Good night! I’m having a problem installing Opera GX through Wine and I have no idea what may be happening … I’ll leave the error here and a pastebin link too:
0024:fixme:oleacc:AccPropServices_SetHwndPropStr (00010092 4294967292 0 {123fe443-211a-4615-9527-c45a7e93717a} L"76%“)
0024:fixme:oleacc:AccPropServices_SetHwndPropStr (00010092 4294967292 0 {123fe443-211a-4615-9527-c45a7e93717a} L"76%”)
0130:fixme:secur32:schannel_get_cipher_algid unknown algorithm 23
0130:fixme:secur32:schannel_get_mac_algid unknown algorithm 200, cipher 23
0128:fixme:file:ReplaceFileW Ignoring flags 2
01b0:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
01c8:err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
01d0:err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
01d0:fixme:file:NtLockFile I/O completion on lock not implemented yet
01d0:fixme:process:SetProcessShutdownParameters (00000100, 00000001): partial stub.
01c8:fixme:file:NtLockFile I/O completion on lock not implemented yet
[0408/215334.324:INFO:assistant_installer_main.cc(169)] Running assistant instal
ler with command line “C:\users\talgatti\Temp.opera\Opera GX Installer Temp\ope
ra_package_202104082141191\assistant\assistant_installer.exe” --version
01c8:fixme:kernelbase:AppPolicyGetProcessTerminationMethod FFFFFFFA, 0033FEAC
01d0:fixme:kernelbase:AppPolicyGetProcessTerminationMethod FFFFFFFA, 0033FEAC
01fc:err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
0204:err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
0204:fixme:file:NtLockFile I/O completion on lock not implemented yet
0204:fixme:process:SetProcessShutdownParameters (00000100, 00000001): partial stub.
01fc:fixme:file:NtLockFile I/O completion on lock not implemented yet
0058:fixme:mountmgr:harddisk_ioctl Unsupported ioctl 2d0800 (device=2d access=0 func=200 method=0)
01fc:fixme:nls:RtlGetThreadPreferredUILanguages 00000038, 000000000022EE34, 0000000000000000 000000000022EE30
01fc:fixme:nls:get_dummy_preferred_ui_language (0x38 000000000022EE34 0000000000000000 000000000022EE30) returning a dummy value (current locale)
01fc:fixme:nls:RtlGetThreadPreferredUILanguages 00000038, 000000000022EE34, 000000000022EE10 000000000022EE30
01fc:fixme:nls:get_dummy_preferred_ui_language (0x38 000000000022EE34 000000000022EE10 000000000022EE30) returning a dummy value (current locale)
01fc:err:ole:create_server class {8c63d4b8-cf89-4527-b10f-99914b6c207f} not registered
01fc:err:ole:com_get_class_object no class object {8c63d4b8-cf89-4527-b10f-99914b6c207f} could be created for context 0x4
01fc:fixme:advapi:GetNamedSecurityInfoW Object type 12 is not currently supported.
0218:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
[0408/215404.340:ERROR:installer.cc(728)] Installer process did not complete suc
cessfully.
0158:fixme:kernelbase:AppPolicyGetProcessTerminationMethod FFFFFFFA, 0033FEAC
[0408/215404.358:ERROR:installer_controller.cc(303)] Installer error: Unreported
installer error.
0164:fixme:kernelbase:AppPolicyGetProcessTerminationMethod FFFFFFFA, 0033FEAC
0204:fixme:kernelbase:AppPolicyGetProcessTerminationMethod FFFFFFFFFFFFFFFA, 000000000022FD70
Thanks in advance
I downloaded Garuda Xfce and I’m loving it, even though I don’t know how to use it fully yet
