~hello
on gnome, when i try to stop the bluetooth, i have the aeroplane mode which turns on, turns off and the bluetooth turns on again.
i have this error:
Bluetooth: hci0: HCI reset during shutdown failed
Error Bluetooth: hci0: Initiating acpi reset method
Error Bluetooth: hci0: command 0x0c1a tx timeout
Error Bluetooth: hci0: Error when powering off device on rfkill (-110)
Error Bluetooth: hci0: Opcode 0x0c1a failed: -110
a problem with the kernel/firmware; anyone with a A211 bluetooth with this problem?
thanks for your help
root=UUID=c40ef420-4ede-40ec-a143-6dabd770e681 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: GNOME v: 48.2 tk: GTK v: 3.24.49 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 48.0 Distro: Garuda base: Arch Linux
Type: Laptop System: LENOVO product: 21BN002VFR v: ThinkPad X13 Gen 3
Mobo: LENOVO model: 21BN002VFR
serial: <superuser required> part-nu: LENOVO_MT_21BN_BU_Think_FM_ThinkPad
X13 Gen 3 uuid: <superuser required> UEFI: LENOVO v: N3CET65W (1.46 )
date: 11/14/2024
ID-1: BAT0 charge: 28.4 Wh (58.4%) condition: 48.6/54.7 Wh (88.8%)
power: 14.4 W volts: 15.5 min: 15.4 model: Sunwoda 5B10W51855 type: Li-poly
serial: <filter> status: discharging cycles: 150
Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x437
Topology: cpus: 1x dies: 1 clusters: 4 cores: 10 threads: 12 mt: 2 tpc: 2
st: 8 smt: enabled cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32
KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 936 min/max: 400/4400:3300 scaling: driver: intel_pstate
governor: powersave cores: 1: 936 2: 936 3: 936 4: 936 5: 936 6: 936 7: 936
8: 936 9: 936 10: 936 11: 936 12: 936 bogomips: 59904
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Lenovo
built: 2021-22+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46a8 class-ID: 0300
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 174f:1812
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0964 built: 2020 res: 1920x1200
dpi: 171 gamma: 1.2 size: 286x179mm (11.26x7.05") diag: 337mm (13.3")
ratio: 16:10 modes: 1920x1200
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (ADL
GT2) device-ID: 8086:46a8 memory: 14.96 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: integrated-gpu name: Intel
Iris Xe Graphics (ADL GT2) driver: mesa intel v: 25.1.4-arch1.1
device-ID: 8086:46a8 surfaces: N/A device: 1 type: cpu name: llvmpipe
Info: Tools: api: eglinfo, glxinfo, vulkaninfo
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.15.3-zen1-1-zen status: kernel-api tools: N/A
IF: wlp0s20f3 state: down mac: <filter>
IF-ID-1: enp0s20f0u1 state: up speed: 425 Mbps duplex: half mac: <filter>
IF-ID-2: utun420 state: unknown speed: N/A duplex: N/A mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:18 chip-ID: 8087:0033
Report: btmgmt ID: hci0 rfk-id: 10 state: up address: N/A
System Temperatures: cpu: N/A mobo: N/A
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB note: est. available: 15.32 GiB used: 7.51 GiB (49.0%)
Processes: 410 Power: uptime: 7h 57m states: freeze,mem,disk
suspend: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.11 GiB services: gsd-power,
Packages: pm: pacman pkgs: 1380 libs: 410 tools: pamac,paru pm: flatpak
pkgs: 0 Compilers: gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
running-in: gnome-terminal inxi: 3.3.38
System install date: 2025-06-12
Last full system update: 2025-06-22
tbg
June 23, 2025, 8:23pm
4
My guess would be that is a side effect of recent changes to the linux-firmware
package. Search the forum for the most recent posts on that topic. You will likely need to uninstall/reinstall the linux-firmware
package, (search recent forum posts).
