Odd issue with updates
I'm running the Dragonized Plasma latest ISO and get told when updating from the Terminal "error: failed to retrieve file" for files that it looks like just above those error messages were actually downloaded. I also noticed that in Acro I had an update for Sonarr and when I just did the updates for Garuda I wasn't offered the Sonarr update. Are there update issues that need addressing?
╭─jigsaw@NSAFieldStation in ~ took 15s
╰─λ topgrade
―― 03:07:55 - System update ――――――――――――――――――――――――――――――――――――――――――――――――――――
[sudo] password for jigsaw:
core                                  134.5 KiB   558 KiB/s 00:00 [------------------------------------] 100%
extra                                1566.8 KiB  4.41 MiB/s 00:00 [------------------------------------] 100%
community                               5.6 MiB  9.98 MiB/s 00:01 [------------------------------------] 100%
multilib is up to date
chaotic-aur                          1095.6 KiB   994 KiB/s 00:01 [------------------------------------] 100%
warning: topgrade: local (7.0.1-1) is newer than chaotic-aur (6.9.1-1)
warning: whoogle: local (0.5.4-1) is newer than chaotic-aur (0.5.3-1)
resolving dependencies...
Packages (6) hdparm-9.62-1  memtest86+-5.31b-1  openmpi-4.1.1-2  paru-1.7.2-1  python-docutils-0.17-1
python-pip-20.3.1-2
Total Download Size:    7.13 MiB
Total Installed Size:  23.29 MiB
Net Upgrade Size:       0.14 MiB
:: Retrieving packages...
*memtest86+-5.31b-1-any                 55.0 KiB   219 KiB/s 00:00 [------------------------------------] 100%*
*hdparm-9.62-1-x86_64                   85.1 KiB   322 KiB/s 00:00 [------------------------------------] 100%*
*python-docutils-0.17-1-any            745.1 KiB  1872 KiB/s 00:00 [------------------------------------] 100%*
*openmpi-4.1.1-2-x86_64                  3.3 MiB  7.41 MiB/s 00:00 [------------------------------------] 100%*
*python-pip-20.3.1-2-any               417.3 KiB  3.02 MiB/s 00:00 [------------------------------------] 100%*
*paru-1.7.2-1-x86_64                     2.6 MiB  3.16 MiB/s 00:01 [------------------------------------] 100%*
*Total (6/6)                             7.1 MiB  8.07 MiB/s 00:01 [------------------------------------] 100%*
*error: failed retrieving file 'python-docutils-0.17-1-any.pkg.tar.zst' from archmirror1.octyl.net : HTTP/2 stream 17 was not closed cleanly before end of the underlying stream*
*error: failed retrieving file 'hdparm-9.62-1-x86_64.pkg.tar.zst' from archmirror1.octyl.net : HTTP/2 stream 11was not closed cleanly before end of the underlying stream*
*error: failed retrieving file 'memtest86+-5.31b-1-any.pkg.tar.zst' from archmirror1.octyl.net : HTTP/2 stream 13 was not closed cleanly before end of the underlying stream*
*warning: too many errors from archmirror1.octyl.net, skipping for the remainder of this transaction*
*error: failed retrieving file 'openmpi-4.1.1-2-x86_64.pkg.tar.zst' from archmirror1.octyl.net : HTTP/2 stream 15 was not closed cleanly before end of the underlying stream*
(6/6) checking keys in keyring                                     [------------------------------------] 100%
(6/6) checking package integrity                                   [------------------------------------] 100%
(6/6) loading package files                                        [------------------------------------] 100%
(6/6) checking for file conflicts                                  [------------------------------------] 100%
(6/6) checking available disk space                                [------------------------------------] 100%
(1/1) Creating Timeshift snapshot before upgrade...
