I installed the latest Garuda Mokka , installed lutris (native not flatpak), installed battle.net launcher through lutris , also hearthstone deck tracker through lutris , installed hearthstone through the installed battle.net and finally installed google chrome and brave browser.
the main issue is, whenever i run hearthstone (it runs in full screen). it blocks any overlay to be displayed on top over its window while letting me interacting with the game at the same time. for example, if i run any video run in chrome or brave in PiP mode, the video window can not be displayed on top of the game . if i open the video window and click back on the game window, the video window disappears. same or similar happens with the deck tracker which should have its overlay displayed on top of the game window to help you in game.
What i noticed is, this issue does not happen at all on the GNOME version of garuda. both cases run perfectly on top of the game window.
I run both instances on wayland not x11. Is there any way to fix that?
Thanks in advance
Kernel:
6.16.0-5-cachyos
arch:
x86_64
bits:
64
compiler:
gcc
v:
15.1.1
clocksource:
tsc
avail:
acpi_pm
parameters:
BOOT_IMAGE=/@/boot/vmlinuz-linux-cachyos
root=UUID=43613f38-27bf-4f02-b26e-0f627677e749 rw rootflags=subvol=@
Desktop:
KDE Plasma
v:
6.4.4
tk:
Qt
v:
N/A
info:
frameworks
v:
6.17.0
wm:
kwin_wayland
vt:
2
dm:
SDDM
Distro:
Garuda
base:
Arch Linux
Type:
Laptop
Razer
product:
Blade Pro 17 (Early 2021) - RZ09-0368
v:
6.04
serial:
<superuser required>
Chassis:
type:
10
serial:
Mobo:
Razer
model:
DA760
v:
4
serial:
part-nu:
RZ09-0368AEA2
uuid:
UEFI:
Razer
v:
1.01
date:
01/05/2021
ID-1:
BAT0
charge:
60.4 Wh (94.5%)
condition:
63.9/70.6 Wh (90.5%)
volts:
16.3
min:
15.4
model:
Razer Blade
type:
Unknown
serial:
<filter>
status:
discharging
model:
Intel Core i7-10875H
bits:
64
type:
MT MCP
arch:
Comet Lake
gen:
core 10
level:
v3
note:
check
built:
2020
process:
Intel 14nm
family:
6
model-id:
0xA5 (165)
stepping:
2
microcode:
0x100
Topology:
cpus:
1x
dies:
1
clusters:
8
cores:
8
threads:
16
tpc:
2
smt:
enabled
cache:
L1:
512 KiB
desc:
d-8x32 KiB; i-8x32 KiB
L2:
2 MiB
desc:
8x256 KiB
L3:
16 MiB
desc:
1x16 MiB
Speed (MHz):
avg:
800
min/max:
800/5100
scaling:
driver:
intel_pstate
governor:
powersave
cores:
1:
800
2:
800
3:
800
4:
800
5:
800
6:
800
7:
800
8:
800
9:
800
10:
800
11:
800
12:
800
13:
800
14:
800
15:
800
16:
800
bogomips:
73598
Flags:
avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
<filter>
Device-1:
Intel CometLake-H GT2 [UHD Graphics]
vendor:
Razer USA
driver:
i915
v:
kernel
arch:
Gen-9.5
process:
Intel 14nm
built:
2016-20
ports:
active:
eDP-1
empty:
none
bus-ID:
00:02.0
chip-ID:
8086:9bc4
class-ID:
0300
Device-2:
NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor:
Razer USA
driver:
nvidia
v:
575.64.05
alternate:
nouveau,nvidia_drm
non-free:
550-570.xx+
status:
current (as of 2025-04; EOL~2026-12-xx)
arch:
Ampere
code:
GAxxx
process:
TSMC n7 (7nm)
built:
2020-2023
pcie:
gen:
3
speed:
8 GT/s
lanes:
16
link-max:
gen:
4
speed:
16 GT/s
ports:
active:
none
empty:
DP-1, DP-2, DP-3, HDMI-A-1
bus-ID:
01:00.0
chip-ID:
10de:2520
class-ID:
0300
Device-3:
IMC Networks Integrated Camera
