On boot i get error hidden.mod not found and stystem is behaving a bit different
on booting i get the following error
ERROR:file'@/boot/grub/x86_64-efi/part_mdosGRUB_TIMEOUT_STYLE=hidden.mod' not found.
After installing Garuda I used it for few months and then i tried editing grub and ended up in grub rescue :sweat_smile:.
i somehow fixed it with loading kernel from rescue,since then i get the error while booting
i think i messed up mounting part while in grub rescue and the system experience got different
for example when i used command cd /
output:
permission denied
output :
Kernel: 6.2.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=7fc7b7c9-1156-461d-8b25-c94450f554d2 rw [email protected]
quiet splash intel_pstate=disable
Type: Convertible System: HP product: HP Pavilion x360 Convertible
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 31
Mobo: HP model: 81A9 v: 57.53 serial: <superuser required> UEFI: Insyde
v: F.40 date: 11/09/2020
ID-1: BAT0 charge: 26.8 Wh (71.5%) condition: 37.5/37.5 Wh (100.0%)
volts: 11.6 min: 11.4 model: 333-42-42 BI03041XL type: Li-ion
Info: model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3100 min/max: 400/2601 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3100 2: 3100 3: 3100
4: 3100 bogomips: 21599
Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5916
Device-2: Sunplus Innovation HP Wide Vision HD type: USB driver: uvcvideo
bus-ID: 1-8:3 chip-ID: 1bcf:2c83 class-ID: 0e02
Monitor-1: eDP-1 model: LG Display 0x052d built: 2016 res: 1920x1080
hz: 60 dpi: 166 gamma: 1.2 size: 294x165mm (11.57x6.5") diag: 337mm (13.3")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel HD Graphics 620 (KBL
GT2) direct-render: Yes
API: ALSA v: k6.2.10-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-6:2 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 223.57 GiB used: 31.59 GiB (14.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
type: SSD serial: <filter> rev: B1H5 scheme: GPT
ID-1: / raw-size: 175.41 GiB size: 175.41 GiB (100.00%)
used: 31.57 GiB (18.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 20.2 MiB (6.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 175.41 GiB size: 175.41 GiB (100.00%)
ID-4: /var/log raw-size: 175.41 GiB size: 175.41 GiB (100.00%)
ID-5: /var/tmp raw-size: 175.41 GiB size: 175.41 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.63 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 90.0 C pch: 81.0 C mobo: N/A
Processes: 220 Uptime: 33m wakeups: 1 Memory: 7.63 GiB
used: 3.61 GiB (47.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: 2950 pm: pacman pkgs: 2943
libs: 489 tools: octopi,paru pm: flatpak pkgs: 7 Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
System install date:     2023-04-12
Last full system update: 2023-04-14
Failed units:            nginx.service reflector.service
command
lsblk -a
output
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sda      8:0    0 223.6G  0 disk
├─sda1   8:1    0   300M  0 part /boot/efi
├─sda2   8:2    0 175.4G  0 part /var/log
├─sda3   8:3    0   8.8G  0 part [SWAP]
├─sda4   8:4    0  29.7G  0 part
└─sda5   8:5    0   9.3G  0 part
zram0  254:0    0   7.6G  0 disk [SWAP]
i have garuda (main os) and aarch linux i have edited grub to boot to aarch from garuda's grub and also usb menuentry to boot from USB
Try restoring a snapshot from before this happened in the advanced boot options of the Grub menu.
i booted into oldest snapshost possible but the issue wasn'nt resolved..
Please explain in as much detail as you can what you mean by this.
Use search function.
chroot, install grub, update grub.
i have chrooted with live media and reinstalled grub
i meant i had made several grub customisations and when i added a line to hide the boot process since windows logo used to pop up while booting garuda i ended up in grub rescue . i fixed it by chrooting then this error pops up whenever i boot .
i have also removed the line i added to /ec/default/grub
please tell me if any output is required i'll provide it as soon as possible
You added a line to what file?
What did the line say?
Chrooting alone doesn't fix anything. What did you do inside the chroot to fix it?
i edited grub at /etc/deafult/
it dont rember the line but it was to hide display
my current grub file i:
# GRUB boot loader configuration
GRUB_DEFAULT="0"
GRUB_TIMEOUT=2
GRUB_DISTRIBUTOR='Garuda'
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_pstate=disable"
GRUB_CMDLINE_LINUX=""
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"GRUB_TIMEOUT_STYLE=hidden
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT=2
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `videoinfo'
GRUB_GFXMODE=1920x1080,auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
#GRUB_BACKGROUND="/path/to/wallpaper"
GRUB_THEME="/usr/share/grub/themes/tela/theme.txt"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
# Probing for other operating systems is disabled for security reasons. Read
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
# functionality install os-prober and uncomment to detect and include other
# operating systems.
GRUB_DISABLE_OS_PROBER=false
# This config file imports drop-in files from /etc/default/grub.d/.
for garuda_grub_d in ${sysconfdir}/default/grub.d/*.cfg ; do if [ -e "${garuda_grub_d}" ]; then source "${garuda_grub_d}"; fi; done
You have this line in /etc/default/grub twice, once on line 6 and again on the bottom line. Go ahead and delete the one on the bottom.
