Hi there, I’ve been scouring all night to see if anyone has had this same issue, but nobody in my search seems to have brought up my particular issue so I thought I’d try asking here.
My problem here is whenever trying to window capture games in OBS on Wayland, these games would essentially just freeze and lock up and end up being unplayable. However this only seems to affect games being played via WINE/Proton, games with native Linux versions are seemingly unaffected by this problem. This seems to be a fairly recent occurrence as I’ve personally not experienced this until earlier this month.
However, this problem is completely negated via screen capture and choosing my monitor as the display. Games seem to work perfectly fine that way regardless whether they are native Linux versions or played via WINE/Proton.
To be completely honest, I’m really not sure how I can even report this issue or which project to bring this issue to light with. I’m not sure if it’s an OBS issue, a WINE issue or a Wayland issue and I’ve yet to find a permanent fix as I much prefer capturing games via window capture. Has anyone else experienced this problem and which project would be best to report this problem to?
Steps to reproduce:
- Log in to a Wayland session
- Open OBS Studio
- Add Screen Capture (select windows tab)
- Open WINE/Proton game
- Select game window in Screen Capture (optional, so long as the game window is selectable and Screen Capture remains opened on the windows tab)
- Watch as the game proceeds to freeze and lock up
Kernel: 6.11.8-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=c87e17cf-c2aa-4cb7-9b3f-535b1b50e245 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop System: Tactus product: Custom v: N/A
Mobo: ASUSTeK model: ROG STRIX X570-E GAMING WIFI II v: Rev X.0x
UEFI: American Megatrends v: 5003 date: 10/07/2023
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3901 min/max: 550/5219 boost: disabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3901 2: 3901 3: 3901
4: 3901 5: 3901 6: 3901 7: 3901 8: 3901 9: 3901 10: 3901 11: 3901 12: 3901
13: 3901 14: 3901 15: 3901 16: 3901 17: 3901 18: 3901 19: 3901 20: 3901
21: 3901 22: 3901 23: 3901 24: 3901 bogomips: 187200
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT
/ 6900 XT] vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1, HDMI-A-1,
HDMI-A-2, Writeback-1 bus-ID: 0c:00.0 chip-ID: 1002:73bf class-ID: 0300
compositor: kwin_wayland driver: X: loaded: amdgpu dri: radeonsi gpu: amdgpu
display-ID: 0
Monitor-1: DP-2 res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 XT (radeonsi
navi21 LLVM 18.1.8 DRM 3.59 6.11.8-zen1-2-zen) device-ID: 1002:73bf
API: Vulkan v: 1.3.295 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 XT (RADV NAVI21) driver: mesa radv v: 24.2.7-arch1.1
device-ID: 1002:73bf surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.2.7-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
bus-ID: 0c:00.1 chip-ID: 1002:ab28 class-ID: 0403
lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Creative Pebble V3 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
chip-ID: 041e:3272 class-ID: 0300 serial: <filter>
Device-4: RODE Microphones NT-USB driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4
chip-ID: 19f7:0003 class-ID: 0300
API: ALSA v: k6.11.8-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:0608
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-4: ASUSTek ROG KERIS WIRELESS driver: hid-generic,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.1:5
chip-ID: 0b05:195e class-ID: 0300
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:7 chip-ID: 0e8d:0608
Local Storage: total: 8.2 TiB used: 5.81 TiB (70.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: FireCuda 530
ZP1000GM30013 size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: SU6SM001
temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
tech: SSD serial: <filter> fw-rev: 2B6Q
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST4000NE001-2MA101
tech: HDD rpm: 7200 serial: <filter> fw-rev: EN01
ID-5: /dev/sdd maj-min: 8:48 vendor: SanDisk model: USB 3.2Gen1
size: 14.34 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00
used: 820.03 GiB (88.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.7 GiB used: 4.87 GiB (7.8%) priority: 100
System Temperatures: cpu: 45.0 C mobo: 37.0 C gpu: amdgpu temp: 58.0 C
mem: 56.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 931
Memory: total: 64 GiB note: est. available: 62.7 GiB used: 23.45 GiB (37.4%)
Processes: 559 Power: uptime: 4d 1h 8m states: freeze,mem,disk
reboot, suspend, test_resume image: 25.06 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 256
Packages: 1779 pm: pacman pkgs: 1744 libs: 478 tools: paru,yay pm: flatpak
pkgs: 35 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: Bash v: 5.2.37 running-in: gnome-terminal inxi: 3.3.36
System install date: 2023-06-21
Last full system update: 2024-11-22 ↻
