My laptop was working properly a week ago but suddenly one of the USB port stop recognising any device I plug in. I want to connect a USB-stick for my headset (the light turns on) but the computer doesn't read it
Here are my garuda -inxi:
╭─artrex@acer in ~ took 6ms
╰─λ garuda-inxi
Kernel: 6.1.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=8ccf1418-878f-4445-94cd-fa59cea87218 rw single
rootflags=subvol=@
Type: Laptop System: Acer product: Swift SF316-51 v: V1.10
Mobo: TGL model: Sangria_TL v: V1.10 serial: <superuser required>
UEFI: Insyde v: 1.10 date: 09/16/2021
ID-1: BAT1 charge: 46.0 Wh (100.0%) condition: 46.0/56.0 Wh (82.2%)
volts: 17.3 min: 15.4 model: SMP AP18C7M type: Li-ion serial: <filter>
status: full cycles: 43
Info: model: 11th Gen Intel Core i5-11300H bits: 64 type: MT MCP
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 2269 high: 3100 min/max: 400/4400 scaling:
driver: intel_pstate governor: powersave cores: 1: 3100 2: 3100 3: 400
4: 3100 5: 3100 6: 1101 7: 3100 8: 1152 bogomips: 49766
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-12.1
process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49
Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-5:2
chip-ID: 0408:a094 class-ID: 0e02
Monitor-1: eDP-1 model: ChiMei InnoLux 0x160b built: 2020 res: 1920x1080
hz: 60 dpi: 137 gamma: 1.2 size: 355x199mm (13.98x7.83") diag: 407mm (16")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio
vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound API: ALSA v: k6.1.7-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 135.62 GiB (28.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 3400 MTFDKBA512TFH
lanes: 4 type: SSD serial: <filter> rev: P7MA000 temp: 49.9 C scheme: GPT
ID-1: / raw-size: 459.67 GiB size: 459.67 GiB (100.00%)
used: 135.62 GiB (29.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.67 GiB size: 459.67 GiB (100.00%)
ID-4: /var/log raw-size: 459.67 GiB size: 459.67 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.67 GiB size: 459.67 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.42 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.97 GiB used: 0 KiB (0.0%)
Src: /sys System Temperatures: cpu: 30.0 C mobo: N/A
Processes: 254 Uptime: 5m wakeups: 300 Memory: 15.42 GiB
used: 2.88 GiB (18.7%) Init: systemd v: 252 default: graphical
pkgs: 1273 libs: 332 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash
v: 5.1.16 running-in: alacritty inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-08-31
Last full system update: 2023-01-24
Failed units: plymouth-deactivate.service
This is the error log I'm geting with sudo dmesg | grep -i usb:
╭─artrex@acer in ~ as 🧙 took 1ms
╰─λ sudo dmesg | grep -i usb
[ 0.397450] ACPI: bus type USB registered
[ 0.397450] usbcore: registered new interface driver usbfs
[ 0.397450] usbcore: registered new interface driver hub
[ 0.397450] usbcore: registered new device driver usb
[ 0.758987] usbcore: registered new interface driver usbserial_generic
[ 0.758989] usbserial: USB Serial support registered for generic
[ 3.582726] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 1
[ 3.584006] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 2
[ 3.584008] xhci_hcd 0000:00:0d.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.584039] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 3.584041] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.584043] usb usb1: Product: xHCI Host Controller
[ 3.584044] usb usb1: Manufacturer: Linux 6.1.7-zen1-1-zen xhci-hcd
[ 3.584045] usb usb1: SerialNumber: 0000:00:0d.0
[ 3.594346] hub 1-0:1.0: USB hub found
[ 3.601332] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 3.601335] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.601337] usb usb2: Product: xHCI Host Controller
