This is a very minor issue and I only noticed it because I got a new mini PC. It’s possible it could also just be my hardware… ^^;
Sorry if this is the wrong section btw - feel free to move it if it’s not correct.
I’m trying to install Qtile, and during the installation process, I noticed that the background on one of the screens (windows?) was completely transparent, making the text quite hard to read in some areas.
Is it possible that Picom is the issue here, as there’s no blur in any transparent windows? I remember back on my XPS 15 when I originally installed Qtile on it, it came with a version of Picom that no longer exists in the AUR. picom-libvaughan-git
or something like that.
I think since the rest of the installer has an opaque background though, it should be left opaque all the way through…
I tried on both the open source and proprietary NVIDIA drivers, but that obviously had no effect because there’s no NVIDIA in this PC (yet) - I’m gonna chuck an RTX 4060 eGPU on it once I get the adapter and PSU.
The ISO this happened on is garuda-qtile-linux-zen-231029.iso.
from live ISO:
misobasedir=garuda root=miso:LABEL=GARUDA_QTILE_RAPTOR quiet
systemd.show_status=1 ibt=off systemd.unified_cgroup_hierarchy=1
driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Desktop: Qtile v: 0.23.0 wm: LG3D vt: 2 dm: SDDM Distro: Garuda Linux
Type: Mini-pc System: Micro (HK) Tech product: Venus series v: N/A
Mobo: Shenzhen Meigao Equipment model: F7BSC serial: <superuser required>
UEFI: American Megatrends LLC. v: 1.07 date: 09/01/2023
Info: model: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics bits: 64
type: MT MCP arch: Zen 4 gen: 5 level: v4 note: check built: 2022+
microcode: 0xA704103
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 469 high: 1505
min/max: 400/5263:6228:5583:5743:5423:5903:6067 scaling:
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 400 15: 1505 16: 400 bogomips: 127747
Device-1: AMD Phoenix1 driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix
process: TSMC n4 (4nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7,
HDMI-A-2 bus-ID: c4:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 36.0 C
Display: x11 server: X.Org v: 21.1.9 compositor: Picom v: git-b700a
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 777mm (30.58")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Dell P2423D serial: <filter>
built: 2023 res: 2560x1440 hz: 60 dpi: 123 gamma: 1.2
max: 2560x1440 min: 720x400
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV GFX1103_R1) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:15bf surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: c4:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_ps
v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: c4:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: c4:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.5.9-zen2-1-zen status: kernel-api
speed: 5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:8125
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz vendor: Rivet Networks
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 8086:2725 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:6 chip-ID: 8087:0032
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.04 TiB used: 3.4 GiB (0.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PGP41024Q-A0
lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK0S.6 temp: 33.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: Ultra USB 3.0
size: 114.56 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: GPT
ID-1: swap-1 type: zram size: 60.54 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 39.5 C mobo: N/A gpu: amdgpu temp: 37.0 C
Processes: 370 Uptime: 14m wakeups: 2 Memory: total: 60 GiB note: est.
available: 60.54 GiB used: 3.56 GiB (5.9%) Init: systemd v: 254
pm: pacman pkgs: 1144 libs: 345 tools: paru Shell: fish v: 3.6.1
running-in: alacritty inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2024-01-05
Last full system update: 2024-01-05 ↻