You could also try rmmodding the btusb
Bluetooth driver module if nothing else helps.
no i’ve cachyos on another partition, no update for 2 months, and i’ve got the same problem
can you give me more details about btusb? i quite a beginner
thks !
i did with the new linux-firmware from today..same result…
what can you propose with btusb or btintel?
tbg
June 26, 2025, 7:29am
7
See:
Hello everyone I have recently encountered an issue with my installation. I used to get approximately 500 mb/s down and now it has plummeted to around 20 mb/s. I have tried going back to an earlier snapshot to no avail.
What I have tried
Rebooted
Restarted network manager
Configured wifi to use 5 Ghz - even though my router offers it the system will not recognize the 5 ghz band. I am unsure if it has always been like this or if this is recent
Rebooted to previous snapshot
What I haven’t tried
To unload the bluetooth driver module is usually pretty straightforward:
sudo modprobe -r btusb
[quote=“Pommede1, post:1, topic:44594”]
0%)
same result
and modprobe -r btusb, i’ve no longer access to bluetooth..it was better before
if i can help i’ve have this
“MESSAGE”: “A security policy denied :1.6 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.105.”,
“PRIORITY”: “4”,
“_SYSTEMD_UNIT”: “dbus-broker.service”
tbg
June 26, 2025, 12:23pm
9
I would suggest testing some alternate kernels such as the linux-lts
kernel as well as a few others.
Please post:
sudo dmesg | grep Blue
hwinfo --netcard --wlan --bluetooth | grep -Ei "model\:|driver\:|status\:|cmd\:|file\:|detected\:" | grep -v "Config Status"
yes i was thinking about trying another kernel..
[ 5.521377] Bluetooth: Core ver 2.22
[ 5.521401] Bluetooth: HCI device and connection manager initialized
[ 5.521405] Bluetooth: HCI socket layer initialized
[ 5.521407] Bluetooth: L2CAP socket layer initialized
[ 5.521410] Bluetooth: SCO socket layer initialized
[ 5.586132] Bluetooth: hci0: Device revision is 0
[ 5.586135] Bluetooth: hci0: Secure boot is enabled
[ 5.586137] Bluetooth: hci0: OTP lock is enabled
[ 5.586137] Bluetooth: hci0: API lock is enabled
[ 5.586138] Bluetooth: hci0: Debug lock is disabled
[ 5.586139] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 5.586140] Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
[ 5.588877] Bluetooth: hci0: DSM reset method type: 0x00
[ 5.593775] Bluetooth: hci0: Found device firmware: intel/ibt-0040-0041.sfi
[ 5.593786] Bluetooth: hci0: Boot Address: 0x100800
[ 5.593787] Bluetooth: hci0: Firmware Version: 88-13.25
[ 7.062539] Bluetooth: hci0: Waiting for firmware download to complete
[ 7.062557] Bluetooth: hci0: Firmware loaded in 1434354 usecs
[ 7.062914] Bluetooth: hci0: Waiting for device to boot
[ 7.079463] Bluetooth: hci0: Device booted in 16444 usecs
[ 7.081937] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-0040-0041.ddc
[ 7.084557] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 7.088577] Bluetooth: hci0: Firmware timestamp 2025.13 buildtype 1 build 82008
[ 7.088593] Bluetooth: hci0: Firmware SHA1: 0x47cf9d0e
[ 7.092398] Bluetooth: hci0: Fseq status: Success (0x00)
[ 7.092415] Bluetooth: hci0: Fseq executed: 00.00.02.41
[ 7.092420] Bluetooth: hci0: Fseq BT Top: 00.00.02.41
[ 7.256063] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.256066] Bluetooth: BNEP filters: protocol multicast
[ 7.256070] Bluetooth: BNEP socket layer initialized
