Package downgrade 'fix' for: "local is newer than chaotic-aur"
Hey all, there’s been a number of posts on this issue lately, and some in the past, often relating to package server updates. I’ve tried the recommended pacman command fixes but the message that local is newer is still coming through. So I tried my own downgrade fix and in the output at least, the problem is solved. Can I expect any breakage from my approach? You can see it below…
(inxi at end of post)
original message:
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su
warning: kf6-servicemenus-rootactions: local (1.1.0-5) is newer than chaotic-aur (1.1.0-1)
resolving dependencies...
my downgrade fix:
🔴] × sudo pacman -Syy kf6-servicemenus-rootactions
warning: downgrading package kf6-servicemenus-rootactions (1.1.0-5 => 1.1.0-1)
Package (1)                               Old Version  New Version  Net Change  Download Size
chaotic-aur/kf6-servicemenus-rootactions  1.1.0-5      1.1.0-1        0.00 MiB       0.02 MiB
Total Download Size:   0.02 MiB
Total Installed Size:  0.07 MiB
Net Upgrade Size:      0.00 MiB
:: Retrieving packages...
kf6-servicemenus-rootactions-1.1.0-1-any       21.4 KiB  33.7 KiB/s 00:01 [------------------------------------------] 100%
(1/1) checking keys in keyring                                             [------------------------------------------] 100%
(1/1) checking package integrity                                           [------------------------------------------] 100%
(1/1) loading package files                                                [------------------------------------------] 100%
(1/1) checking for file conflicts                                          [------------------------------------------] 100%
(1/1) checking available disk space                                        [------------------------------------------] 100%
==> root: 718
(1/1) downgrading kf6-servicemenus-rootactions                             [------------------------------------------] 100%
(1/6) Arming ConditionNeedsUpdate...
(2/6) Foreign/AUR package notification
=> No foreign/AUR packages found.
(3/6) Orphaned package notification...
gcab 1.6-2
js115 115.16.1-1
libsmbios 2.4.3-7
wpebackend-fdo 1.14.3-1
(4/6) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/locale.gen.pacnew
/etc/pacman.conf.pacnew
/etc/makepkg.conf.d/rust.conf.pacnew
/etc/updatedb.conf.pacsave
Please check and merge
(5/6) Performing snapper post snapshots for the following configurations...
==> root: 719
(6/6) Syncing all file systems...
downgrade fix output: :slight_smile:
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
core downloading...
spawn pacman -Su
there is nothing to do
System updated! 🐧
Press enter to exit
my inxi
Kernel: 6.11.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=b71c31f1-55e9-4354-a076-2d2364f5e63d rw rootflags=subvol=@
nvidia-drm.modeset=1 nvidia.NVreg_EnableGpuFirmware=0 quiet loglevel=3
Desktop: KDE Plasma v: 6.2.2 tk: Qt v: N/A info: frameworks v: 6.7.0
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506QM_TUF506QM
Mobo: ASUSTeK model: FA506QM v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: FA506QM.314
date: 01/07/2023
ID-1: BAT1 charge: 46.8 Wh (61.2%) condition: 76.5/90.2 Wh (84.8%)
volts: 15.5 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: not charging
microcode: 0xA50000C
Speed (MHz): avg: 1600 min/max: 400/4463 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1600 2: 1600 3: 1600
4: 1600 5: 1600 6: 1600 7: 1600 8: 1600 9: 1600 10: 1600 11: 1600 12: 1600
13: 1600 14: 1600 15: 1600 16: 1600 bogomips: 102214
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: DP-1 empty: none bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1
off: eDP-1 empty: none bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300
temp: 47.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 322e:202c
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.3
gpu: nvidia,amdgpu d-rect: 4480x1440 display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: right res: 1920x1080 size: N/A modes: N/A
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.2.5-arch1.1
renoir LLVM 18.1.8 DRM 3.59 6.11.5-zen1-1-zen) device-ID: 1002:1638
API: Vulkan v: 1.3.295 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.5-arch1.1
device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia
v: 560.35.03 device-ID: 10de:2520 surfaces: xcb,xlib,wayland device: 2
v: 24.2.5-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6
API: ALSA v: k6.11.5-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:4 chip-ID: 13d3:3563
Local Storage: total: 3.19 TiB used: 1009.91 GiB (30.9%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung
fw-rev: FXM7201Q temp: 26.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EAVS-00D7B1
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.75 scheme: MBR
ID-1: / raw-size: 70 GiB size: 70 GiB (100.00%) used: 49.79 GiB (71.1%)
fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:3
used: 23.6 MiB (9.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
ID-3: /home raw-size: 70 GiB size: 70 GiB (100.00%)
used: 49.79 GiB (71.1%) fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 70 GiB size: 70 GiB (100.00%)
ID-5: /var/tmp raw-size: 70 GiB size: 70 GiB (100.00%)
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: zram size: 15.03 GiB used: 30.8 MiB (0.2%)
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p2 maj-min: 259:2
System Temperatures: cpu: 59.9 C mobo: 34.0 C gpu: amdgpu temp: 48.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB note: est. available: 15.03 GiB used: 6.82 GiB (45.4%)
Processes: 425 Power: uptime: 41m states: freeze,mem,disk suspend: s2idle
image: 5.93 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: 1528 pm: pacman pkgs: 1496 libs: 464 tools: octopi,paru
pm: flatpak pkgs: 32 Compilers: gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: yakuake inxi: 3.3.36
System install date:     2024-08-27
Last full system update: 2024-10-28 ↻
That’s not an issue, it’s an warning. Like a hint.
It’s not solved.
Sure :smiley: :joy: :rofl:, or just wait and see?
In Germany we say:
Wenn man keine Arbeit hat, macht man sich welche.
Use garuda-update and ignore these warnings. Done.
OK.
The OCD of seeing that error daily and ignoring it… It’s tough. :face_with_peeking_eye: :melting_face: :rofl:
Thanks for your assistance. :slight_smile:
