OS wont boot after installation
Hi, I'm Sampath and new to Linux. I wanted to try Linux dual boot with windows 11.
I installed Garuda Linux on a Separate drive, and dual booted with Windows 11. I installed it using proprietary drivers' options. After finishing the installation, and after reboot I see the following message and it doesn't boot after that.
SO, I tried installing with open-source drivers, then my screen becomes orange, and it won't install.
Please help?
I'm new to Linux, and i wanted to shift from windows 11 to Linux soon.
"1.0914743 RAX: crErrercererrida RBX: 00005647d 2a500 RCX: 0000739 e5997rd
1.0944751 RDX: 0000000000000000 RSI: 0000739febed343 RDI: 0000000000000005
1.0341721 ДЕР: 00007739Себе4343 пОВ: 0000000000000000 109: 0000741/93677430
1.0944781 R10: 0000000000000005 11: 0000000000000246 R12: 0000000000020000
1.0941791 R13: 00005647 drZacO R14: 00005647rd 2a500 R15: 000056475d2a6d0
1.0944801 < TASKS
1.0944811 Modules linked in: nuidia(POE*)
1.0944841
-I end trace 0000000000000000 ]-
1.0944851 RIP: 0010:exc_control_protect ion+0xc2/OxdO
1.0944871 Code: fa fF 45 31 c9 49 89 aB 69 09 00 00 00 48 86 93 80 00 00 00 be fa 00 00 00 48 c7 c7 cc 14 89 9a eB 53 10 2c FF e9 64 FF Tr tr Ob 66 66
Ze of 11 B4 00 00 00 00 00 90 66 0 1 00 41 54 55 53
1.094489] RSP: 0018:FFFF9888409a?ae8 EFLAGS: 00010002
1.0941901 RAX: 0000000000000033 RBX: FFF9BB8409a7608 RCX: 0000000000000000
1.0944311 RDX: 0000000000000000 SI: 00000000Frrrarrr RDI: 0000000000000003
1.0944921 ABP: 0000000000000003 ROB: 0000000000000001 09: 00000000f fffffea
1.0944931 B10: FFFFB90e?fecbcAo R11: 0000000000000002 12: 0000000000000000
1.0914941 B13: 0000000000000000 14: 0000000000000000 15: 0000000000000000
1.0941951 PS:
00007 /39 dco7200(0000) GS:Frr890e5faB0000(0000) knIGS:00000
00000000000
1.0944971 CS: 0010 DS: 0000 ES: 0000 CRO: 0000000080050033
1.0944961 CR2: 000078 19/8b5*74 CR3: 0000000101490003 CR4: 0000000000/70cc
1.0944991 PKRU: 55555551
1.0945363 Console: suitching to colour frane buffer device 240x6?"
My understanding is Windows 11 requires secure boot to be enabled, however Garuda Linux requires secure boot to be disabled. You will have to enter the BIOS settings and switch secure boot to disabled in order to continue.
If you have done this and still cannot boot, please enter the live environment (where you install from), connect to the internet, log into the forum, and paste the output of garuda-inxi into the thread.
