Heating issue even on idle state, temepratures goes upto 80 plus just while using chrome.
i even tried lts kernel still same. i even replaced thermal paste stll no effect.
i am using power save stuff with auto-cpufreq
Kernel: 6.5.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=85787286-a7db-4c70-b09b-21b7b5f6f0ce rw rootflags=subvol=@
resume=UUID=76115168-354a-4626-8300-e6b54c149796 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0
Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX505DT.316 date: 01/28/2021
ID-1: BAT0 charge: 28.8 Wh (81.4%) condition: 35.4/48.1 Wh (73.7%)
volts: 12.0 min: 11.7 model: FX50442 type: Li-ion serial: N/A
status: not charging
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
stepping: 1 microcode: 0x8108102
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2097 high: 2100 min/max: 1400/2100 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2096 2: 2096
3: 2096 4: 2100 5: 2096 6: 2100 7: 2095 8: 2100 bogomips: 33537
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0300
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
ports: active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 71.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:56a2
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1521 built: 2020
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: radeonsi inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics (raven
LLVM 16.0.6 DRM 3.54 6.5.7-zen1-1-zen) device-ID: 1002:15d8
memory: 500 MiB unified: no
API: Vulkan v: 1.3.264 layers: 10 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:15d8 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 535.113.01
device-ID: 10de:1f91 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
API: ALSA v: k6.5.7-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
IF-ID-1: CloudflareWARP state: unknown speed: 10000 Mbps duplex: full
mac: N/A
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 13d3:3548
status: discoverable: yes pairing: yes
Local Storage: total: 1.38 TiB used: 300.72 GiB (21.4%)
model: 2200V MTFDHBA512TCK size: 476.94 GiB block-size: physical: 512 B
fw-rev: P1MA0V4 temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 046 scheme: GPT
ID-1: / raw-size: 914.65 GiB size: 914.65 GiB (100.00%)
used: 300.72 GiB (32.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 914.65 GiB size: 914.65 GiB (100.00%)
ID-4: /var/log raw-size: 914.65 GiB size: 914.65 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.65 GiB size: 914.65 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.06 GiB used: 237 MiB (1.5%) priority: 100
ID-2: swap-2 type: partition size: 16.57 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 80.4 C mobo: N/A gpu: amdgpu temp: 80.0 C
Fan Speeds (rpm): cpu: 4000
Processes: 328 Uptime: 14m wakeups: 1 Memory: total: 16 GiB note: est.
available: 15.06 GiB used: 4.74 GiB (31.4%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: pm: pacman pkgs: 2439 libs: 615
tools: octopi,pamac,paru pm: flatpak pkgs: 0 Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-08-25
Last full system update: 2023-10-13
