To test if any of the Garuda's performance enhancements are causing issues on your system you may want to try disabling/masking some of these services one at a time. The performance tuning packages Garuda has installed by default have changed over time. Depending on how old your install is, you could have a few of the older services not in current usage running on your system. If you suspect any of these services are causing issues on your system you can temporarily disable them via masking to test for improvements.
You can find out if any of these services are installed and running on your system with the following command:
systemctl status prelockd auto-cpufreq ananicy-cpp irqbalance preload memavaild
To stop/disable/mask any individual service that is running on your system, execute:
sudo systemctl disable --now prelockd.service && sudo systemctl mask prelockd.service && sudo systemctl daemon-reload
sudo systemctl disable --now auto-cpufreq.service && sudo systemctl mask auto-cpufreq.service && sudo systemctl daemon-reload
sudo systemctl disable --now ananicy-cpp.service && sudo systemctl mask ananicy-cpp.service && sudo systemctl daemon-reload
sudo systemctl disable --now irqbalance.service && sudo systemctl mask irqbalance.service && sudo systemctl daemon-reload
sudo systemctl disable --now preload.service && sudo systemctl mask preload.service && sudo systemctl daemon-reload
sudo systemctl disable --now memavaild.service && sudo systemctl mask memavaild.service && sudo systemctl daemon-reload
The service's state should be automatically refreshed by the included sudo systemctl daemon-reload command.
After testing the results of your systems performance with a service masked, the service can be easily be made operational again if you wish. To reinitialize any of the service(s) you masked, repeat the above command(s) substituting "unmask" in place of "mask" and "enable" in place of "disable", as in the example below:
sudo systemctl unmask irqbalance.service && sudo systemctl enable --now irqbalance.service && sudo systemctl daemon-reload
In some instances you may need to reboot to fully initialize the service, as reloading may not be sufficient in all cases.
Edited & Updated.
