I can OC my monitor to 75Hz under Xorg with my GTX-1660 using nVidia's drivers and not the open source drivers.
However, when I try to do the same with Wayland, it's not taking effect after I add the following kernel parameter in grub. I have verified the parameter is present in the grub boot menu so it is there:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 nvidia_drm.modeset=1 ibt=off video=DP-1:[email protected]
DP-1 is my display port monitor. I also have an HDMI-A-1 monitor as well that I can OC to 75Hz in Xorg.
However, when I reboot and log in using the Wayland protocol, display settings states that 60Hz is the max I can go to.
Is this a limitation of the nVidia drivers when using the Wayland protocol?
Just curious.
Thanks!
Kernel: 6.1.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=20834898-fd28-4c96-aced-9b0c2862486a rw [email protected]
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_wayland dm: SDDM
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A serial: N/A
Mobo: Gigabyte model: B450M DS3H-CF serial: N/A UEFI: American Megatrends
LLC. v: F63b date: 05/11/2022
Info: model: AMD Ryzen 5 3600 socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3600 min/max: 2200/4208 boost: enabled
base/boost: 3600/4200 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3600 2: 3600 3: 3600 4: 3600
5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600 12: 3600
bogomips: 86235
Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: ASUSTeK driver: nvidia
v: 525.78.01 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
off: DP-1,DVI-D-1,HDMI-A-1 empty: none bus-ID: 06:00.0 chip-ID: 10de:2184
Display: server: X.Org v: 22.1.7 with: Xwayland v: 22.1.7
gpu: nvidia,nvidia-nvswitch display-ID: :1 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x285mm (60.00x11.22")
s-diag: 1550mm (61.04")
Monitor-1: DP-1 mapped: XWAYLAND0 note: disabled pos: left model: HP E223
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 546mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: DVI-D-1 mapped: XWAYLAND1 note: disabled pos: right
model: HP E223 serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 102
gamma: 1.2 size: 480x270mm (18.9x10.63") diag: 546mm (21.5") ratio: 16:9
Monitor-3: HDMI-A-1 mapped: XWAYLAND2 note: disabled pos: primary,center
API: OpenGL v: 4.6.0 NVIDIA 525.78.01 renderer: NVIDIA GeForce GTX
1660/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 1-1:2 pcie: chip-ID: 0d8c:0012
gen: 3 class-ID: 0300 speed: 8 GT/s lanes: 16 bus-ID: 06:00.1
chip-ID: 10de:1aeb class-ID: 0403
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media USB Audio Device type: USB
Sound API: ALSA v: k6.1.7-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Microsoft Xbox 360 Wireless Adapter type: USB driver: usbfs
bus-ID: 1-5:4 chip-ID: 045e:0719 class-ID: ff00 serial: <filter>
Local Storage: total: 7.06 TiB used: 772.74 GiB (10.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk family: Driven OEM SSDs size: 238.47 GiB
block-size: physical: 512 B logical: 512 B sata: 3.2 speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 91.3 temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 17d 13h cycles: 1582
written: 40677 GiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS5C3030ALA630
family: Deskstar 5K3000 size: 2.73 TiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 6.0 Gb/s type: HDD rpm: 5700
serial: <filter> rev: A580 temp: 46 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 8y 338d 18h cycles: 3648
ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HDS723020BLA642
family: Deskstar 7K3000 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: A5C0 temp: 48 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 8y 343d 8h cycles: 3659
Old-Age: UDMA CRC errors: 1365814 alert: Bad cable/connection?
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: HD103SI
family: SpinPoint F2 EG size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1118
temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 8y 264d 6h cycles: 4467
ID-5: /dev/sde maj-min: 8:64 type: USB vendor: JMicron Tech model: N/A
drive vendor: Seagate drive model: ST1000LM010-9YH146 family: FreePlay
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B sata: 3.0
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
drive serial: <filter> rev: 0509 drive rev: CC9F temp: 24 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 109d 8h cycles: 1107
read: 1.43 TiB written: 1.37 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-6: /dev/sdf maj-min: 8:80 type: USB vendor: Toshiba model: MQ01ABF050
family: 2.5" HDD MQ01ABF... size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: AM0B1J temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 4y 136d 18h cycles: 4105
Old-Age: g-sense error rate: 360
ID-1: / raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
used: 24.37 GiB (49.9%) fs: btrfs block-size: 4096 B dev: /dev/sdc3
maj-min: 8:35
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 608 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
used: 554.89 GiB (30.9%) fs: btrfs block-size: 4096 B dev: /dev/sdc4
maj-min: 8:36
ID-4: /var/log raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
maj-min: 8:35
ID-5: /var/tmp raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
maj-min: 8:35
ID-1: swap-1 type: zram size: 15.54 GiB used: 11.8 MiB (0.1%)
System Temperatures: cpu: 45.4 C mobo: 32.0 C
Processes: 360 Uptime: 1h 54m wakeups: 0 Memory: 15.54 GiB
used: 3.52 GiB (22.7%) Init: systemd v: 252 default: graphical
pkgs: 1990 libs: 546 tools: octopi,paru Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-15
Last full system update: 2023-01-20
Windows dual boot: Yes
Failed units: man-db.timer