[ 7.257158] Bluetooth: MGMT ver 1.23
[ 9.095293] Bluetooth: RFCOMM TTY layer initialized
[ 9.095303] Bluetooth: RFCOMM socket layer initialized
[ 9.095306] Bluetooth: RFCOMM ver 1.11
[ 3260.602265] Bluetooth: hci0: command 0x0c1a tx timeout
[ 3260.602266] Bluetooth: hci0: Opcode 0x0c1a failed: -110
[ 3260.602281] Bluetooth: hci0: Initiating acpi reset method
[ 3260.602283] Bluetooth: hci0: Error when powering off device on rfkill (-110)
[ 3270.778276] Bluetooth: hci0: HCI reset during shutdown failed
[ 3271.130130] Bluetooth: hci0: Device revision is 0
[ 3271.130140] Bluetooth: hci0: Secure boot is enabled
[ 3271.130143] Bluetooth: hci0: OTP lock is enabled
[ 3271.130144] Bluetooth: hci0: API lock is enabled
[ 3271.130146] Bluetooth: hci0: Debug lock is disabled
[ 3271.130148] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 3271.130151] Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
[ 3271.130275] Bluetooth: hci0: DSM reset method type: 0x00
[ 3271.136411] Bluetooth: hci0: Found device firmware: intel/ibt-0040-0041.sfi
[ 3271.136476] Bluetooth: hci0: Boot Address: 0x100800
[ 3271.136478] Bluetooth: hci0: Firmware Version: 88-13.25
[ 3272.833467] Bluetooth: hci0: Waiting for firmware download to complete
[ 3272.834232] Bluetooth: hci0: Firmware loaded in 1658025 usecs
[ 3272.834364] Bluetooth: hci0: Waiting for device to boot
[ 3272.851129] Bluetooth: hci0: Device booted in 16460 usecs
[ 3272.853350] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-0040-0041.ddc
[ 3272.855149] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 3272.858304] Bluetooth: hci0: Firmware timestamp 2025.13 buildtype 1 build 82008
[ 3272.858318] Bluetooth: hci0: Firmware SHA1: 0x47cf9d0e
[ 3272.862448] Bluetooth: hci0: Fseq status: Success (0x00)
[ 3272.862465] Bluetooth: hci0: Fseq executed: 00.00.02.41
[ 3272.862470] Bluetooth: hci0: Fseq BT Top: 00.00.02.41
[ 3272.932834] Bluetooth: MGMT ver 1.23
Model: "Intel Alder Lake-P PCH CNVi WiFi"
Driver: "iwlwifi"
Device File: wlp0s20f3
Link detected: yes
Driver Status: iwlwifi is active
Driver Activation Cmd: "modprobe iwlwifi"
Model: "Intel AX211 Bluetooth"
Driver: "btusb"
Driver Status: btusb is active
Driver Activation Cmd: "modprobe btusb"
Driver: "btusb"
tbg
June 27, 2025, 12:59am
11
Your above statement is contradicted by your last wireless status output:
Have you tried toggling Bluetooth off and on via the command line?
Unload the Bluetooth driver module, then reload the Bluetooth driver:
sudo modprobe -r btusb && sudo modprobe btusb
Or, alternately:
Activate, then deactivate the Bluetooth driver module.
sudo modprobe btusb && sudo modprobe -r btusb
From your log output:
Pommede1:
If “Secure Boot” is enabled in your bios, it should not be. Be sure Secure Boot" is disabled in your bios.
secure boot is disabled..sure..strange that dmesg says the opposite
and with sudo modprobe -r btusb
i’ve no bluetooth (it’s normal) then i cancel it.
my problem is to stop the bluetooth when i click…and restart if i want to..but it’s not so serious to have it always enable..(better than not functional)
it was working with the new update but after a second reboot, it doesn’t anymore
tbg
June 29, 2025, 12:53am
14
This ^^^ is far too vague and lacking in details to be of much use to anybody. Please be more specific and far more detailed with your responses.
