One monitor going black after logoff/logon
Dual monitors, when pc goes idle and I login again, one monitor (DP3) starts going black. Part when I move cursor to it, part randomly, and goes fully black eventually. If I reconnect the cable it starts working fine again, but at first shows an empty workspace.
Also I have login screen on both screens.
Any ideas?
# for 2560x1440
monitor = DP-3, 2560x1440@144, 0x0, 1, vrr, 1
monitor = DP-2, 1920x1080@99.93, -1920x0, 1
monitor = , preferred, auto, 1
workspace = 1, monitor:DP-2, default=true
workspace = 2, monitor:DP-3, default=true
workspace = 3, monitor:DP-3
workspace = 4, monitor:DP-2
  Kernel: 6.14.4-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=5e7ccf81-41c3-4ad9-93e1-c903d7c6d143 rw rootflags=subvol=@
    quiet resume=UUID=11d60491-4d6a-4fdb-8b1e-a3eb6d4f2e31 loglevel=3 ibt=off
  Desktop: Hyprland v: 0.48.1 with: waybar tools: avail: hypridle,swaylock
    vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
  Type: Desktop Mobo: Gigabyte model: Z790 AORUS ELITE AX
    Megatrends LLC. v: F12 date: 09/27/2024
  Info: model: 13th Gen Intel Core i5-13600K bits: 64 type: MST AMCP
    microcode: 0x12C
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
    st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
    KiB, 8x64 KiB L2: 20 MiB desc: 6x2 MiB, 2x4 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 5100 min/max: 800/5100:3900 scaling:
    driver: intel_pstate governor: performance cores: 1: 5100 2: 5100 3: 5100
    4: 5100 5: 5100 6: 5100 7: 5100 8: 5100 9: 5100 10: 5100 11: 5100 12: 5100
    13: 5100 14: 5100 15: 5100 16: 5100 17: 5100 18: 5100 19: 5100 20: 5100
    bogomips: 139776
  Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Gigabyte
    built: 2020-21 ports: active: none empty: DP-4,HDMI-A-2,HDMI-A-3
    bus-ID: 00:02.0 chip-ID: 8086:a780 class-ID: 0380
  Device-2: NVIDIA AD104 [GeForce RTX 4070 SUPER] vendor: Gigabyte
    non-free: 550-570.xx+ status: current (as of 2025-04) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: none off: DP-2,DP-3
    empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2783 class-ID: 0300
  Device-3: Tobii AB EyeChip driver: N/A type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 2104:0313 class-ID: 0e02
    compositor: Hyprland v: 0.48.1 driver: X: loaded: modesetting,nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: 1
  Monitor-1: DP-2 model: BenQ XL2720Z serial: <filter> built: 2014 res:
    mode: 1920x1080 hz: 100 scale: 100% (1) dpi: 82 gamma: 1.2
    max: 1920x1080 min: 640x480
  Monitor-2: DP-3 model: LG (GoldStar) 27GL850 serial: <filter> built: 2020
    res: mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 109 gamma: 1.2
    max: 2560x1440 min: 640x480
  API: Vulkan v: 1.4.309 layers: 10 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4070 SUPER driver: nvidia v: 570.144 device-ID: 10de:2783
    surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu
    name: Intel Graphics (RPL-S) driver: mesa intel v: 25.0.4-arch1.1
    device-ID: 8086:a780 surfaces: xcb,xlib,wayland device: 2 type: cpu
    name: llvmpipe (LLVM 19.1.7 256 bits) driver: mesa llvmpipe
    v: 25.0.4-arch1.1 (LLVM 19.1.7) device-ID: 10005:0000
  Info: Tools: api: vulkaninfo gpu: nvidia-settings,nvidia-smi wl: kanshi,
    wdisplays, wlr-randr x11: xprop,xrandr
  Device-1: Intel Raptor Lake High Definition Audio vendor: Gigabyte
  Device-2: NVIDIA AD104 High Definition Audio vendor: Gigabyte
  Device-3: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
    Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 1102:0012 class-ID: 0403
  Device-4: Samson GoMic compact condenser mic
    lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 17a0:0305 class-ID: 0300
  API: ALSA v: k6.14.4-zen1-2-zen status: kernel-api
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 8087:0033
  Local Storage: total: 2.41 TiB used: 28.37 GiB (1.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Intel model: SSDPEDMW400G4
    size: 372.61 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 8EV101H0 temp: 51.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: PNY model: CS3030 1TB SSD
    lanes: 4 tech: SSD serial: <filter> fw-rev: CS303320 temp: 26.9 C
    scheme: MBR
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1ER162
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
  ID-1: / raw-size: 120.12 GiB size: 120.12 GiB (100.00%)
    used: 12.82 GiB (10.7%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:3
    used: 612 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:5
  ID-3: /home raw-size: 236.37 GiB size: 236.37 GiB (100.00%)
    used: 15.56 GiB (6.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
  ID-4: /var/log raw-size: 120.12 GiB size: 120.12 GiB (100.00%)
  ID-5: /var/tmp raw-size: 120.12 GiB size: 120.12 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.1 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 20
  ID-2: swap-2 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:6
  System Temperatures: cpu: 48.5 C mobo: 47.0 C
  Memory: total: 32 GiB note: est. available: 31.1 GiB used: 7.2 GiB (23.2%)
  Processes: 453 Power: uptime: 4h 35m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.37 GiB services: upowerd Init: systemd
    v: 257 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1563 libs: 491 tools: pacseek,paru pm: flatpak
    pkgs: 0 Compilers: gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
    running-in: foot inxi: 3.3.38
  System install date:     2025-04-30
  Last full system update: 2025-05-07
Give an HDMI cable a test instead of display port. Be sure the HDMI cable is at least 4K capable.
Never had an Issue on Windows though.
