OpenGL 3.3. or better?
Hello
I'm wondering if my system supports Garuda Linux. I don't really understand the diffrent outputs when checking OpenGL version from terminal. With glxinfo | grep "OpenGL version" I get OpenGL version string: 4.6 (Compatibility Profile) Mesa 21.2.6 and with glxinfo | grep "version" I get
server glx version string: 1.4
client glx version string: 1.4
GLX version: 1.4
    Max core profile version: 4.6
    Max compat profile version: 4.6
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.2
OpenGL core profile version string: 4.6 (Core Profile) Mesa 21.2.6
OpenGL core profile shading language version string: 4.60
OpenGL shading language version string: 4.60
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 21.2.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
    GL_EXT_shader_implicit_conversions, GL_EXT_shader_integer_mix,
I have enough space and RAM to meet the requirements from Garuda Linux | Download. Could someone explain which number the 3.3 is in the requirements? As you can see, there are some version numbers above it and some below it in my outputs.
I think it’s this one:
Looks like you are good to go, give it a shot. :+1:
Ok, I'll try it out.
