OpenLinkHub used to work flawlessly with both Commander Pro and Commander Core Units that are in my system. After a recent system upgrade, that functionality has broken. I see that the kernel is unable to communicate with the devices anymore per the Journald error message output
Jornal Error output:
`Dec 15 22:16:05 PHOENIXATE kernel: usb 2-2: device not accepting address 3, error -71
Dec 15 22:16:05 PHOENIXATE kernel: usb 2-2: device not accepting address 4, error -71
Dec 15 22:16:05 PHOENIXATE kernel: usb 2-2: device not accepting address 5, error -71
Dec 15 22:16:05 PHOENIXATE kernel: usb 2-2: device not accepting address 6, error -71
Dec 15 22:16:05 PHOENIXATE kernel: usb usb2-port2: unable to enumerate USB device
Dec 15 22:16:02 PHOENIXATE systemd-modules-load[329]: Failed to find module 'acpi_call'
Dec 16 17:15:59 PHOENIXATE systemd-modules-load[709]: Failed to find module 'acpi_call'
Dec 16 17:15:59 PHOENIXATE kernel: Bluetooth: hci0: No support for _PRR ACPI method`
Garuda-inxi output:
Kernel: 6.12.5-arch1-1-znver3 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver3
root=UUID=0811b3c2-4fae-4301-8cc8-aee6104f5c03 rw rootflags=subvol=@
quiet resume=UUID=b1789870-3e88-4397-87ba-cf22537a4adc loglevel=3
amdgpu.ppfeaturemask=0xffffffff splash ibt=off
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 5021 date: 09/29/2024
Device-1: ps-controller-battery-d0:bc:c1:fb:46:48 model: N/A serial: N/A
charge: N/A status: charging
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3592 min/max: 550/5084 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3592 2: 3592 3: 3592
4: 3592 5: 3592 6: 3592 7: 3592 8: 3592 9: 3592 10: 3592 11: 3592 12: 3592
13: 3592 14: 3592 15: 3592 16: 3592 17: 3592 18: 3592 19: 3592 20: 3592
21: 3592 22: 3592 23: 3592 24: 3592 25: 3592 26: 3592 27: 3592 28: 3592
29: 3592 30: 3592 31: 3592 32: 3592 bogomips: 217279
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: XFX RX-79XMERCB9 driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3,
HDMI-A-1, Writeback-1 bus-ID: 0a:00.0 chip-ID: 1002:744c class-ID: 0300
unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi gpu: amdgpu
display-ID: 0
Monitor-1: DP-1 res: 3440x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.1-arch1.3
navi31 LLVM 18.1.8 DRM 3.59 6.12.5-arch1-1-znver3) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 16 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
bus-ID: 0a:00.1 chip-ID: 1002:ab30 class-ID: 0403
lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Sony DualSense wireless controller (PS5)
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 5-2:3 chip-ID: 054c:0ce6 class-ID: 0300
API: ALSA v: k6.12.5-arch1-1-znver3 status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:3 chip-ID: 8087:0032
Local Storage: total: 2.75 TiB used: 459.42 GiB (16.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7
temp: 54.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital model: PC SN530
SDBPNPZ-1T00-1002 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 21106000 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 459.42 GiB (25.1%)
used: 892 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 459.42 GiB (25.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 32
ID-2: swap-2 type: partition size: 34.37 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 39.5 C mobo: 43.0 C gpu: amdgpu temp: 61.0 C
mem: 68.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 967 fan-3: 0 fan-4: 0 fan-5: 3479
fan-6: 2227 fan-7: 0 gpu: amdgpu fan: 567
Memory: total: 32 GiB available: 31.25 GiB used: 5.11 GiB (16.4%)
Processes: 607 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.47 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1877 libs: 487 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-11-27
Last full system update: 2024-12-15 ↻
lsbusb output:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0bda:5409 Realtek Semiconductor Corp. USB2.1 Hub
