i often experience if i’m using the “Open” command from a GUI, or, e.g. Open Folder in VS Code, [this Arch linux system at least as it did it just now]
Kernel: 6.14.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1 clocksource: tsc
root=UUID=1418e16d-beda-43d4-b69f-509be30082bf rw rootflags=subvol=@ quiet loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0 wm: kwin_wayland
with: krunner,ulauncher tools: avail: budgie-screensaver, cinnamon-screensaver, gtklock,
swayidle, swaylock, xautolock vt: 1 dm: LightDM v: 1.32.0 Distro: Garuda base: Arch Linux
Type: Desktop Mobo: PELADN model: WI-6 serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends LLC. v: PL-BI-M8-AN-H03R110-B00B-110-B date: 10/06/2023
Info: model: Intel N100 bits: 64 type: MCP arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0xBE (190) stepping: 0 microcode: 0x1D
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3400 min/max: 700/3400 scaling: driver: intel_pstate governor: powersave
cores: 1: 3400 2: 3400 3: 3400 4: 3400 bogomips: 6451
Device-1: Intel Alder Lake-N [UHD Graphics] driver: i915 v: kernel alternate: xe arch: Xe
process: Intel 10nm built: 2020-21 ports: active: HDMI-A-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:46d1 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 compositor: kwin_wayland
driver: X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 model: HP E241i serial: <filter> built: 2015 res: 1920x1200 dpi: 94
gamma: 1.2 size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes: max: 1920x1200
min: 640x480
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: integrated-gpu name: Intel Graphics (ADL-N)
driver: mesa intel v: 25.0.5-arch1.1 device-ID: 8086:46d1 surfaces: N/A device: 1 type: cpu
name: llvmpipe (LLVM 19.1.7 256 bits) driver: mesa llvmpipe v: 25.0.5-arch1.1 (LLVM 19.1.7)
Info: Tools: api: vulkaninfo de: kscreen-doctor x11: xdpyinfo, xprop, xrandr
Device-1: Intel Alder Lake-N PCH High Definition Audio driver: snd_hda_intel v: kernel
alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:54c8 class-ID: 0403
API: ALSA v: k6.14.6-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter driver: rtw_8821ce v: N/A
modules: rtw88_8821ce pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 01:00.0
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
IF-ID-1: br-4bcac93f9cec state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: br-6e1e8dfcf5e0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-3: br-aa8f45bff726 state: down mac: <filter>
IF-ID-4: br-b403c35ce5d8 state: down mac: <filter>
IF-ID-5: docker0 state: down mac: <filter>
IF-ID-6: veth1478559 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-7: veth22b80fd state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-8: veth89041e1 state: up speed: 10000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, sm
bd, systemd-timesyncd, wpa_supplicant
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-8:4 chip-ID: 0bda:c821 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2 lmp-v: 8 status:
Local Storage: total: 476.94 GiB used: 132.21 GiB (27.7%)
ID-1: /dev/sda maj-min: 8:0 model: 512GB SSD size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 201 scheme: GPT
ID-1: / raw-size: 229.87 GiB size: 229.87 GiB (100.00%) used: 65.28 GiB (28.4%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 12.2 MiB (4.1%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 229.87 GiB size: 229.87 GiB (100.00%) used: 65.28 GiB (28.4%) fs: btrfs
ID-4: /var/log raw-size: 229.87 GiB size: 229.87 GiB (100.00%) used: 65.28 GiB (28.4%)
ID-5: /var/tmp raw-size: 229.87 GiB size: 229.87 GiB (100.00%) used: 65.28 GiB (28.4%)
ID-1: swap-1 type: zram size: 15.35 GiB used: 15.9 MiB (0.1%) priority: 100 comp: zstd
avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4 dev: /dev/zram0
ID-2: swap-2 type: partition size: 16.9 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
System Temperatures: cpu: 41.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.35 GiB used: 5.1 GiB (33.2%)
Processes: 343 Power: uptime: 2h 17m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 6.12 GiB
Packages: 2083 pm: pacman pkgs: 2077 libs: 480 tools: octopi,pacseek,paru,yay pm: appimage
pkgs: 0 pm: flatpak pkgs: 6 Compilers: clang: 19.1.7 gcc: 15.1.1 Client: shell wrapper
v: 5.2.37-release inxi: 3.3.38
System install date: 2025-04-11
Last full system update: 2025-05-19 ↻
Open > Dir - Dir - Dir - [ TARGET dir ] :: lister crashes and goes back to primary GUI.
not specfic to VS Code, but for instance.
annoying, but not insurmountable. i feel it doesn’t do it if i switch out to Budgie or uh. the other Win manager not wayland.
of course want to get to bottom of it, because this DT is comfortable otherwise.
