resume of the problem:
- with OS X everything works
- with garuda-mokka-kde as I plug the 3.5mm jack the audio does not work, but the system does see the headphones. ( on Bluetooth everything works fine).
here are the specs of the system:
> System:
> Kernel: 6.16.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
> clocksource: tsc avail: hpet,acpi_pm
> parameters: root=UUID=282e5867-cdbf-4650-b4ff-e95f698ac2f3 rw
> rootflags=subvol=@
> vt.default_red=30,243,166,249,137,245,148,186,88,243,166,249,137,245,148,166
> vt.default_grn=30,139,227,226,180,194,226,194,91,139,227,226,180,194,226,173
> vt.default_blu=46,168,161,175,250,231,213,222,112,168,161,175,250,231,213,200
> quiet loglevel=3 ibt=off initrd=@\boot\initramfs-linux-zen.img
> Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
> wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
> Machine:
> Type: Desktop System: Apple product: iMac15,1 v: 1.0
> serial: <superuser required> Chassis: type: 13 v: Mac-FA842E06C61E91C5
> Mobo: Apple model: Mac-FA842E06C61E91C5 v: iMac15,1
> serial: <superuser required> uuid: <superuser required> UEFI: Apple
> v: 478.0.0.0.0 date: 01/13/2023
> Battery:
> Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
> serial: <filter> charge: 55% (should be ignored) rechargeable: yes
> status: discharging
> CPU:
> Info: model: Intel Core i7-4790K bits: 64 type: MT MCP arch: Haswell
> gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
> family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
> Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
> smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
> desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
> Speed (MHz): avg: 800 min/max: 800/4400 scaling: driver: intel_cpufreq
> governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
> 8: 800 bogomips: 63856
> Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
> Vulnerabilities: <filter>
> Graphics:
> Device-1: Advanced Micro Devices [AMD/ATI] Tonga XT / Amethyst [Radeon R9
> 380X M295X] vendor: Apple driver: amdgpu v: kernel arch: GCN-3
> code: Volcanic Islands process: TSMC 28nm built: 2014-19 pcie: gen: 3
> speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2,DP-3
> bus-ID: 01:00.0 chip-ID: 1002:6938 class-ID: 0300 temp: 109.0 C
> Device-2: Apple FaceTime HD Camera (Built-in) driver: uvcvideo type: USB
> rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:5 chip-ID: 05ac:8511
> class-ID: 0e02 serial: <filter>
> Display: wayland server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
> compositor: kwin_wayland driver: X: loaded: amdgpu unloaded: modesetting
> alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
> Monitor-1: eDP-1 model: Apple iMac serial: <filter> built: 2014 res:
> mode: 3840x2160 hz: 60 scale: 150% (1.5) to: 2560x1440 dpi: 163 gamma: 1.2
> size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
> max: 3840x2160 min: 640x480
> API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi
> device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi
> wayland: drv: radeonsi x11: drv: radeonsi
> API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.1-arch1.5
> glx-v: 1.4 direct-render: yes renderer: AMD Radeon R9 200 Series (radeonsi
> tonga ACO DRM 3.64 6.16.4-zen1-1-zen) device-ID: 1002:6938
> memory: 3.91 GiB unified: no display-ID: :0.0
> API: Vulkan v: 1.4.321 layers: 5 device: 0 type: discrete-gpu name: AMD
> Radeon R9 200 Series (RADV TONGA) driver: mesa radv v: 25.2.1-arch1.5
> device-ID: 1002:6938 surfaces: N/A device: 1 type: cpu name: llvmpipe
> (LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.1-arch1.5 (LLVM
> 20.1.8) device-ID: 10005:0000 surfaces: N/A
> Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo
> de: kscreen-console,kscreen-doctor wl: wayland-info
> x11: xdpyinfo, xprop, xrandr
> Audio:
> Device-1: Intel 8 Series/C220 Series High Definition Audio
> driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
> class-ID: 0403
> Device-2: Advanced Micro Devices [AMD/ATI] Tonga HDMI Audio [Radeon R9
> 285/380] driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
> lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aad8 class-ID: 0403
> Device-3: Generalplus USB Audio Device
> driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
> lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 1b3f:2008 class-ID: 0300
> API: ALSA v: k6.16.4-zen1-1-zen status: kernel-api tools: N/A
> Server-1: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
> status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin
> 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
> Network:
> Device-1: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter
> vendor: Apple driver: wl v: kernel modules: bcma pcie: gen: 1
> speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14e4:43a0 class-ID: 0280
> IF: wlp3s0 state: up mac: <filter>
> Device-2: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe driver: tg3
> v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
> chip-ID: 14e4:1686 class-ID: 0200
> IF: enp4s0f0 state: down mac: <filter>
> Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
> Bluetooth:
> Device-1: Apple Bluetooth Host Controller driver: btusb v: 0.8 type: USB
> rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8.3:9
> chip-ID: 05ac:828d class-ID: fe01
> Report: btmgmt ID: hci0 rfk-id: 1 state: up address: N/A
> Drives:
> Local Storage: total: 1.02 TiB used: 15.56 GiB (1.5%)
> SMART Message: Unable to run smartctl. Root privileges required.
> ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: HDD ST1000DM003
> size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
> tech: HDD rpm: 7200 serial: <filter> fw-rev: AP14 scheme: GPT
> ID-2: /dev/sdb maj-min: 8:16 vendor: Apple model: SSD SD0128F
> size: 113 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
> tech: SSD serial: <filter> fw-rev: 821 scheme: GPT
> Partition:
> ID-1: / raw-size: 65.24 GiB size: 65.24 GiB (100.00%)
> used: 15.55 GiB (23.8%) fs: btrfs dev: /dev/sdb4 maj-min: 8:20
> ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.45%)
> used: 15.4 MiB (7.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
> ID-3: /home raw-size: 65.24 GiB size: 65.24 GiB (100.00%)
> ID-4: /var/log raw-size: 65.24 GiB size: 65.24 GiB (100.00%)
> ID-5: /var/tmp raw-size: 65.24 GiB size: 65.24 GiB (100.00%)
> Swap:
> Kernel: swappiness: 133 (default 60) cache-pressure: 100 (default) zswap: no
> ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100
> comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 dev: /dev/zram0
> Sensors:
> System Temperatures: cpu: 65.0 C mobo: N/A gpu: amdgpu temp: 108.0 C
> Fan Speeds (rpm): N/A
> Info:
> Memory: total: 32 GiB available: 31.28 GiB used: 3.54 GiB (11.3%)
> Processes: 315 Power: uptime: 8m states: freeze,mem,disk suspend: deep
> avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
> suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
> power-profiles-daemon, upowerd Init: systemd v: 257 default: graphical
> tool: systemctl
> Packages: pm: pacman pkgs: 1493 libs: 414 tools: octopi,paru Compilers:
> gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.0.2 running-in: konsole
> inxi: 3.3.38
> Garuda (2.8.2-2):
> System install date: 2025-08-31
> Last full system update: 2025-08-31
> Is partially upgraded: No
> Relevant software: snapper NetworkManager dracut
> Windows dual boot: No/Undetected
> Failed units:
