If you are on Dragonized or any other editions and use Octopi, and found that it broke, you should update again from a terminal:
sudo pacman -Syu
Octopi has been rebuilt and will work again.
9-23-24 Update:
Octopi does not appear to be in the Garuda or pacman repositories any longer
sudo pacman -Syu octopi
[sudo] password for mike:
Synchronizing package databases…
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
error: target not found: octopi