driver:
uvcvideo
type:
USB
rev:
2.0
speed:
480 Mb/s
lanes:
1
mode:
2.0
bus-ID:
1-7:2
chip-ID:
13d3:56d5
class-ID:
0e02
serial:
<filter>
Display:
wayland
server:
``X.org``
v:
1.21.1.18
with:
Xwayland
v:
24.1.8
compositor:
kwin_wayland
driver:
X:
loaded:
modesetting,nvidia
unloaded:
nouveau
alternate:
fbdev,intel,nv,vesa
dri:
iris
gpu:
i915
display-ID:
0
Monitor-1:
eDP-1
model:
BOE Display 0x09d9
built:
2020
res:
mode:
1920x1080
hz:
60
scale:
114% (1.15)
to:
1670x939
dpi:
171
gamma:
1.2
size:
381x214mm (15x8.43")
diag:
437mm (17.2")
ratio:
16:9
modes:
2560x1440
API:
EGL
v:
1.5
hw:
drv:
intel iris
drv:
nvidia
platforms:
device:
0
drv:
nvidia
device:
1
drv:
iris
device:
3
drv:
swrast
gbm:
drv:
iris
surfaceless:
drv:
nvidia
wayland:
drv:
iris
x11:
drv:
iris
inactive:
device-2
API:
OpenGL
v:
4.6.0
compat-v:
4.5
vendor:
intel mesa
v:
25.2.0-cachyos1.1
glx-v:
1.4
direct-render:
yes
renderer:
Mesa Intel UHD Graphics (CML GT2)
device-ID:
8086:9bc4
memory:
15.11 GiB
unified:
yes
display-ID:
:0.0
API:
Vulkan
v:
1.4.321
layers:
8
device:
0
type:
integrated-gpu
name:
Intel
driver:
mesa intel
v:
25.2.0-cachyos1.1
device-ID:
8086:9bc4
surfaces:
N/A
device:
1
type:
discrete-gpu
name:
NVIDIA GeForce RTX 3060 Laptop GPU
driver:
nvidia
v:
575.64.05
device-ID:
10de:2520
surfaces:
N/A
device:
2
type:
cpu
name:
llvmpipe
(LLVM 20.1.8 256 bits)
driver:
mesa llvmpipe
v:
25.2.0-cachyos1.1 (LLVM
20.1.8)
device-ID:
10005:0000
surfaces:
N/A
Tools:
api:
clinfo, eglinfo, glxinfo, vulkaninfo
de:
kscreen-console,kscreen-doctor
gpu:
nvidia-settings,nvidia-smi
wl:
wayland-info
x11:
xdpyinfo, xprop, xrandr
Device-1:
Intel Comet Lake PCH cAVS
vendor:
Razer USA
driver:
snd_hda_intel
v:
kernel
alternate:
snd_soc_avs,snd_sof_pci_intel_cnl
bus-ID:
00:1f.3
chip-ID:
8086:06c8
class-ID:
0403
Device-2:
NVIDIA GA106 High Definition Audio
vendor:
Razer USA
driver:
snd_hda_intel
v:
kernel
pcie:
gen:
3
speed:
8 GT/s
lanes:
16
link-max:
gen:
4
speed:
16 GT/s
bus-ID:
01:00.1
chip-ID:
10de:228e
class-ID:
0403
API:
ALSA
v:
k6.16.0-5-cachyos
status:
kernel-api
tools:
N/A
Server-1:
PipeWire
v:
1.4.7
status:
active
with:
1:
pipewire-pulse
status:
active
2:
wireplumber
status:
active
3:
pipewire-alsa
type:
plugin
4:
pw-jack
type:
plugin
tools:
pactl,pw-cat,pw-cli,wpctl
Device-1:
Realtek RTL8125 2.5GbE
vendor:
Razer USA
driver:
r8169
v:
kernel
pcie:
speed:
Unknown
lanes:
63
link-max:
gen:
2
speed:
5 GT/s
port:
3000
bus-ID:
3d:00.0
chip-ID:
10ec:8125
class-ID:
0200
IF:
enp61s0
state:
down
mac:
<filter>
Device-2:
Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak]
driver:
iwlwifi
v:
kernel
pcie:
gen:
2
speed:
5 GT/s
lanes:
1
bus-ID:
3f:00.0
chip-ID:
8086:2725
class-ID:
0280
IF:
wlp63s0
state:
up
mac:
<filter>
services:
NetworkManager, systemd-timesyncd, wpa_supplicant
Device-1:
Intel AX210 Bluetooth
driver:
btusb
v:
0.8
type:
USB
rev:
2.0
speed:
12 Mb/s
lanes:
1
mode:
1.1
bus-ID:
1-14:4
chip-ID:
8087:0032
class-ID:
e001
Report:
btmgmt
ID:
hci0
rfk-id:
1
state:
down
bt-service:
enabled,running
rfk-block:
hardware:
no
software:
yes
address:
N/A
Local Storage:
total:
1.38 TiB
used:
39.97 GiB (2.8%)
SMART Message:
Unable to run smartctl. Root privileges required.