Please post:
pacman -Q |grep linux-firmware*
lsmod | grep Blue
i don’t what it’s needed to help me
linux-firmware 20250627-1
linux-firmware-amdgpu 20250627-1
linux-firmware-atheros 20250627-1
linux-firmware-broadcom 20250627-1
linux-firmware-cirrus 20250627-1
linux-firmware-intel 20250627-1
linux-firmware-mediatek 20250627-1
linux-firmware-nvidia 20250627-1
linux-firmware-other 20250627-1
linux-firmware-radeon 20250627-1
linux-firmware-realtek 20250627-1
linux-firmware-whence 20250627-1
[ 4.735998] Bluetooth: Core ver 2.22
[ 4.736031] Bluetooth: HCI device and connection manager initialized
[ 4.736036] Bluetooth: HCI socket layer initialized
[ 4.736038] Bluetooth: L2CAP socket layer initialized
[ 4.736042] Bluetooth: SCO socket layer initialized
[ 4.841635] Bluetooth: hci0: Device revision is 0
[ 4.841639] Bluetooth: hci0: Secure boot is enabled
[ 4.841640] Bluetooth: hci0: OTP lock is enabled
[ 4.841640] Bluetooth: hci0: API lock is enabled
[ 4.841641] Bluetooth: hci0: Debug lock is disabled
[ 4.841642] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 4.841645] Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
[ 4.843290] Bluetooth: hci0: DSM reset method type: 0x00
[ 4.848103] Bluetooth: hci0: Found device firmware: intel/ibt-0040-0041.sfi
[ 4.848114] Bluetooth: hci0: Boot Address: 0x100800
[ 4.848115] Bluetooth: hci0: Firmware Version: 88-13.25
[ 4.893939] Bluetooth: hci0: Failed to send firmware data (-19)
[ 4.893947] Bluetooth: hci0: sending frame failed (-19)
[ 4.893953] Bluetooth: hci0: FW download error recovery failed (-19)
[ 4.893971] Bluetooth: hci0: sending frame failed (-19)
[ 4.893975] Bluetooth: hci0: Failed to read MSFT supported features (-19)
[ 5.504697] Bluetooth: hci0: Device revision is 0
[ 5.504701] Bluetooth: hci0: Secure boot is enabled
[ 5.504702] Bluetooth: hci0: OTP lock is enabled
[ 5.504703] Bluetooth: hci0: API lock is enabled
[ 5.504704] Bluetooth: hci0: Debug lock is disabled
[ 5.504705] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 5.504706] Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
[ 5.505641] Bluetooth: hci0: DSM reset method type: 0x00
[ 5.507818] Bluetooth: hci0: Found device firmware: intel/ibt-0040-0041.sfi
[ 5.507834] Bluetooth: hci0: Boot Address: 0x100800
[ 5.507835] Bluetooth: hci0: Firmware Version: 88-13.25
[ 6.433910] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.433913] Bluetooth: BNEP filters: protocol multicast
[ 6.433917] Bluetooth: BNEP socket layer initialized
[ 6.984745] Bluetooth: hci0: Waiting for firmware download to complete
[ 6.985636] Bluetooth: hci0: Firmware loaded in 1443178 usecs
[ 6.985685] Bluetooth: hci0: Waiting for device to boot
[ 7.001599] Bluetooth: hci0: Device booted in 15573 usecs
[ 7.003763] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-0040-0041.ddc
[ 7.005635] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 7.008708] Bluetooth: hci0: Firmware timestamp 2025.13 buildtype 1 build 82008
[ 7.008712] Bluetooth: hci0: Firmware SHA1: 0x47cf9d0e
[ 7.012650] Bluetooth: hci0: Fseq status: Success (0x00)
[ 7.012652] Bluetooth: hci0: Fseq executed: 00.00.02.41
[ 7.012654] Bluetooth: hci0: Fseq BT Top: 00.00.02.41
[ 7.081756] Bluetooth: MGMT ver 1.23
[ 8.319502] Bluetooth: RFCOMM TTY layer initialized
[ 8.319515] Bluetooth: RFCOMM socket layer initialized
[ 8.319520] Bluetooth: RFCOMM ver 1.11