Using system disk as snapshot device for creating snapshots in BTRFS mode
/dev/nvme0n1p2 is mounted at: /run/timeshift/backup, options: rw,relatime,compress=zstd:3,ssd,space_cache,autodefrag,subvolid=5,subvol=/
Creating new backup...(BTRFS)
Saving to device: /dev/nvme0n1p2, mounted at path: /run/timeshift/backup
Created directory: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-06-12_03-08-35
Created subvolume snapshot: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-06-12_03-08-35/@
Created control file: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-06-12_03-08-35/info.json
BTRFS Snapshot saved successfully (0s)
Tagged snapshot '2021-06-12_03-08-35': ondemand
Removing snapshot: 2021-06-11_07-42-23
Deleting subvolume: @ (Id:299)
Deleted subvolume: @ (Id:299)
Destroying qgroup: 0/299
Destroyed qgroup: 0/299
Deleted directory: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-06-11_07-42-23
Removed snapshot: 2021-06-11_07-42-23
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: initramfs-linux-zen-fallback.img
Found ArcoLinux on /dev/nvme1n1p2
Detecting snapshots ...
Info: Separate boot partition not detected
Found snapshot: 2021-06-12 03:08:35 | timeshift-btrfs/snapshots/2021-06-12_03-08-35/@
Found snapshot: 2021-06-12 02:43:26 | timeshift-btrfs/snapshots/2021-06-12_02-43-26/@
Found snapshot: 2021-06-11 17:17:47 | timeshift-btrfs/snapshots/2021-06-11_17-17-47/@
Found snapshot: 2021-06-11 15:52:56 | timeshift-btrfs/snapshots/2021-06-11_15-52-56/@
Found snapshot: 2021-06-11 13:26:24 | timeshift-btrfs/snapshots/2021-06-11_13-26-24/@
Found snapshot: 2021-06-11 11:53:35 | timeshift-btrfs/snapshots/2021-06-11_11-53-35/@
Found snapshot: 2021-06-11 08:56:54 | timeshift-btrfs/snapshots/2021-06-11_08-56-54/@
Found snapshot: 2021-06-11 06:00:07 | timeshift-btrfs/snapshots/2021-06-11_06-00-07/@
Found 8 snapshot(s)
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
(1/6) upgrading hdparm                                             [------------------------------------] 100%
(2/6) upgrading memtest86+                                         [------------------------------------] 100%
(3/6) upgrading openmpi                                            [------------------------------------] 100%
(4/6) upgrading paru                                               [------------------------------------] 100%
warning: /etc/paru.conf installed as /etc/paru.conf.pacnew
(5/6) upgrading python-docutils                                    [------------------------------------] 100%
(6/6) upgrading python-pip                                         [------------------------------------] 100%
(1/8) Syncing all file systems...
(2/8) Arming ConditionNeedsUpdate...
*(3/8) Foreign/AUR package notification*
angrysearch 1.0.2-1
cpu-x 4.2.0-1
freefilesync-bin 11.10-1
i-nex 7.6.1-5
jackett 0.18.283-1
komga 0.99.0-1
lib32-libnm-glib 1.18.5dev+12+ga8746f48ca-1
libcpuid 0.5.1-1
pamac-tray-icon-plasma 0.1.3-1
python2-twodict-git 1.2.r2.g925d3bd-1
radarr-develop 3.2.2.5080-1
snapd 2.51-1
snapd-glib 1.59-1
sonarr-develop 3.0.6.1263-1
vivaldi-snapshot 4.0.2312.17-1
youtube-dl-gui-git 0.4.r81.gc5c18e5-1
(4/8) Orphaned package notification...
asciidoc 9.1.0-1
dotnet-sdk 5.0.7.sdk204-1
doxygen 1.9.1-1
gambas3-devel 3.15.2-11
go 2:1.16.5-1
go-tools 4:0.1.2-1
itstool 1:2.0.6-2
kfiredragonhelper 5.0.6-1
lib32-dconf 0.40.0-1
lib32-libgusb 0.3.7-1
lib32-polkit 0.119-1
meson 0.58.1-1
nasm 2.15.05-1
python-docutils 0.17-1
qt4 4.8.7-33
snapd-glib 1.59-1
vala 0.52.4-1
(5/8) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/pamac.conf.pacnew
/etc/pacman.conf.pacnew
/etc/systemd/system.conf.pacnew
/etc/systemd/user.conf.pacnew
Please check and merge
(6/8) Updating pkgfile database...
