Hello! I have been using OBS Studio for months, but it seems suddenly it stopped working. I searched for similar problems on Google and here at this forum, but it is still not clear for me what I could do to fix my situation. I would appreciate any input on this.
It seems I’m using the version 30.1.2-1
╰─λ obs
debug: Found portal inhibitor
debug: Attempted path: share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: share/obs/obs-studio/themes
debug: Attempted path: /usr/share/obs/obs-studio/themes
debug: Attempted path: share/obs/obs-studio/themes/Yami.qss
debug: Attempted path: /usr/share/obs/obs-studio/themes/Yami.qss
warning: [Safe Mode] Unclean shutdown detected!
warning: [Safe Mode] User elected to launch normally.
info: Using EGL/X11
info: CPU Name: 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz
info: CPU Speed: 3032.633MHz
info: Physical Cores: 8, Logical Cores: 16
info: Physical Memory: 64045MB Total, 7066MB Free
info: Kernel Version: Linux 6.8.9-zen1-2-zen
info: Distribution: "Garuda Linux" Unknown
info: Desktop Environment: KDE (KDE)
info: Session Type: x11
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
info: Qt Version: 6.7.0 (runtime), 6.7.0 (compiled)
info: Portable mode: false
info: OBS 30.1.2-1 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 48000
speakers: 2
max buffering: 960 milliseconds
buffering type: dynamically increasing
info: Initializing OpenGL...
info: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2
info: OpenGL loaded successfully, version 3.3.0 NVIDIA 550.78, shading language 3.30 NVIDIA via Cg compiler
info: video settings reset:
base resolution: 1920x1080
output resolution: 1920x1080
downscale filter: Bicubic
fps: 60/1
format: NV12
YUV mode: Rec. 709/Partial
info: NV12 texture support enabled
info: P010 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
libDeckLinkAPI.so: não é possível abrir arquivo compartilhado: Arquivo ou diretório inexistente
warning: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
warning: Failed to initialize module 'decklink.so'
info: [pipewire] No captures available
info: NVENC supported
info: VAAPI: API version 1.21
info: FFmpeg VAAPI H264 encoding supported
fish: Tarefa 1, 'obs' encerrada pelo sinal SIGSEGV (Erro de fronteira de endereço (Falha de segmentação))
I tried also installing sudo pacman -S obs-studio-stable
to give a try. But got this:
╰─λ obs
obs: error while loading shared libraries: libpython3.11.so.1.0: cannot open shared object file: No such file or directory
I think it has something to do with my NVIDIA drivers. When I switch to “integrated” at Optimus Manager QT, OBS Studio works. I never had this issue before so I’m wondering what could have happened.
╰─λ garuda-inxi
Kernel: 6.8.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=1841fbdb-0a5a-497a-86d3-67c2ef2f6c76 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: Avell High Performance product: A65 MOB v: Standard
Mobo: Avell High Performance model: Avell A65 MOB v: Standard
serial: <superuser required> part-nu: A65 MOB uuid: <superuser required>
UEFI: American Megatrends LLC. v: N.1.07AVE00 date: 07/23/2021
ID-1: BAT0 charge: 67.1 Wh (94.9%) condition: 70.7/93.5 Wh (75.6%)
volts: 12.1 min: 11.4 model: standard type: Li-ion serial: <filter>
status: not charging
ID-2: hidpp_battery_1 charge: 96% condition: N/A volts: 4.1 min: N/A
model: Logitech G703 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: N/A
ID-3: hidpp_battery_2 charge: 96% condition: N/A volts: 4.1 min: N/A
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
microcode: 0x50
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 999 high: 1989 min/max: 800/4600 scaling:
driver: intel_pstate governor: performance cores: 1: 1988 2: 800 3: 800
4: 1213 5: 876 6: 800 7: 800 8: 800 9: 800 10: 800 11: 1124 12: 800
13: 800 14: 801 15: 800 16: 1989 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Tongfang Hongkong
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: DP-1 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Tongfang Hongkong driver: nvidia v: 550.78
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: HDMI-A-1 empty: DP-2,DP-3,eDP-2 bus-ID: 01:00.0 chip-ID: 10de:2520
Device-3: Chicony Integrated IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-13:8 chip-ID: 04f2:b71a
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
s-diag: 1407mm (55.38")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled pos: primary,bottom-r
model: LG (GoldStar) 25UM58G serial: <filter> built: 2015 res: 2560x1080
dpi: 96 gamma: 1.2 size: 677x290mm (26.65x11.42") diag: 730mm (28.8")
modes: max: 2560x1080 min: 640x480
Monitor-2: eDP-1 mapped: eDP-1-1 pos: top-left model: BOE Display 0x0974
built: 2021 res: 2560x1440 hz: 165 dpi: 189 gamma: 1.2
modes: 2560x1440
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: nvidia inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Laptop
GPU/PCIe/SSE2 memory: 5.86 GiB
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics (TGL GT1) driver: mesa intel v: 24.0.7-arch1.3
device-ID: 8086:9a60 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 550.78
device-ID: 10de:2520 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.7-arch1.3 (LLVM
Device-1: Intel Tiger Lake-H HD Audio vendor: Tongfang Hongkong
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: Tongfang Hongkong
Device-3: Fifine Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.1:12
chip-ID: 3142:5060 class-ID: 0300
API: ALSA v: k6.8.9-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
Device-2: Realtek RTL8125 2.5GbE vendor: Tongfang Hongkong driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 2e:00.0
IF: enp46s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-2: br-3736135ffeba state: down mac: <filter>
IF-ID-3: br-c4679ddb8f32 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-4: docker0 state: down mac: <filter>
IF-ID-5: veth0da94f3 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: veth1366429 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: veth210d2b3 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-8: veth372fa57 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-9: veth3d121e0 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-10: veth46e8a5f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-11: veth4a5d814 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-12: veth81a59a0 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-13: veth907ad18 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-14: vethc9b6b26 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Info: services: NetworkManager, nginx, smbd, systemd-networkd,
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:10 chip-ID: 8087:0026
Local Storage: total: 3.73 TiB used: 641.47 GiB (16.8%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: A-Data model: SX8200PNP
lanes: 4 tech: SSD serial: <filter> fw-rev: 42B9T6TB temp: 45.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 tech: SSD serial: <filter> fw-rev: 42B9T6TB temp: 41.9 C
ID-1: / raw-size: 1.86 TiB size: 1.86 TiB (100.00%) used: 641.46 GiB (33.6%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 571 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
used: 641.46 GiB (33.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
ID-4: /var/log raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-1: swap-1 type: zram size: 62.54 GiB used: 10.8 GiB (17.3%)
System Temperatures: cpu: 66.0 C mobo: N/A gpu: nvidia temp: 62 C
Memory: total: 64 GiB note: est. available: 62.54 GiB
used: 27.44 GiB (43.9%)
Processes: 808 Power: uptime: 1d 18h 11m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 24.98 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 255
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2414 libs: 569
tools: pamac,paru Compilers: clang: 17.0.6 gcc: 14.1.1 alt: 12/13
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2021-09-13
Last full system update: 2024-05-15 ↻
Relevant software: timeshift NetworkManager mkinitcpio nvidia-dkms
Failed units: anbox-container-manager.service configure-printer@usb-003-009.service systemd-guest-user.service systemd-networkd-wait-online.service