[ 3.601338] usb usb2: Manufacturer: Linux 6.1.7-zen1-1-zen xhci-hcd
[ 3.601339] usb usb2: SerialNumber: 0000:00:0d.0
[ 3.601472] hub 2-0:1.0: USB hub found
[ 3.602718] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 3.604142] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 3.604144] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.604174] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 3.604176] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.604177] usb usb3: Product: xHCI Host Controller
[ 3.604178] usb usb3: Manufacturer: Linux 6.1.7-zen1-1-zen xhci-hcd
[ 3.604179] usb usb3: SerialNumber: 0000:00:14.0
[ 3.607605] hub 3-0:1.0: USB hub found
[ 3.611978] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 3.611981] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.611982] usb usb4: Product: xHCI Host Controller
[ 3.611983] usb usb4: Manufacturer: Linux 6.1.7-zen1-1-zen xhci-hcd
[ 3.611985] usb usb4: SerialNumber: 0000:00:14.0
[ 3.612061] hub 4-0:1.0: USB hub found
[ 3.612296] usb: port power management may be unreliable
[ 3.852407] usb 3-5: new high-speed USB device number 2 using xhci_hcd
[ 3.990201] usb 3-5: New USB device found, idVendor=0408, idProduct=a094, bcdDevice= 0.02
[ 3.990208] usb 3-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.990211] usb 3-5: Product: HD User Facing
[ 3.990213] usb 3-5: Manufacturer: SunplusIT Inc
[ 4.106531] usb 3-7: new high-speed USB device number 3 using xhci_hcd
[ 4.240470] usb 3-7: New USB device found, idVendor=1c7a, idProduct=0575, bcdDevice=10.72
[ 4.240478] usb 3-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.240481] usb 3-7: Product: EgisTec EH575
[ 4.240483] usb 3-7: Manufacturer: EgisTec
[ 4.240486] usb 3-7: SerialNumber: 07B35E7E
[ 4.357524] usb 3-10: new full-speed USB device number 4 using xhci_hcd
[ 4.486653] usb 3-10: New USB device found, idVendor=8087, idProduct=0026, bcdDevice= 0.02
[ 4.486660] usb 3-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.924255] typec port0: bound usb3-port2 (ops connector_ops)
[ 5.924263] typec port0: bound usb2-port1 (ops connector_ops)
[ 5.994328] usbcore: registered new interface driver btusb
[ 6.199861] usb 3-5: Found UVC 1.00 device HD User Facing (0408:a094)
[ 6.217517] input: HD User Facing: HD User Facing as /devices/pci0000:00/0000:00:14.0/usb3/3-5/3-5:1.0/input/input12
[ 6.220523] usbcore: registered new interface driver uvcvideo
[ 77.567533] usb 3-1: new full-speed USB device number 5 using xhci_hcd
[ 77.681607] usb 3-1: device descriptor read/64, error -71
[ 77.900603] usb 3-1: device descriptor read/64, error -71
[ 78.123552] usb 3-1: new full-speed USB device number 6 using xhci_hcd
[ 78.237632] usb 3-1: device descriptor read/64, error -71
[ 78.460607] usb 3-1: device descriptor read/64, error -71
[ 78.569646] usb usb3-port1: attempt power cycle
[ 78.949549] usb 3-1: new full-speed USB device number 7 using xhci_hcd
[ 78.949757] usb 3-1: Device not responding to setup address.
[ 79.153744] usb 3-1: Device not responding to setup address.
[ 79.361543] usb 3-1: device not accepting address 7, error -71
[ 79.475409] usb 3-1: new full-speed USB device number 8 using xhci_hcd
[ 79.475667] usb 3-1: Device not responding to setup address.
[ 79.681776] usb 3-1: Device not responding to setup address.
[ 79.889549] usb 3-1: device not accepting address 8, error -71
[ 79.889704] usb usb3-port1: unable to enumerate USB device
I tried to change the usbcore.autosuspend but didn't work and since doesn't matter is a plug the USB-stick before or after rebooting, I don't think is actually the problem but I couldn't find any solution on the web and that's why I'm asking for assistance.
Thank you.
