garuda-inxi:
Kernel: 6.3.4-AMD arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd
root=UUID=b7df3a68-b4fc-46c7-92cf-cfe3d87c0806 rw rootflags=subvol=@
resume=UUID=15ef061a-5d9d-4844-91f9-0ed80b13b640 loglevel=3 ibt=off
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop System: Gigabyte product: X670 AORUS ELITE AX v: -CF
Mobo: Gigabyte model: X670 AORUS ELITE AX v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F8c
date: 04/26/2023
ID-1: hidpp_battery_0 charge: 54% condition: N/A volts: 3.8 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Wirel type: N/A
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4753 high: 5608 min/max: 3000/5733 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 5078 2: 4700
3: 4700 4: 4700 5: 4700 6: 4700 7: 4700 8: 4700 9: 4700 10: 4700 11: 4700
12: 4700 13: 4700 14: 4700 15: 4700 16: 4700 17: 4700 18: 4700 19: 4700
20: 4700 21: 4700 22: 4700 23: 5608 24: 4700 bogomips: 225259
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: ASRock
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:744c
Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4, DP-5,
DP-6, HDMI-A-2 bus-ID: 17:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 40.0 C
Device-3: Sunplus Innovation Canyon CNS-CWC5 Webcam
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 9-1.3:5 chip-ID: 1bcf:2284 class-ID: 0102
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: Samsung LC27G7xT serial: <filter> built: 2021
res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 23.2.0-devel (git-8a33a1390a) renderer: AMD
Radeon RX 7900 XTX (gfx1100 LLVM 15.0.7 DRM 3.52 6.3.4-AMD)
direct-render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 17:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 17:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Sony DualSense wireless controller (PS5)
lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 054c:0ce6 class-ID: 0300
Device-5: Cooler Master MH650 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.1:4
chip-ID: 2516:0129 class-ID: 0300 serial: <filter>
Device-6: Sunplus Innovation Canyon CNS-CWC5 Webcam
API: ALSA v: k6.3.4-AMD status: kernel-api tools: N/A
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 10:00.0
IF: enp16s0 state: up speed: 100 Mbps duplex: full mac: <filter>
driver: N/A modules: mt7921e pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 11:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-3: Sony DualSense wireless controller (PS5)
Local Storage: total: 3.17 TiB used: 1.63 TiB (51.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte model: GP-AG70S1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFM21.1 temp: 32.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Gigabyte model: GP-GSTFS31480GNTD
tech: SSD serial: <filter> fw-rev: 61.5 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2UB102
ID-1: / raw-size: 897.67 GiB size: 897.67 GiB (100.00%)
used: 23.85 GiB (2.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 29.7 MiB (9.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 897.67 GiB size: 897.67 GiB (100.00%)
ID-4: /var/log raw-size: 897.67 GiB size: 897.67 GiB (100.00%)
ID-5: /var/tmp raw-size: 897.67 GiB size: 897.67 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.51 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 33.55 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 44.0 C mobo: N/A
GPU: device: amdgpu temp: 39.0 C mem: 58.0 C fan: 653 watts: 21.00
device: amdgpu temp: 40.0 C
Processes: 495 Uptime: 31m wakeups: 2 Memory: available: 30.51 GiB
used: 4.32 GiB (14.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1600 libs: 477 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.27
System install date: 2023-05-28
Last full system update: 2023-05-29
Hello, I installed Garuda Gnome yesterday and while everything works splendidly the sole issue I am facing is making OBS Studio work. Both the normal, broswer and git variants are giving me this error:
obs: error while loading shared libraries: libmbedcrypto.so.7: cannot open shared object file: No such file or directory
Even symlinking doesn't seem to work and I consider it wrong practice anyway.
Does anyone know what this lib is and if it's on the AUR or of some other way to circumvent this error?
