Hello.
I install from usb with opensource nvidia drivers but after Garuda Assistant I get info to install closed nvidia drivers. I install that and everything looks OK but optimus manager don't work.
Kernel: 5.17.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=89437e7c-58ad-4fa2-b4f0-904e1853a5cc rw rootflags=subvol=@
resume=UUID=f194a83d-041a-4b69-b5d7-3da2504f9f0c loglevel=3
Desktop: GNOME v: 42.0 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Dell product: Inspiron 7577 v: N/A
Mobo: Dell model: 0WTYKT v: A00 serial: <superuser required>
UEFI-[Legacy]: Dell v: 1.12.1 date: 12/18/2020
ID-1: BAT0 charge: 42.1 Wh (100.0%) condition: 42.1/56.0 Wh (75.1%)
volts: 17.3 min: 15.2 model: Samsung SDI DELL W7NKD7B type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEC
desc: 1x6 MiB
Speed (MHz): avg: 900 min/max: 800/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 bogomips: 19999
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0302
compositor: gnome-shell driver: X: loaded: modesetting,nvidia gpu: i915
display-ID: :1 screens: 1
Monitor-1: eDP-1 model: LG Display 0x053f built: 2016 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 22.0.2
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.17.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 3b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp59s0 state: down mac: <filter>
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3c:00.0 chip-ID: 8086:24fd
IF: wlan0 state: up mac: <filter>
bus-ID: 1-4:3 chip-ID: 8087:0a2b class-ID: e001
address: <filter>
Local Storage: total: 1.03 TiB used: 674.28 GiB (64.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Plextor model: PX-128S3G
type: SSD serial: <filter> rev: 1.03 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LX015-1U7172
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM2
scheme: MBR
ID-1: / raw-size: 104.48 GiB size: 104.48 GiB (100.00%)
used: 14.2 GiB (13.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /home raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 660.08 GiB (72.1%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
ID-3: /var/log raw-size: 104.48 GiB size: 104.48 GiB (100.00%)
ID-4: /var/tmp raw-size: 104.48 GiB size: 104.48 GiB (100.00%)
ID-1: swap-1 type: partition size: 14.75 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda1 maj-min: 8:1
ID-2: swap-2 type: zram size: 15.25 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C pch: 41.0 C mobo: 38.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 240 Uptime: 16m wakeups: 3 Memory: 15.25 GiB
used: 3.36 GiB (22.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1494 lib: 480 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-04-25
Last full system update: 2022-04-26
Is partially upgraded: Yes
Do I need to install GDM-prime in Garuda?
Regards.
