During a regular update command, got this conflict error:
> update
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su
warning: kf6-servicemenus-rootactions: local (1.1.0-5) is newer than chaotic-aur (1.1.0-1)
resolving dependencies...
:: python-fvs-0.3.4-3 and fvs-0.3.4-2.2 are in conflict. Remove fvs? [y/N] N
n
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Here's my inxi:
Kernel: 6.11.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
root=UUID=8dcc0c9c-8fe9-4fc6-b189-a8db2cfa3823 rw rootflags=subvol=@ rd.driver.pre=vfio-pci
intel_iommu=on quiet resume=UUID=a14a443b-9c6b-47d0-b49a-d9686d767b7c loglevel=3
sysrq_always_enabled=1 ibt=off
Console: pty pts/0 DM: SDDM Distro: Garuda base: Arch Linux
Mobo: ASUSTeK model: PRIME Z690-P WIFI v: Rev 1.xx serial: <superuser required> part-nu: SKU
uuid: <superuser required> UEFI: American Megatrends v: 3001 date: 11/29/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 50% (should be ignored) rechargeable: yes status: N/A
Info: model: 12th Gen Intel Core i9-12900K bits: 64 type: MST AMCP arch: Alder Lake gen: core 12
level: v3 note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151)
stepping: 2 microcode: 0x36
Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2 st: 8 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB L2: 14 MiB
desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 800 min/max: 800/5100:5200:3900 scaling: driver: intel_pstate
governor: performance cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800
10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800
21: 800 22: 800 23: 800 24: 800 bogomips: 152985
Device-1: Intel AlderLake-S GT1 vendor: ASUSTeK driver: i915 v: kernel alternate: xe
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: none
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0300
Device-2: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] vendor: ASUSTeK driver: nvidia
v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of 2024-09;
EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-2,DP-4
empty: DP-3,HDMI-A-3,HDMI-A-4 bus-ID: 01:00.0 chip-ID: 10de:2489 class-ID: 0300
Display: server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4 compositor: kwin_wayland driver:
X: loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: iris
gpu: nvidia,nvidia-nvswitch tty: 160x33
Monitor-1: DP-2 model: Samsung SyncMaster serial: <filter> built: 2009 res: 1920x1080 dpi: 92
gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080
min: 640x480
Monitor-2: DP-4 model: Dell UZ2715H serial: <filter> built: 2014 res: 1920x1080 dpi: 83
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 676mm (26.6") ratio: 16:9 modes: max: 1920x1080
min: 640x480
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia platforms: device: 0 drv: nvidia device: 1
drv: iris device: 3 drv: swrast gbm: drv: iris surfaceless: drv: nvidia wayland: drv: nvidia
inactive: x11,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 24.2.6-arch1.1 note: console (EGL sourced)
renderer: Mesa Intel UHD Graphics 770 (ADL-S GT1), NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2,
llvmpipe (LLVM 18.1.8 256 bits)
API: Vulkan v: 1.3.295 layers: 15 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 3060
Ti driver: nvidia v: 565.57.01 device-ID: 10de:2489 surfaces: wayland device: 1
type: integrated-gpu name: Intel UHD Graphics 770 (ADL-S GT1) driver: mesa intel
v: 24.2.6-arch1.1 device-ID: 8086:4680 surfaces: wayland device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.6-arch1.1 (LLVM 18.1.8)
device-ID: 10005:0000 surfaces: wayland
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: vfio-pci alternate: snd_hda_intel,
snd_soc_avs, snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
API: ALSA v: k6.11.6-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-2: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:7af0 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 06:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF-ID-1: br-b787944b7593 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: br-c22acf9ff387 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-3: br-e04f75c95f55 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-4: br-e9c38ec2b98c state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-5: docker0 state: down mac: <filter>
IF-ID-6: veth2e331b3 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-7: vethb9a59c2 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-8: vethc17ed54 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-9: vethd8f3380 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-10: virbr0 state: down mac: <filter>
IF-ID-11: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-12: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Info: services: NetworkManager, smbd, sshd, systemd-timesyncd, wpa_supplicant
mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0026 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2 lmp-v: 11 status:
bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 6.37 TiB used: 3.38 TiB (53.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO with Heatsink 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD
serial: <filter> fw-rev: 4B2QJXD7 temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB
fw-rev: 5B2QGXA7 temp: 32.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000NE001-2MA101 size: 3.64 TiB
fw-rev: EN01 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 1.12 TiB (62.8%) fs: btrfs
block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 588 KiB (0.2%) fs: vfat
block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 1.12 TiB (62.8%) fs: btrfs
ID-4: /var/log raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 1.12 TiB (62.8%) fs: btrfs
ID-5: /var/tmp raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 1.12 TiB (62.8%) fs: btrfs
ID-1: swap-1 type: zram size: 31.09 GiB used: 7.35 GiB (23.6%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24 dev: /dev/zram0
ID-2: swap-2 type: partition size: 34.2 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 31.0 C mobo: N/A gpu: nvidia temp: 34 C
Memory: total: 32 GiB note: est. available: 31.09 GiB used: 14.34 GiB (46.1%)
Processes: 614 Power: uptime: 3d 21h 32m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.38 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 256
Packages: 2184 pm: pacman pkgs: 2169 libs: 615 tools: octopi,pacseek,paru pm: flatpak pkgs: 15
Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13 Shell: garuda-inxi default: fish v: 3.7.1
running-in: pty pts/0 inxi: 3.3.36
System install date: 2024-10-16
Last full system update: 2024-11-08 ↻
Not sure if I should install the python-fvs over fvs or not, but for now, I’m stuck with unable to system update. Any thoughts?
Thanks in advance!!
