zoneid
September 29, 2022, 9:19pm
1
I've been reading the console output from the latest update a little closer, since the kernel update breaks my Garuda install and one of the odd messages i came across is the output of os-prober:
/dev/mapper/luks-6ec60199-2eb3-4b32-835c-0f29f002ab25:Debian GNU/Linux 11 (bullseye):Debian:linux:btrfs:UUID=1733e231-61d3-4c17-89b0-0bdd9f044070:subvol=@
/var/lib/docker/btrfs/subvolumes/5f31022533ec8de3c1be7909bb8baae44049d759e0937919ce44efd7645f2e91
This won't fix my install, but I still wonder how os-prober could be so wrong about the OS on my NVME.
It looks like it's related to a Docker container (not your OS).
zoneid
September 29, 2022, 9:32pm
3
It's the only output os-prober provides, so it has to be Garuda and the UUID also matches the Garuda install, since there is no other OS. I don't have any Debian containers in docker.
SGS
September 29, 2022, 9:50pm
4
Which one, or you mean the grub bug?
All in all, maybe you could be so kind to post garuda-inxi?
sudo os-prober
/dev/nvme0n1p6:Garuda Linux:Garuda:linux:btrfs:UUID=cc8c3427-2bdc-407e-ae93-4105b6795059:subvol=@
zoneid
September 29, 2022, 10:07pm
5
It's a different issue than the grub bug. A while ago a kernel update broke my Garuda install, so I switched from zen to lts and everything was fine again. Then came along the additional grub entry for the recovery mode. So when grub now selected entry nr 3 from the list it wasn't lts anymore, but zen (recovery mode) and the total entries are now 6 and not 4. So zen still doesn't work for me, but at least lts works now that the correct entry is selected in grub.
garuda-inxi:
Kernel: 5.15.71-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=1733e231-61d3-4c17-89b0-0bdd9f044070 rw rootflags=subvol=@
quiet
cryptdevice=UUID=6ec60199-2eb3-4b32-835c-0f29f002ab25:luks-6ec60199-2eb3-4b32-835c-0f29f002ab25
root=/dev/mapper/luks-6ec60199-2eb3-4b32-835c-0f29f002ab25 quiet splash
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Dell product: XPS 15 9510 v: N/A
Mobo: Dell model: 01V4T3 v: A00 serial: <superuser required> UEFI: Dell
v: 1.9.0 date: 03/17/2022
ID-1: BAT0 charge: 72.9 Wh (86.5%) condition: 84.3/84.3 Wh (100.0%)
volts: 12.3 min: 11.4 model: SMP DELL 70N2F95 type: Li-poly
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 built: 2020 process: Intel 10nm
family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x40
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 897 high: 1150 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 919 2: 1123 3: 794
4: 801 5: 801 6: 927 7: 800 8: 778 9: 800 10: 872 11: 1150 12: 818
13: 862 14: 1031 15: 905 16: 986 bogomips: 73728
prctl and seccomp
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:9a60
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: Dell
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max:
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a0 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-11:3 chip-ID: 0c45:672e class-ID: 0e02
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 model: Sharp 0x1515 built: 2021 res: 1920x1200 hz: 60
dpi: 145 gamma: 1.2 size: 336x210mm (13.23x8.27") diag: 396mm (15.6")
ratio: 16:10 modes: 1920x1200
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Dell driver: snd_hda_intel
chip-ID: 8086:43c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.71-1-lts running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
bus-ID: 3-14:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 594.06 GiB (62.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
NVMe WDC 1024GB size: 953.87 GiB block-size: physical: 512 B
rev: 11170012 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 936.68 GiB size: 936.68 GiB (100.00%) used: 594.04 GiB
(63.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-6ec60199-2eb3-4b32-835c-0f29f002ab25
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 18 MiB
(6.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 936.68 GiB size: 936.68 GiB (100.00%) used: 594.04
GiB (63.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 936.68 GiB size: 936.68 GiB (100.00%) used: 594.04
ID-5: /var/tmp raw-size: 936.68 GiB size: 936.68 GiB (100.00%) used: 594.04
ID-1: swap-1 type: zram size: 15.36 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.89 GiB used: 0 KiB (0.0%)
mapped: luks-892c9b70-a1a2-461e-8734-387156579e88
System Temperatures: cpu: 38.0 C mobo: N/A
Processes: 370 Uptime: 9m wakeups: 1866 Memory: 15.36 GiB used: 2.81 GiB
(18.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1446
libs: 361 tools: octopi,pamac,paru pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-05-22
Last full system update: 2022-09-29
OS-prober does not have to provide an output for each bootable entry, or any for that matter. It only offers an entry it is able to detect according to its configuration.
The UUID identifies the disk. If that is the disk where Garuda is installed, it would make sense that software installed on the system (like Docker, or anything else) would share the same UUID.
Are you sure about that?
zoneid:
/var/lib/docker/
Docker containers contain a lot of their own needed infrastructure; you could have installed a Docker container that uses a Debian stack. You honestly would have no idea unless you looked at the guts of whatever you installed.
zoneid
September 29, 2022, 10:27pm
7
Interesting. I was under the impression, that os-prober finds all installed OS, but I was wrong. I have removed all docker images and now the os-prober output is empty.
Thank you, @BluishHumility !
petsam
September 29, 2022, 11:12pm
8
I thought so as well. Weird…
Did grub menu have any new entry for Debian after that, or did you explicitly run os-prober yourself?
I can confirm this is purely a result of Docker. Nothing about it will alter the way grub behaves, all is fine.
zoneid
September 30, 2022, 1:17pm
10
Grub didn't show any Debian entries. Not before and not after I removed all docker images. And yes, I did run os-proper explicitly myself after discovering the the Debian message in the update log as part of "mkinitcpio -P"
system
Closed
October 2, 2022, 1:18pm
11
