Octopi and garuda-settings-manager does not worked after update
Hi. I update system today. After that octopi and garuda-settings-manager does not worked anymore. I got the following errors:
octopi: error while loading shared libraries: libqtermwidget5.so.1: cannot open shared object file: No such file or directory
garuda-settings-manager: error while loading shared libraries: libicuuc.so.74: cannot open shared object file:No such file or directory
My garuda-inxi
Kernel: 6.9.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=bfc36042-8f8e-4781-beaa-4e24b4c8225c rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop System: Micro-Star product: MS-7E27 v: 1.0
Mobo: Micro-Star model: PRO B650M-P (MS-7E27) v: 1.0
Megatrends LLC. v: 1.50 date: 12/15/2023
Mouse serial: <filter> charge: 50% (should be ignored) rechargeable: yes
Info: model: AMD Ryzen 5 7600 bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3143 high: 4249 min/max: 400/5170 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3889 2: 4247 3: 4249
4: 4024 5: 4154 6: 400 7: 4020 8: 4209 9: 400 10: 3893 11: 3838 12: 400
bogomips: 91195
Device-1: NVIDIA AD104 [GeForce RTX 4070 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2783 class-ID: 0300
Device-2: AMD Raphael vendor: Micro-Star MSI driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4, DP-5,
DP-6, HDMI-A-2, Writeback-1 bus-ID: 10:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 38.0 C
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x292mm (20.87x11.50")
s-diag: 605mm (23.82")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: V24FAB-RA
serial: <filter> built: 2022 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x293mm (20.75x11.54") diag: 603mm (23.7") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070
SUPER/PCIe/SSE2 memory: 11.71 GiB
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 SUPER driver: nvidia v: 550.78 device-ID: 10de:2783
surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv v: 24.0.7-arch1.3
device-ID: 1002:164e surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.7-arch1.3 (LLVM
Device-1: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bc
Device-2: AMD Rembrandt Radeon High Definition Audio
speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 10:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.9.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0c:00.0
IF: enp12s0 state: down mac: <filter>
IF-ID-1: enp14s0u3 state: unknown speed: -1 duplex: half mac: <filter>
Local Storage: total: 953.87 GiB used: 189 GiB (19.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: XPG GAMMIX S11 Pro size: 953.87 GiB block-size: physical: 512 B
fw-rev: 42BFU6MI temp: 36.9 C scheme: GPT
ID-1: / raw-size: 237.98 GiB size: 237.98 GiB (100.00%)
used: 188.63 GiB (79.3%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot raw-size: 500 MiB size: 500 MiB (100.00%)
used: 345.5 MiB (69.1%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%)
used: 34 MiB (35.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /home raw-size: 237.98 GiB size: 237.98 GiB (100.00%)
ID-5: /var/log raw-size: 237.98 GiB size: 237.98 GiB (100.00%)
ID-6: /var/tmp raw-size: 237.98 GiB size: 237.98 GiB (100.00%)
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
ID-2: swap-2 type: zram size: 14.81 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.1 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 39 C fan: 0% device: amdgpu
temp: 38.0 C
Memory: total: 16 GiB note: est. available: 14.81 GiB used: 3.4 GiB (23.0%)
Processes: 383 Power: uptime: 14m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.88 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1946 libs: 575 tools: octopi,pamac,paru
Compilers: clang: 17.0.6 gcc: 14.1.1 alt: 13 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date:     2024-05-11
Last full system update: 2024-05-20
Failed units:            nmb.service
Please search next time before just opening a new thread (one of your issues is a post right next to yours even)
