Hey guys! TIll now i am imprerss by garuda linux i still am but there is a wierd bug which makes all windows freeze my cursours keep moving ut every window freezes the keyboard's caps etc keys also turn on normally when pressed if the pc is freeezed
System: Kernel: 5.12.11-168-tkg-bmq x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5406c160-0b2d-4bc1-8be7-96508b47db1c rw rootflags=subvol=@ splash quiet
rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3
Desktop: KDE Plasma 5.22.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: LENOVO product: 80TJ v: Lenovo ideapad 110-15ACL serial: <filter> Chassis:
type: 10 v: Lenovo ideapad 110-15ACL serial: <filter>
Mobo: LENOVO model: Nano 5A8 v: SDK0J40679 WIN serial: <filter> UEFI: Lenovo v: 1QCN32WW
date: 08/18/2016
Battery: ID-1: BATT charge: 1.9 Wh (32.2%) condition: 5.9/23.8 Wh (25.0%) volts: 11.7 min: 10.8
model: LENOVO LCFC type: Unknown serial: <filter> status: Charging
CPU: Info: Quad Core model: AMD A8-7410 APU with AMD Radeon R5 Graphics bits: 64 type: MCP
arch: Puma family: 16 (22) model-id: 30 (48) stepping: 1 microcode: 7030105 cache: L2: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 17587
Speed: 2340 MHz min/max: 1000/2200 MHz boost: enabled Core speeds (MHz): 1: 2340 2: 2321
3: 2327 4: 2302
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Lenovo driver: radeon v: kernel
alternate: amdgpu bus-ID: 00:01.0 chip-ID: 1002:9851 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile]
vendor: Lenovo driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0 chip-ID: 1002:6660
class-ID: 0380
Device-3: IMC Networks EasyCamera type: USB driver: uvcvideo bus-ID: 2-1.2:4 chip-ID: 13d3:a745
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: ati,radeon
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.12.11-168-tkg-bmq LLVM 12.0.0) v: 4.5 Mesa 21.1.2
direct render: Yes
Audio: Device-1: AMD Kabini HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:14.2
chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.12.11-168-tkg-bmq running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
Network: Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lenovo
driver: ath10k_pci v: kernel port: 2000 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo driver: r8169 v: kernel
port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 2-1.1:3 chip-ID: 0cf3:e360
Drives: Local Storage: total: 223.58 GiB used: 39.91 GiB (17.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS240G2G0A-00JH30 size: 223.58 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: 0000 scheme: GPT
Partition: ID-1: / raw-size: 74.98 GiB size: 74.98 GiB (100.00%) used: 39.88 GiB (53.2%) fs: btrfs
dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 36.2 MiB (7.1%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 74.98 GiB size: 74.98 GiB (100.00%) used: 39.88 GiB (53.2%) fs: btrfs
ID-4: /var/log raw-size: 74.98 GiB size: 74.98 GiB (100.00%) used: 39.88 GiB (53.2%) fs: btrfs
ID-5: /var/tmp raw-size: 74.98 GiB size: 74.98 GiB (100.00%) used: 39.88 GiB (53.2%) fs: btrfs
ID-1: swap-1 type: zram size: 1.67 GiB used: 19.8 MiB (1.2%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.67 GiB used: 19.8 MiB (1.2%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.67 GiB used: 19.8 MiB (1.2%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.67 GiB used: 19.8 MiB (1.2%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 70.9 C mobo: N/A
GPU: device: radeon temp: 71.0 C device: radeon temp: 50.0 C
Info: Processes: 253 Uptime: 26m wakeups: 1 Memory: 6.69 GiB used: 4.43 GiB (66.2%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1400 lib: 346
Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
Output of my inxi, This is getting really frustrating now