(7/8) Checking which packages need to be rebuilt
(8/8) Syncing all file systems...
:: Searching databases for updates...
:: Searching AUR for updates...
-> topgrade: local (7.0.1-1) is newer than chaotic-aur (6.9.1-1)
-> whoogle: local (0.5.4-1) is newer than chaotic-aur (0.5.3-1)
:: Checking development packages...
-> Missing AUR Packages:  lib32-libnm-glib  libnm-glib
there is nothing to do
―― 03:08:56 - pip3 ―――――――――――――――――――――――――――――――――――――――――――――――――――――――――――――
Requirement already satisfied: pip in ./.local/lib/python3.9/site-packages (21.1.2)
―― 03:08:56 - micro ――――――――――――――――――――――――――――――――――――――――――――――――――――――――――――
Checking for plugin updates
Nothing to install / update
―― 03:08:57 - Flatpak User Packages ――――――――――――――――――――――――――――――――――――――――――――
Looking for updates…
Nothing to do.
Nothing to do.
―― 03:08:57 - snap ―――――――――――――――――――――――――――――――――――――――――――――――――――――――――――――
All snaps up to date.
―― 03:08:58 - Firmware upgrades ――――――――――――――――――――――――――――――――――――――――――――――――
Firmware metadata last refresh: 18 hours ago. Use --force to refresh again.
Devices with no available firmware updates:
• USB3.0 Hub
• UEFI dbx
• USB2.0 Hub
Devices with the latest available firmware version:
• Unifying Receiver
• Unifying Receiver
―― 03:09:00 - Summary ――――――――――――――――――――――――――――――――――――――――――――――――――――――――――
System update: OK
pip3: OK
micro: OK
Flatpak: OK
snap: OK
Firmware upgrades: OK
Pacman backup configuration files found:
╭─jigsaw@NSAFieldStation in ~ took 1m4s
╰─λ udp
fish: Unknown command: udp
╭─jigsaw@NSAFieldStation in ~ took 257ms
[🔍] × upd
File: /etc/pacman.d/mirrorlist
################# Arch Linux mirrorlist generated by Reflector #################
# With:       reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirro
rlist
# When:       2021-06-12 10:18:34 UTC
# From:       https://www.archlinux.org/mirrors/status/json/
# Retrieved:  2021-06-12 10:18:17 UTC
# Last Check: 2021-06-12 09:17:18 UTC
Server = https://mirror.pkgbuild.com/$repo/os/$arch
Server = https://mirror.telepoint.bg/archlinux/$repo/os/$arch
Server = https://mirror.pseudoform.org/$repo/os/$arch
Server = https://mirror.easylee.nl/archlinux/$repo/os/$arch
Server = https://archlinux.thaller.ws/$repo/os/$arch
core is up to date
extra is up to date
community is up to date
chaotic-aur                          1089.4 KiB   222 KiB/s 00:05 [------------------------------------] 100%
Parsing man pages and writing completions to /home/jigsaw/.local/share/fish/generated_completions/
9416 / 9416 : zramctl.8.gz
This looks like an issue with the mirror.
Remove that mirror from /etc/pacman.d/mirrorlist, or refresh the list.
You already did that at the end of your log, so now the same problem won’t reoccur.
Thanks mirrors are now updated. What abut like Sonarr and others being listed below the "foreign package notifications", and at least Sonarr not updating in Garuda when it just did in Acro using the same update tools?
Where did you install this package from?
I assume it’s sonarr-develop which is listed as version 3.0.6.1263-1 on the AUR package page, so which version do you currently have installed?
If you’re updating AUR packages, what’s the output of yay -Syu or paru- Syu ?
Yes it's Sonarr-develop 3.0.6.1263-1, installed through Pamac. Looks like I got the update in Garuda before getting it this morning in Acro, so actually good there.
╰─λ yay -Syu
core is up to date
extra is up to date
chaotic-aur is up to date
