OrcaSlicer does not start on Plasma 6 Wayland/NVIDIA, even via XWayland
1. Pre-Check Actions
2. Issue Description
Hi everyone,
I’m having trouble running OrcaSlicer on KDE Plasma 6 Wayland with an NVIDIA GPU (OpenGL 4.6, driver 580.76.05).
Symptoms:
  • The application starts, but the UI does not display.
  • The main window does not render, buttons are unresponsive.
  • The log is filled with GTK errors and messages about failing to create GBM buffers:
    Gtk-CRITICAL **: gtk_widget_set_size_request: assertion ‘width >= -1’ failed
    Gtk-CRITICAL **: gtk_window_resize: assertion ‘height > 0’ failed
    Failed to create GBM buffer of size 1200x736: Invalid argument
    Xlib: extension “DRI2” missing on display “:1”.
    Cannot register URI scheme wxfs/memory more than once
What I’ve tried:
  1. AppImage and chaotic build — both fail the same way.
  2. Environment variables for GTK/QT (GDK_BACKEND=wayland/x11, QT_QPA_PLATFORM=xcb) — no effect.
  3. Font check — all required fonts are loaded correctly.
  4. OpenGL check — NVIDIA driver 4.6.0 works fine.
  5. Updating Mesa / libgbm — no effect.
Question:
Has anyone managed to run OrcaSlicer under pure Wayland or XWayland on Plasma 6 + NVIDIA?
3. Technical Details
Kernel: 6.16.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=c499503c-8eaf-4df9-bf10-173a86e99192 rw rootflags=subvol=@
quiet resume=UUID=6963b372-dd42-46ea-8153-276c3d5433ff loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
Type: Desktop Mobo: ASRock model: B550M Pro4 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: P3.40
date: 01/18/2024
Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3586 min/max: 566/4471 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3586 2: 3586 3: 3586
4: 3586 5: 3586 6: 3586 7: 3586 8: 3586 9: 3586 10: 3586 11: 3586 12: 3586
bogomips: 83841
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Gigabyte
driver: nvidia v: 580.76.05 alternate: nouveau,nvidia_drm
gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: none off: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2 bus-ID: 06:00.0
chip-ID: 10de:2504 class-ID: 0300
gpu: nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 0
Monitor-1: HDMI-A-1 pos: primary,left model: ViewSonic VA2261 Series
serial: <filter> built: 2019 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55") diag: 547mm (21.5")
Monitor-2: HDMI-A-2 pos: right model: MSI MAG 275F serial: <filter>
built: 2024 res: mode: 1920x1080 hz: 120 scale: 100% (1) dpi: 81 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.76.05
API: Vulkan v: 1.4.321 layers: 15 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 580.76.05
device-ID: 10de:2504 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.1-arch1.1 (LLVM
de: kscreen-console,kscreen-doctor gpu: corectrl, lact, nvidia-settings,
Device-1: NVIDIA GA106 High Definition Audio vendor: Gigabyte
bus-ID: 06:00.1 chip-ID: 10de:228e class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.16.2-zen1-1-zen status: kernel-api with: aoss
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: ROBOT_UXERROR state: unknown speed: N/A duplex: N/A mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7.1:6 chip-ID: 0bda:8771
Report: btmgmt ID: hci1 rfk-id: 4 state: up address: N/A
Local Storage: total: 2.11 TiB used: 436.37 GiB (20.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 44.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: A-Data model: LEGEND 710
lanes: 4 tech: SSD serial: <filter> fw-rev: VC2SAD01 temp: 31.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-08Z10
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A05 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Kingston model: DataTraveler 3.0
size: 57.75 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: PMAP scheme: GPT
ID-1: / raw-size: 896.83 GiB size: 896.83 GiB (100.00%)
used: 54.84 GiB (6.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 896.83 GiB size: 896.83 GiB (100.00%)
ID-4: /var/log raw-size: 896.83 GiB size: 896.83 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.83 GiB size: 896.83 GiB (100.00%)
System Temperatures: cpu: 45.1 C mobo: N/A
Memory: total: 32 GiB available: 31.26 GiB used: 7.2 GiB (23.0%)
Processes: 404 Power: uptime: 36m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1779 libs: 516 tools: octopi,paru Compilers:
clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.0.2
Garuda (2.8.1-2):
System install date:     2025-08-23
Last full system update: 2025-08-24 ↻
22/23 checks run in 0.72 seconds ⌛
Powered by garuda-health 🦅
--- INFO ---
- Nvidia drivers are installed, but no hardware profile is active (fix available)
P.S. Some warnings from garuda-health are related to the fact that I currently have the proprietary nvidia-dkms package installed. However, this is not the cause of the problem — the issue occurs with both open-source and proprietary drivers.
First reboot then garuda-inxi … :upside_down_face:
How can handle the system this, if the driver isn’t correct installed ?
You need the nvidia-open-dkms driver for your system, think on this.
You work current with a broken system.
Uninstall nvidia-dkms and install nvidia-open-dkms.
I installed nvidia-dkms in an attempt to find a way out of the situation. But the issue is the same — it persists both with nvidia-dkms and with nvidia-open-dkms.
P.S The system itself works perfectly. With nvidia-dkms, it’s actually better and more stable specifically for my setup.
How can your system handling window managing if the driver is not correct installed ?
You work with 2 Monitors.