[ 4211.505576] Bluetooth: hci0: Opcode 0x0c1a failed: -110
[ 4211.505595] Bluetooth: hci0: Error when powering off device on rfkill (-110)
[ 4211.505593] Bluetooth: hci0: command 0x0c1a tx timeout
[ 4211.505633] Bluetooth: hci0: Initiating acpi reset method
[ 4211.505658] Bluetooth: hci0: HCI reset during shutdown failed
[ 4212.207720] Bluetooth: hci0: Device revision is 0
[ 4212.207727] Bluetooth: hci0: Secure boot is enabled
[ 4212.207729] Bluetooth: hci0: OTP lock is enabled
[ 4212.207731] Bluetooth: hci0: API lock is enabled
[ 4212.207732] Bluetooth: hci0: Debug lock is disabled
[ 4212.207733] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 4212.207736] Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
[ 4212.207839] Bluetooth: hci0: DSM reset method type: 0x00
[ 4212.211882] Bluetooth: hci0: Found device firmware: intel/ibt-0040-0041.sfi
[ 4212.211896] Bluetooth: hci0: Boot Address: 0x100800
[ 4212.211898] Bluetooth: hci0: Firmware Version: 88-13.25
[ 4213.802155] Bluetooth: hci0: Waiting for firmware download to complete
[ 4213.802847] Bluetooth: hci0: Firmware loaded in 1553685 usecs
[ 4213.803058] Bluetooth: hci0: Waiting for device to boot
[ 4213.819734] Bluetooth: hci0: Device booted in 16402 usecs
[ 4213.821861] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-0040-0041.ddc
[ 4213.823732] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 4213.826727] Bluetooth: hci0: Firmware timestamp 2025.13 buildtype 1 build 82008
[ 4213.826733] Bluetooth: hci0: Firmware SHA1: 0x47cf9d0e
[ 4213.830700] Bluetooth: hci0: Fseq status: Success (0x00)
[ 4213.830704] Bluetooth: hci0: Fseq executed: 00.00.02.41
[ 4213.830706] Bluetooth: hci0: Fseq BT Top: 00.00.02.41
[ 4213.900221] Bluetooth: MGMT ver 1.23
lsmod | grep blue
bluetooth 1155072 34 btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
rfkill 45056 8 iwlmvm,bluetooth,thinkpad_acpi,cfg80211
hi,
Do you run the System with Dual-Boot with windows? Because your inxi looks like you deleted stuff out of it like SSDs/Nvmes and the last dualboot with windows ???
My output shows this:
System install date: 2025-05-30
Last full system update: 2025-06-29
To avoid that windows is hijacking your Hardware disable fastboot on windows. I have to press SHIFT Button then Shutdown to get my BT working on Garuda. If not im not able to activate it even my WIFI same issue too. What is this command tell you rfkill list
Hard blocked?
gampel
June 29, 2025, 6:57pm
17
SGS:
Please.
Format terminal output (including your garuda-inxi
) as a code block by clicking the preformatted text button (</> ) , or put three tildes (~) above and below the text
pls post your current garuda-inxi
yes i’ve got a dual boot with windows 11
rfkill list
0: tpacpi_bluetooth_sw: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
3: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
gampel
June 30, 2025, 7:45am
20
To be on the safe side…
pls deactivate fastboot inside M$
bios: fast + secure boot off
never a warm boot from M$ to linux (reverse yes)
what is fastboot inside windows? i know fastboot from adb..
like i said, secure boot is off..fastboot off too; only dmesg says on?
i don’t understand well this phrase, i use grub at start..
but i’ve got exactly the same config in my thinkpad L14 and no problems…and the problem was before installing windows on a partition.