It sounds like you changed other things besides this one line:
Try to be more specific. There is still a lot of missing information here.
Show what is in /etc/grub.d/ when you have a chance.
ls /etc/grub.d/
ls /etc/grub.d/
00_header     30_os-prober      40_custom           60_memtest86+
10_linux      30_uefi-firmware  41_custom           61_custom_leave_options
20_linux_xen  35_fwupd          41_snapshots-btrfs  README
40_custom is for booting to usb drive
code :
#!/bin/sh
exec tail -n +3 $0
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
menuentry "Boot from USB" {
    search --no-floppy --fs--uuid AE93-7130 --set=root
    set root=$search_fs_uuid
    chainloader +1}
Grub-Update
update-grub
Found theme: /usr/share/grub/themes/tela/theme.txt
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot:  intel-ucode.img initramfs-linux-zen-fallback.img
Found Bodhi 6.0 (20.04) on /dev/sda4
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2023-04-14 17:11:10 | @/.snapshots/447/snapshot | post | arch-install-scripts                                                     |
Found snapshot: 2023-04-14 17:11:04 | @/.snapshots/446/snapshot | pre  | pacman -S extra/arch-install-scripts                                     |
Found snapshot: 2023-04-14 13:06:11 | @/.snapshots/445/snapshot | post | stress             |
Found snapshot: 2023-04-14 13:06:08 | @/.snapshots/444/snapshot | pre  | pacman -S stress   |
Found snapshot: 2023-04-14 12:53:05 | @/.snapshots/443/snapshot | post | python-aiohttp python-terminaltables                                     |
Found snapshot: 2023-04-14 12:53:01 | @/.snapshots/442/snapshot | pre  | pacman -Su         |
Found snapshot: 2023-04-13 22:56:14 | @/.snapshots/441/snapshot | post | a2ps proton-ge-custom                                                    |
Found snapshot: 2023-04-13 22:56:01 | @/.snapshots/440/snapshot | pre  | pacman -Su         |
Found snapshot: 2023-04-13 20:16:40 | @/.snapshots/439/snapshot | post | candy-icons-git chaotic-mirrorlist gunicorn gupnp-igd lib32-openal libni |
Found snapshot: 2023-04-13 20:16:35 | @/.snapshots/438/snapshot | pre  | pacman -Syu        |
Found 10 snapshot(s)
Unmount /tmp/grub-btrfs.LVwpBzqS0F .. Success
done
kate /etc/fstab
UUID=4E15-2982                            /boot/efi      vfat    defaults,noatime 0 2
UUID=7fc7b7c9-1156-461d-8b25-c94450f554d2 /              btrfs   subvol=/@,defaults,noatime,compress=zstd 0 0
UUID=7fc7b7c9-1156-461d-8b25-c94450f554d2 /home          btrfs   subvol=/@home,defaults,noatime,compress=zstd 0 0
UUID=7fc7b7c9-1156-461d-8b25-c94450f554d2 /root          btrfs   subvol=/@root,defaults,noatime,compress=zstd 0 0
UUID=7fc7b7c9-1156-461d-8b25-c94450f554d2 /srv           btrfs   subvol=/@srv,defaults,noatime,compress=zstd 0 0
UUID=7fc7b7c9-1156-461d-8b25-c94450f554d2 /var/cache     btrfs   subvol=/@cache,defaults,noatime,compress=zstd 0 0
UUID=7fc7b7c9-1156-461d-8b25-c94450f554d2 /var/log       btrfs   subvol=/@log,defaults,noatime,compress=zstd 0 0
UUID=7fc7b7c9-1156-461d-8b25-c94450f554d2 /var/tmp       btrfs   subvol=/@tmp,defaults,noatime,compress=zstd 0 0
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
UUID=97df0fc2-f84d-41c5-97b4-a62dd0a3a08b none swap defaults 0 0
df :
Filesystem     1K-blocks     Used Available Use% Mounted on
devtmpfs            4096        0      4096   0% /dev
tmpfs            4002476   117468   3885008   3% /dev/shm
tmpfs            1600992     1600   1599392   1% /run
/dev/sda2      183931904 33150756 148669228  19% /
/dev/sda2      183931904 33150756 148669228  19% /home
/dev/sda2      183931904 33150756 148669228  19% /root
/dev/sda2      183931904 33150756 148669228  19% /srvFilesystem     1K-blocks     Used Available Use% Mounted on
tmpfs            4002476     2980   3999496   1% /tmp
/dev/sda2      183931904 33150756 148669228  19% /var/cache
/dev/sda2      183931904 33150756 148669228  19% /var/tmp
/dev/sda2      183931904 33150756 148669228  19% /var/log
/dev/sda1         306572    20728    285844   7% /boot/efi
tmpfs             800492       72    800420   1% /run/user/1000
This looks good actually. Did you reinstall Grub first?
Something like this:
grub-install --target=x86_64-efi --efi-directory=*esp* --bootloader-id=GRUB
Or see what options you may need here: GRUB - ArchWiki
Then update Grub again, exit the chroot and reboot to test again.
You have these two statements on one line, but I think grub expects only one per line.
