OpenVPN running from shell - push DNS
Tried to use openvpn at the shell but I have difficulties with the DNS registration.
As far as I can see the problem is at the end that garuda users openresolv and it look like for that there’s no more working script to update as stated here:
Anyone using it and also using propagated dns?
Kernel: 6.14.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=b2f43419-f3d6-4282-9f1e-96741c127cb6 rw rootflags=subvol=@
quiet rd.luks.uuid=717e1213-09d9-453c-b90d-dd74575a899d
rd.luks.uuid=76aea1b9-ed95-48ea-94b3-7586ccbbb067
resume=/dev/mapper/luks-76aea1b9-ed95-48ea-94b3-7586ccbbb067 loglevel=3
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A wm: kwin_wayland with: krunner
Type: Laptop System: TUXEDO product: TUXEDO InfinityBook Pro AMD Gen9
v: Standard serial: <filter>
Mobo: NB02 model: GXxHRXx v: Standard serial: <filter> part-nu: IBP14A09MK1
/ IBP15A09MK1 uuid: 4732dd80-aaf5-11ef-b7ea-c01e4a0a1b00 UEFI: American
Megatrends LLC. v: N.1.14A13 date: 03/06/2025
ID-1: BAT0 charge: 80.1 Wh (100.0%) condition: 80.1/80.1 Wh (100.0%)
volts: 16.6 min: 15.4 model: standard type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_2 model: Logitech Wireless Mouse MX Master 3
Info: model: AMD Ryzen 7 8845HS w/ Radeon 780M Graphics socket: FP8 bits: 64
process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x75 (117) stepping: 2
microcode: 0xA705206
Speed (MHz): avg: 1357 min/max: 400/5102 boost: enabled
base/boost: 3800/5100 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1357 2: 1357 3: 1357 4: 1357
5: 1357 6: 1357 7: 1357 8: 1357 9: 1357 10: 1357 11: 1357 12: 1357
13: 1357 14: 1357 15: 1357 16: 1357 bogomips: 121369
Device-1: Advanced Micro Devices [AMD/ATI] Phoenix3 vendor: AIstone Global
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,eDP-1 empty: DP-2, DP-3, DP-4, DP-5, DP-6, HDMI-A-1,
Writeback-1 bus-ID: 66:00.0 chip-ID: 1002:1900 class-ID: 0300 temp: 41.0 C
Device-2: Kingcome FHD WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 2b7e:c858
Device-3: USB C Video Adaptor driver: N/A type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1.3:3 chip-ID: 25a4:9321
class-ID: 1100 serial: <filter>
Display: unspecified server: X.Org v: 24.1.6 with: Xwayland v: 24.1.6
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 5760x1876 s-dpi: 96 s-size: 1524x496mm (60.00x19.53")
s-diag: 1603mm (63.1")
Monitor-1: DP-1 pos: bottom-l model: BenQ G2410HD serial: <filter>
built: 2009 res: mode: 2880x1620 hz: 60 scale: 100% (1) dpi: 153 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 595mm (23.4") ratio: 16:9 modes:
Monitor-2: eDP-1 pos: primary,top-right model: MNE007ZA3-2 built: 2023
res: mode: 2880x1800 hz: 60 scale: 100% (1) dpi: 243 gamma: 1.2
size: 301x188mm (11.85x7.4") diag: 355mm (14") ratio: 16:10 modes:
max: 2880x1800 min: 640x480
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.3-arch1.3
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M Graphics (radeonsi
phoenix LLVM 20.1.6 DRM 3.61 6.14.9-zen1-1-zen) device-ID: 1002:1900
memory: 500 MiB unified: no
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: integrated-gpu name: AMD
Radeon 780M Graphics (RADV PHOENIX) driver: mesa radv v: 25.1.3-arch1.3
device-ID: 1002:1900 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.6 256 bits) driver: mesa llvmpipe v: 25.1.3-arch1.3 (LLVM
[Rembrandt/Strix] vendor: AIstone Global driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 66:00.1 chip-ID: 1002:1640
vendor: AIstone Global driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 66:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: AIstone Global driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 66:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.14.9-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.5 status: n/a (root, process) with:
Device-1: Motorcomm Micro. YT6801 Gigabit Ethernet vendor: AIstone Global
driver: yt6801 v: 1.0.29 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 02:00.0 chip-ID: 1f0a:6801 class-ID: 0200
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0
Device-3: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-1.1:3 chip-ID: 0b95:1790
IF: eth0 state: down mac: <filter>
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0032
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: N/A
Local Storage: total: 4.09 TiB used: 1.18 TiB (28.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT4000P3SSD8
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 34.9 C
SMART: yes health: PASSED on: 41d 22h cycles: 6,560
read-units: 30,418,189 [15.5 TB] written-units: 43,974,360 [22.5 TB]
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 980 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B4QFXO7 temp: 35.9 C
SMART: yes health: PASSED on: 17 hrs cycles: 5,941
read-units: 975,381 [499 GB] written-units: 906,408 [464 GB]
ID-1: / raw-size: 364.14 GiB size: 364.14 GiB (100.00%)
used: 39.9 GiB (11.0%) fs: btrfs block-size: 4096 B dev: /dev/dm-1
maj-min: 253:1 mapped: luks-717e1213-09d9-453c-b90d-dd74575a899d
used: 780 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:6
ID-3: /home raw-size: 364.14 GiB size: 364.14 GiB (100.00%)
ID-4: /var/log raw-size: 364.14 GiB size: 364.14 GiB (100.00%)
ID-5: /var/tmp raw-size: 364.14 GiB size: 364.14 GiB (100.00%)
ID-1: swap-1 type: partition size: 101.32 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-0 maj-min: 253:0
mapped: luks-76aea1b9-ed95-48ea-94b3-7586ccbbb067
ID-2: swap-2 type: zram size: 46.33 GiB used: 868 MiB (1.8%) priority: 100
System Temperatures: cpu: 46.6 C mobo: N/A gpu: amdgpu temp: 42.0 C
Memory: total: 48 GiB note: est. available: 46.33 GiB
used: 19.72 GiB (42.6%)
Processes: 561 Power: uptime: 9d 2h 50m states: freeze,mem,disk
suspend: s2idle wakeups: 3 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 18.51 GiB services: org_kde_powerdevil,
Packages: 1580 pm: dpkg pkgs: 0 pm: pacman pkgs: 1569 libs: 503
tools: octopi,paru,yay pm: flatpak pkgs: 11 Compilers: clang: 20.1.6
gcc: 15.1.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.37
System install date:     2025-04-02
Last full system update: 2025-06-13 ↻
Windows dual boot:       Yes
