Hey, since this morning (i assume since yesterday morning, did a update there) i am unable to change any settings via the gui for the networking, wifi on/off, connect to network, connect to lan etc. everything errors out with "org.freedesktop.NetworkManager.network-control request failed: not authorized", is there anything i could do to gain control again of the network-manager? also i can't connect to the lan of my school because of by default my laptop uses my home network config (dns static) which is not the case for the school network, hence i can only use the internet over usb tethering over my mobile data
edit: this is the message from the gui:
second edit: just looked into the settings manager to look at my account if because of some weird bug the gui root privileges have been revoked, but my account does not show up in the account management section, tho i am able to use sudo like normal:
and the third edit, can't have enough edits now can you:
while i tried mounting a usb stick via the gui i got this error:
An error occurred while accessing 'Ventoy', the system responded: You are not authorized to perform this operation: Not authorized to perform operation (polkit authority not available and caller is not uid 0)
inxi:
Kernel: 5.19.8-hardened2-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 12.2.0 parameters: pti=on page_alloc.shuffle=1
BOOT_IMAGE=/@/boot/vmlinuz-linux-hardened
root=UUID=d16ddc96-5d12-402f-bbcb-9fa585484f0b rw rootflags=subvol=@
cryptdevice=UUID=3c647ba3-56c7-43a5-bafc-5f6213b05312:luks-3c647ba3-56c7-43a5-bafc-5f6213b05312
root=/dev/mapper/luks-3c647ba3-56c7-43a5-bafc-5f6213b05312
Type: Laptop System: LENOVO product: 82C7 v: Lenovo V15-ADA
serial: <superuser required> Chassis: type: 10 v: Lenovo V15-ADA
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
UEFI: LENOVO v: E8CN30WW date: 07/28/2021
ID-1: BAT0 charge: 32.5 Wh (91.8%) condition: 35.4/35.3 Wh (100.1%)
volts: 8.6 min: 7.6 model: CPT-COS L16C2PB1 type: Li-poly serial: <filter>
status: charging cycles: 46
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1594 high: 2332 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2332 2: 2100
3: 1400 4: 1400 5: 1400 6: 1400 7: 1323 8: 1400 bogomips: 33550
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 03:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-1:2 chip-ID: 13d3:5a08 class-ID: 0e02 serial: <filter>
s-diag: 1052mm (41.43")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Idek Iiyama
PL2482H serial: <filter> built: 2013 res: 1920x1080 hz: 60 dpi: 94
gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9
Monitor-2: eDP-1 mapped: eDP pos: primary,left model: BOE Display 0x0812
built: 2018 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.47
5.19.8-hardened2-1-hardened) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Sound Server-1: ALSA v: k5.19.8-hardened2-1-hardened running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280
Device-2: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
bus-ID: 2-3:3 chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp3s0f3u3 state: down mac: <filter>
IF-ID-1: enp3s0f3u4 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Samsung GT-I9070 (network tethering USB debugging enabled)
type: USB driver: rndis_host,usbfs bus-ID: 1-4:10 chip-ID: 04e8:6864
Device-2: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 3-2:3 chip-ID: 0cf3:e300 class-ID: e001
Report: ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter>
Local Storage: total: 700.51 GiB used: 367.61 GiB (52.5%)
model: MZALQ512HALU-000L2 size: 476.94 GiB block-size: physical: 512 B
rev: BL2QFXV7 temp: 23.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
type: SSD serial: <filter> rev: 052
ID-1: / raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 367.61 GiB
(78.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-3c647ba3-56c7-43a5-bafc-5f6213b05312
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 736 KiB
ID-3: /home raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 367.61
GiB (78.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 367.61
ID-5: /var/tmp raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 367.61
ID-1: swap-1 type: zram size: 17.45 GiB used: 0 KiB (0.0%) priority: 100
mapped: luks-48d04c79-6793-4578-a7bd-b7f3baa922dc
System Temperatures: cpu: 41.1 C mobo: N/A gpu: amdgpu temp: 41.0 C
Processes: 280 Uptime: 50m wakeups: 64526 Memory: 17.45 GiB used: 3.62 GiB
(20.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1475
libs: 374 tools: octopi,paru Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.21
e[1;34mGaruda (2.6.7-1):e[0m
e[1;34m System install date:e[0m 2022-06-18
e[1;34m Last full system update:e[0m 2022-09-15
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify)
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m shadow.service