Bus 001 Device 003: ID 1b1c:1b7f Corsair CORSAIR DARK CORE RGB PRO SE Gaming Dongle
Bus 001 Device 004: ID 187c:100e Alienware Corporation HID Device
Bus 001 Device 005: ID 1b1c:0c2a Corsair CORSAIR iCUE COMMANDER CORE XT
Bus 001 Device 006: ID 1b1c:0c39 Corsair LCD Cap for Elite Capellix coolers
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 0bda:0409 Realtek Semiconductor Corp. USB3.2 Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 1b1c:0c32 Corsair CORSAIR iCUE COMMANDER Core
Bus 003 Device 003: ID 8087:0032 Intel Corp. AX210 Bluetooth
Bus 003 Device 004: ID 0b05:18f3 ASUSTek Computer, Inc. AURA LED Controller
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 002: ID 0764:0601 Cyber Power System, Inc. PR1500LCDRT2U UPS
Bus 005 Device 003: ID 054c:0ce6 Sony Corp. DualSense wireless controller (PS5)
Bus 005 Device 004: ID 1b1c:1b7c Corsair CORSAIR K100 RGB Optical-Mechanical Gaming Keyboard
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
lm-sensors output:
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1: +34.0°C
jc42-i2c-9-1b
Adapter: SMBus PIIX4 adapter port 0 at 0b00
temp1: +43.6°C (low = +0.0°C) ALARM (HIGH, CRIT)
(high = +0.0°C, hyst = +0.0°C)
(crit = +0.0°C, hyst = +0.0°C)
k10temp-pci-00c3
Adapter: PCI adapter
Tctl: +45.1°C
Tccd1: +38.8°C
Tccd2: +37.2°C
nvme-pci-0100
Composite: +55.9°C (low = -273.1°C, high = +81.8°C)
(crit = +84.8°C)
Sensor 1: +55.9°C (low = -273.1°C, high = +65261.8°C)
Sensor 2: +62.9°C (low = -273.1°C, high = +65261.8°C)
nct6798-isa-0290
Adapter: ISA adapter
in0: 864.00 mV (min = +0.00 V, max = +1.74 V)
in1: 984.00 mV (min = +0.00 V, max = +0.00 V) ALARM
in2: 3.39 V (min = +0.00 V, max = +0.00 V) ALARM
in3: 3.26 V (min = +0.00 V, max = +0.00 V) ALARM
in4: 1000.00 mV (min = +0.00 V, max = +0.00 V) ALARM
in5: 688.00 mV (min = +0.00 V, max = +0.00 V)
in6: 984.00 mV (min = +0.00 V, max = +0.00 V) ALARM
in7: 3.39 V (min = +0.00 V, max = +0.00 V) ALARM
in8: 3.34 V (min = +0.00 V, max = +0.00 V) ALARM
in9: 1.81 V (min = +0.00 V, max = +0.00 V) ALARM
in10: 368.00 mV (min = +0.00 V, max = +0.00 V) ALARM
in11: 1.07 V (min = +0.00 V, max = +0.00 V) ALARM
in12: 1.02 V (min = +0.00 V, max = +0.00 V) ALARM
in13: 976.00 mV (min = +0.00 V, max = +0.00 V) ALARM
in14: 1000.00 mV (min = +0.00 V, max = +0.00 V) ALARM
fan1: 0 RPM (min = 0 RPM)
fan2: 952 RPM (min = 0 RPM)
fan3: 0 RPM (min = 0 RPM)
fan4: 0 RPM (min = 0 RPM)
fan5: 3590 RPM (min = 0 RPM)
fan6: 2235 RPM (min = 0 RPM)
fan7: 0 RPM (min = 0 RPM)
SYSTIN: +43.0°C (high = +80.0°C, hyst = +75.0°C)
(crit = +125.0°C) sensor = thermistor
CPUTIN: +39.5°C (high = +80.0°C, hyst = +75.0°C)
AUXTIN0: +26.0°C (high = +80.0°C, hyst = +75.0°C)
AUXTIN1: +69.0°C (high = +80.0°C, hyst = +75.0°C)
AUXTIN2: +22.0°C (high = +80.0°C, hyst = +75.0°C)
AUXTIN3: +26.0°C (high = +80.0°C, hyst = +75.0°C)
AUXTIN4: +43.0°C (high = +80.0°C, hyst = +75.0°C)
(crit = +100.0°C)
PECI Agent 0 Calibration: +40.0°C (high = +80.0°C, hyst = +75.0°C)
SMBUSMASTER 1: +76.0°C
PCH_CHIP_CPU_MAX_TEMP: +0.0°C
PCH_CHIP_TEMP: +0.0°C
PCH_CPU_TEMP: +0.0°C
TSI0_TEMP: +45.1°C
TSI1_TEMP: +76.2°C
intrusion0: ALARM
intrusion1: ALARM
beep_enable: disabled
jc42-i2c-9-1a
temp1: +41.9°C (low = +0.0°C) ALARM (HIGH, CRIT)
amdgpu-pci-0a00
vddgfx: 218.00 mV
fan1: 569 RPM (min = 0 RPM, max = 3300 RPM)
edge: +52.0°C (crit = +100.0°C, hyst = -273.1°C)
(emerg = +105.0°C)
junction: +62.0°C (crit = +110.0°C, hyst = -273.1°C)
(emerg = +115.0°C)
mem: +70.0°C (crit = +108.0°C, hyst = -273.1°C)
(emerg = +113.0°C)
PPT: 83.00 W (cap = 339.00 W)
nvme-pci-0400
Composite: +40.9°C (low = -5.2°C, high = +79.8°C)
(crit = +84.8°C)
According to the sensor output, all devices connected are working fine.
I updated the OpenLinkHub to the latest version as it had shown OpenLinkHub.service as having failed to load initially in the garuda-inxi. This has not resolved the issue for my Corsair devices not being recognized, though.
