garuda-inxi:
Kernel: 5.16.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=7d76c00e-7358-4f00-a876-1486077522a6 rw rootflags=subvol=@
cgroup_enable=memory swapaccount=1 quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 cgroup_enable=memory swapaccount=1
systemd.unified_cgroup_hierarchy=0 loglevel=3
Type: Desktop Mobo: Micro-Star model: B450M PRO-M2 MAX (MS-7B84) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.70
date: 06/10/2020
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3734 high: 4327 min/max: 2200/4559 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3854 2: 3438
3: 3479 4: 3479 5: 3470 6: 3599 7: 3599 8: 3598 9: 4327 10: 4277 11: 4288
12: 3996 13: 3425 14: 3562 15: 3614 16: 3746 bogomips: 124801
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA TU117 [GeForce GTX 1650] driver: nvidia v: 510.54
alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 29:00.0 chip-ID: 10de:1f82 class-ID: 0300
Device-2: Sunplus Innovation FULL HD webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-1:2 chip-ID: 1bcf:2283
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 4920x2280 s-dpi: 156 s-size: 801x371mm (31.5x14.6")
s-diag: 883mm (34.8")
Monitor-1: DP-0 pos: primary,top-right res: 3840x2160 hz: 60 dpi: 161
size: 607x345mm (23.9x13.6") diag: 698mm (27.5")
Monitor-2: DP-2 pos: bottom-l res: 1080x1920 hz: 60 dpi: 96
size: 286x509mm (11.3x20.0") diag: 584mm (23")
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 29:00.1 chip-ID: 10de:10fa class-ID: 0403
bus-ID: 2b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Sunplus Innovation FULL HD webcam type: USB
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 100 Mbps duplex: full mac: <filter>
bus-ID: 1-3:4 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Local Storage: total: 5.46 TiB used: 221.73 GiB (4.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S5Z42105
temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM004-2CV104
type: HDD rpm: 5425 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
used: 95.91 GiB (54.6%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 26.7 MiB (27.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
used: 125.79 GiB (46.0%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
ID-5: /var/tmp raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
ID-1: swap-1 type: partition size: 15.82 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.36 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.0 C mobo: N/A gpu: nvidia temp: 44 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1737 fan-3: 0 fan-4: 0 fan-5: 0
gpu: nvidia fan: 30%
Processes: 482 Uptime: 7m wakeups: 0 Memory: 31.36 GiB
used: 6.7 GiB (21.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 2650 lib: 577 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2021-10-25
Last full system update: 2022-03-23 ↻
Failed units: fancontrol.service memavaild.service systemd-oomd.socket
I am trying to get the text to speech engine plugin on Okular working. I want it to read me PDFs! I have installed all the requirements, but I just can't get it to work! I am about to pull my hairs out ![]()
What I know:
- Speech-dispatcher sound driver, the sound driver shows up under applications on the KDE audio settings, meaning that pipewire can see it. Maybe some part of the audio driver isn't working (?), nevertheless it is at least detected
- Speech-dispatcher service, I noticed that speech-dispatcher thanks to Okular complained that it couldn't find it, after installing speech-dispatcher it stopped complaining. I know that the service is running:
╰─λ ps aux | grep speech-dispatcher
can 31738 0.0 0.0 100104 8468 pts/3 S<l+ 11:37 0:00 /usr/lib/speech-dispatcher/speech-dispatche
r-modules/sd_espeak-ng-mbrola /etc/speech-dispatcher/modules/espeak-ng-mbrola.conf
can 31741 0.0 0.0 101168 9348 pts/3 S<l+ 11:37 0:00 /usr/lib/speech-dispatcher/speech-dispatche
r-modules/sd_espeak-ng /etc/speech-dispatcher/modules/espeak-ng.conf
can 31744 0.0 0.0 21824 5736 pts/3 S<l+ 11:37 0:00 /usr/lib/speech-dispatcher/speech-dispatche
r-modules/sd_dummy /etc/speech-dispatcher/modules/dummy.conf
can 31746 0.0 0.0 111940 5096 ? S<sl 11:37 0:00 /usr/bin/speech-dispatcher --spawn --commun
ication-method unix_socket --socket-path /run/user/1000/speech-dispatcher/speechd.sock
can 45407 0.0 0.0 6672 2444 pts/1 S<+ 11:44 0:00 grep --color=auto speech-dispatcher
speech-dispatcher itself also says it is running without any errors:
╰─λ speech-dispatcher -D
[Wed Mar 23 11:45:19 2022 : 767430] speechd: Speech Dispatcher 0.11.1 starting
[Wed Mar 23 11:45:19 2022 : 767478] speechd: Speech Dispatcher already running.
- tts engine works also:
spd-say Hello!produces sound. - I think that the problem is on the
Okularside, but it cannot be since this feature has been around for a very long time; it shouldn't break now...
Meaning I am stuck in a rationelle loop, any input to get me out will be met with open arms ![]()
Uninsightful, but here is the Okular terminal output after attempting to start tts by pressing "Speak whole document" under "Tools" on the toolbar:
[🧱] × okular
Icon theme "adwaita" not found.
Icon theme "ubuntu-mono" not found.
Icon theme "yaru" not found.
Icon theme "Mint-X" not found.
Icon theme "elementary" not found.