ID-1:
/dev/nvme0n1
maj-min:
259:0
model:
NVMe CA5-8D512
size:
476.94 GiB
block-size:
physical:
512 B
logical:
512 B
speed:
31.6 Gb/s
lanes:
4
tech:
SSD
serial:
<filter>
fw-rev:
CQ20904
temp:
37.9 C
scheme:
GPT
ID-2:
/dev/nvme1n1
maj-min:
259:1
vendor:
Samsung
model:
SSD 980 1TB
size:
931.51 GiB
block-size:
physical:
512 B
logical:
512 B
speed:
31.6 Gb/s
lanes:
4
tech:
SSD
serial:
<filter>
fw-rev:
1B4QFXO7
temp:
40.9 C
scheme:
GPT
ID-1:
raw-size:
95.98 GiB
size:
95.98 GiB (100.00%)
used:
39.6 GiB (41.3%)
fs:
btrfs
dev:
/dev/nvme0n1p6
maj-min:
259:10
ID-2:
/boot/efi
raw-size:
2.56 GiB
size:
2.55 GiB (99.80%)
used:
378.2 MiB (14.5%)
fs:
vfat
dev:
/dev/nvme0n1p1
maj-min:
259:5
ID-3:
/home
raw-size:
95.98 GiB
size:
95.98 GiB (100.00%)
used:
39.6 GiB (41.3%)
fs:
btrfs
dev:
/dev/nvme0n1p6
maj-min:
259:10
ID-4:
/var/log
raw-size:
95.98 GiB
size:
95.98 GiB (100.00%)
used:
39.6 GiB (41.3%)
fs:
btrfs
dev:
/dev/nvme0n1p6
maj-min:
259:10
ID-5:
/var/tmp
raw-size:
95.98 GiB
size:
95.98 GiB (100.00%)
used:
39.6 GiB (41.3%)
fs:
btrfs
dev:
/dev/nvme0n1p6
maj-min:
259:10
Kernel:
swappiness:
133 (default 60)
cache-pressure:
100 (default)
zswap:
no
ID-1:
swap-1
type:
zram
size:
15.47 GiB
used:
0 KiB (0.0%)
priority:
100
comp:
zstd
avail:
lzo-rle,lzo,lz4,lz4hc,deflate,842
dev:
/dev/zram0
System Temperatures:
cpu:
49.0 C
pch:
53.0 C
mobo:
N/A
Fan Speeds (rpm):
N/A
Memory:
total:
16 GiB
available:
15.47 GiB
used:
3.91 GiB (25.3%)
Processes:
409
Power:
uptime:
8m
states:
freeze,mem,disk
suspend:
deep
avail:
s2idle
wakeups:
0
hibernate:
platform
avail:
shutdown, reboot,
suspend, test_resume
image:
6.09 GiB
services:
org_kde_powerdevil,upowerd
Init:
systemd
v:
257
default:
graphical
tool:
systemctl
Packages:
1397
pm:
pacman
pkgs:
1387
libs:
392
tools:
octopi,paru
pm:
flatpak
pkgs:
10
Compilers:
clang:
20.1.8
gcc:
15.1.1
Shell:
Bash
v:
5.3.3
default:
fish
v:
4.0.2
running-in:
konsole
inxi:
3.3.38
Garuda (2.7.5-1):
System install date:
2025-08-01
Last full system update:
2025-08-09
β»
Is partially upgraded:
No
Relevant software:
snapper tlp NetworkManager dracut nvidia-dkms
Windows dual boot:
Probably (Run as root to verify)
21/22 checks run in 1.43 seconds β
Powered by garuda-health π¦
e
