var/tmp raw-size: 465.68 GiB size: 465.68 GiB (100.00%)
ID-1: swap-1 type: zram size: 61.76 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.9 C mobo: 27.0 C gpu: amdgpu temp: 39.0 C
Memory: total: 64 GiB note: est. available: 61.77 GiB used: 9.03 GiB (14.6%)
Processes: 493 Power: uptime: 2h 29m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.64 GiB services: org_kde_powerdevil,
Packages: 2242 pm: pacman pkgs: 2236 libs: 604
tools: octopi,pacseek,paru,pikaur pm: flatpak pkgs: 6 pm: snap pkgs: 0
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: Zsh
v: 5.8 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date:     2025-02-01
Last full system update: 2025-02-04
I just found this and it seems to do the trick.
EDIT:
Wondering if it can be edited to put the latest on top instead of the bottom?
awk '/%NAME%/{getline;PKG=$1} /%INSTALLDATE%/{getline;IDATE=strftime("%Y-%m-%d %H:%M",$1);print IDATE" "PKG}' /var/lib/pacman/local/*/desc|sort
sort --help    # :-D
 -r, --reverse # reverse the result of the sorting
