Packed conflict (xdman-beta-bin (8.0.29-6) breaks dependency ‘xdman’)
:: installing xdman-beta-bin (8.0.29-6) breaks dependency ‘xdman’ required by firedragon-extension-xdm-browser
-monitor
what do i do?
  1. Post youre garuda-inxi, the template ask for.
Hello!
I have the same problem on my machine, here is my garuda-inxi
root=UUID=b92a07d7-f834-45e3-9907-994f29930330 rw rootflags=subvol=@
quiet splash d.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=a8df5364-dfba-4f0d-aee9-ca8276546c76 loglevel=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 3
Type: Desktop Mobo: Micro-Star model: Z370 PC PRO (MS-7B49) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.B3
date: 11/15/2021
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 799 high: 801 min/max: 800/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 801 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 799 12: 799 bogomips: 88796
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: Sapphire PULSE
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,HDMI-A-1 empty: DP-2,HDMI-A-2 bus-ID: 03:00.0
chip-ID: 1002:744c class-ID: 0300
gpu: amdgpu d-rect: 5120x1440 display-ID: 0
Monitor-1: DP-1 pos: right res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: primary,left res: 2560x1440 size: N/A modes: N/A
drv: radeonsi inactive: gbm
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (gfx1100 LLVM
16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:744c memory: 19.53 GiB
unified: no display-ID: :0.0
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XT (RADV GFX1100) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
Device-2: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
Device-3: RODE Microphones RØDE NT-USB Mini
lanes: 1 mode: 1.1 bus-ID: 1-9.2.4:8 chip-ID: 19f7:0015 class-ID: 0300
Server-2: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2
rfk-block: hardware: no software: no address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 6.82 TiB used: 1.96 TiB (28.7%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QJXD7 temp: 31.9 C
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 40.9 C scheme: GPT
model: WD10EZEX-00ZF5A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM006-2DM164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC26 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: MBR
ID-1: / raw-size: 431.17 GiB size: 431.17 GiB (100.00%)
used: 93.31 GiB (21.6%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:5
ID-2: /boot/efi raw-size: 511 MiB size: 510 MiB (99.80%)
used: 108.5 MiB (21.3%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4
ID-3: /home raw-size: 431.17 GiB size: 431.17 GiB (100.00%)
ID-4: /var/log raw-size: 431.17 GiB size: 431.17 GiB (100.00%)
ID-5: /var/tmp raw-size: 431.17 GiB size: 431.17 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.09 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:6
ID-2: swap-2 type: zram size: 31.29 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 34.0 C mobo: N/A gpu: amdgpu temp: 47.0 C
mem: 56.0 C
Processes: 325 Uptime: 12m wakeups: 0 Memory: total: 32 GiB
available: 31.29 GiB used: 4.26 GiB (13.6%) Init: systemd v: 254
Packages: 1882 pm: pacman pkgs: 1876 libs: 507 tools: octopi,pamac,paru
pm: flatpak pkgs: 6 Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.17-1):
System install date:     2023-11-06
Last full system update: 2023-11-06
Is partially upgraded:   Yes
Failed units:            systemd-vconsole-setup.service
Just wait or ask the developer, please.
Can be removed, including xdman. See:
Then you should be good to go.
https://aur.archlinux.org/cgit/aur.git/commit/?h=xdman-beta-bin&id=bccbb41caa2607c1548c922a3164da01fb7d5bf5
This change here broke it. It used to provide xdman and suddenly no more.
firedragon-extension-xdm-browser-monitor removed and problem is gone
curious, i just found an xdman folder in /opt even after removing firedragon-extension-xdm-browser-monitor, and clearing orphans the other day.
i just manually deleted it after creating a snapshot just in case.
edit: just rebooted and no issues to report.
These are usually left behind, /opt/ probably being the place where the application stored its binaries.
well, it’s gone now! lmao
We are now back to having xdman as provides of xdman-beta-bin, so I’m quite sure this won’t be an issue anymore.
https://aur.archlinux.org/cgit/aur.git/commit/?h=xdman-beta-bin&id=b21943507b410043bd2ee2afbecb76cfbd69dfa4
We still need to look into a way of handling the deprecated firedragon-extension-xdm-browser-monitor since it won’t be updated anymore.
thanks for the info.
i used octopi to reinstall xdman-beta-bin and the xdman folder has been returned to /opt, so i’ll leave it be since you folks know what you’re doing with these packages and i most certainly do not lmfao
