Obs not working
hey there, as i wrote in my other post, obs is not really working anymore, when i try to click it wont open, wont show in program manager.
when i try to start it in cmd it shows this:
wirr@wirr in ~ as 🧙 took 7s
[🔴] × obs
debug: Found portal inhibitor
debug: Attempted path: /usr/bin/../share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: /usr/bin/../share/obs/obs-studio/locale.ini
debug: Attempted path: /usr/bin/../share/obs/obs-studio/locale/de-DE.ini
info: Using preferred locale 'de-DE'
debug: Attempted path: /usr/bin/../share/obs/obs-studio/themes
debug: Attempted path: /usr/bin/../share/obs/obs-studio/themes/
warning: [Safe Mode] Unclean shutdown detected!
warning: [Safe Mode] User elected to launch normally.
info: Platform: Wayland
info: CPU Name: AMD Ryzen 9 7900X 12-Core Processor
info: CPU Speed: 4026.907MHz
info: Physical Cores: 12, Logical Cores: 24
info: Physical Memory: 31237MB Total, 12466MB Free
info: Kernel Version: Linux 6.13.5-arch1-1-znver4
info: Distribution: "Garuda Linux" Unknown
info: Desktop Environment: KDE (KDE)
info: Session Type: wayland
info: Qt Version: 6.8.2 (runtime), 6.8.1 (compiled)
info: Portable mode: false
info: OBS 31.0.1 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 48000
speakers:        2
max buffering:   960 milliseconds
buffering type:  dynamically increasing
info: Initializing OpenGL...
info: Using EGL/Wayland
info: Initialized EGL 1.5
info: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce RTX 3080/PCIe/SSE2
info: OpenGL loaded successfully, version 3.3.0 NVIDIA 570.124.04, shading language 3.30 NVIDIA via Cg compiler
info: video settings reset:
base resolution:   1920x1080
output resolution: 1280x720
downscale filter:  Bicubic
fps:               30/1
format:            NV12
YUV mode:          Rec. 709/Partial
info: NV12 texture support enabled
info: P010 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
libDeckLinkAPI.so: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
warning: A DeckLink iterator could not be created.  The DeckLink drivers may not be installed
warning: Failed to initialize module 'decklink.so'
info: [pipewire] Available capture sources:
info: [pipewire]     - Monitor source
info: [pipewire]     - Window source
warning: v4l2loopback not installed, virtual camera not registered
fish: Job 1, 'obs' terminated by signal SIGSEGV (Address boundary error)
╭─wirr@wirr in ~ took 13s
Kernel: 6.13.5-arch1-1-znver4 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver4
root=UUID=b3328148-480b-42c9-9425-ff822289ea26 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
Mobo: ASUSTeK model: ROG STRIX B650E-E GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 3208 date: 02/10/2025
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 4
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB
desc: 12x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3006 min/max: 545/5733 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3006 2: 3006 3: 3006
4: 3006 5: 3006 6: 3006 7: 3006 8: 3006 9: 3006 10: 3006 11: 3006 12: 3006
13: 3006 14: 3006 15: 3006 16: 3006 17: 3006 18: 3006 19: 3006 20: 3006
21: 3006 22: 3006 23: 3006 24: 3006 bogomips: 225162
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 570.124.04 alternate: nouveau,nvidia_drm
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: HDMI-A-2
empty: DP-2, DP-3, DP-4, HDMI-A-3 bus-ID: 01:00.0 chip-ID: 10de:2216
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
empty: DP-1,HDMI-A-1,Writeback-1 bus-ID: 0d:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 50.0 C
Monitor-1: HDMI-A-2 model: HISENSE serial: <filter> built: 2023 res:
mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 68 gamma: 1.2
size: 1428x804mm (56.22x31.65") diag: 1639mm (64.5") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
drv: nvidia device: 1 drv: radeonsi gbm: drv: radeonsi surfaceless:
drv: nvidia wayland: drv: nvidia x11: drv: nvidia
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 570.124.04
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 9.77 GiB display-ID: :1.0
API: Vulkan v: 1.4.304 layers: 13 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: N/A device-ID: 10de:2216
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
Device-1: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:1640
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
Device-4: Logitech [G533 Wireless Headset Dongle]
lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 046d:0a66 class-ID: 0300
API: ALSA v: k6.13.5-arch1-1-znver4 status: kernel-api with: aoss
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3
lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: xone-dongle
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:9
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:7
chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 5.15 TiB used: 2.83 TiB (54.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: OWC model: Aura P12 Pro 2.0TB
size: 1.75 TiB block-size: physical: 4096 B logical: 4096 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM15.1 temp: 27.9 C
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 53.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 00RL scheme: MBR
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 020 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SD8SBBU240G1122
tech: SSD serial: <filter> fw-rev: 6000 scheme: MBR
used: 104.37 GiB (22.4%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 30.5 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 24
System Temperatures: cpu: 57.4 C mobo: 46.2 C gpu: amdgpu temp: 50.0 C
Memory: total: 32 GiB note: est. available: 30.51 GiB used: 8.08 GiB (26.5%)
Processes: 580 Power: uptime: 4h 51m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.11 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1901 libs: 574 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
System install date:     2023-04-15
Last full system update: 2025-03-03
The decklink drivers may not be installed or may be out of date. This is an AUR package, so try to install/reinstall them via paru in the terminal or via octopi.
If you have AUR packages installed, please remember to run garuda-update -a to update these packages as well.
well, to install decklink via octopi has worked, but its still giving me the same error
╭─wirr@wirr in ~ as 🧙 took 28s
[🔴] × obs
info: CPU Speed: 3942.795MHz
info: Physical Memory: 31237MB Total, 8191MB Free
speakers:        2
fps:               30/1
format:            NV12
╭─wirr@wirr in ~ as 🧙 took 3s
7 posts were merged into an existing topic: Problems updating AUR packages
If all else fails, since the arch maintainers wont fix the obs pkg. You can always just use the flatpak.
Now I’m not a fan of flatpak but when upstream just pkg it as flatpak most of the time its easier to use depending on if it needs out of the sandbox. But OBS is one of the rare ones that just works best in flatpak
lol its remind me one something…
that happened to me if i was on Garuda Raptor and updated regulary but if i remembered right its stopped with last year build . I did try the same steps earlier didnt work too.But after Backups and installed the new iso never had this issue again.i dont use obs much it is good for the psvita screen to it for playing but dont record much.Did you try the AppImage Version?
Since I am not an OBS user, I quickly tested this in a VM. Installed obs-studio-stable (chaotic-aur) and rebooted, works without issues.
Try to remove these decklink drivers, then reboot and check if OBS works without issues.
If not, then post the output from:
pacman -Qs obs
so that we can see which OBS version you have installed.
i was just about to look around,
first i found that there is the option to start obs without checking for other packages with
obs --disable-missing-files-check
but that didnt change anything, so i was just looking for that continuus-full build, but coudnt find it yet, but i can see that obs-stable version, so im going to uninstall obs and install the stable one …
meanwhile
wirr@wirr in ~ as 🧙 took 4s
[⚡] × pacman -Qs obs
local/libxmlb 0.3.21-1
Library to help create and query binary XML blobs
local/obs-studio 31.0.1-2
Free, open source software for live streaming and recording
local/print-manager 1:6.3.2-1 (plasma)
A tool for managing print jobs and printers
local/ruby 3.3.7-2
An object-oriented language for quick and easy programming
Remove these decklink drivers at the same time…
i did,
but sadly its still not working :confused:
obs
info: CPU Speed: 3006.000MHz
info: Physical Memory: 31233MB Total, 22561MB Free
info: Qt Version: 6.8.2 (runtime), 6.8.2 (compiled)
speakers:        2
fps:               30/1
format:            NV12
info: [obs-browser]: Version 2.24.4
info: [obs-browser]: CEF Version 127.0.6533.100 (runtime), 127.3.4+ge9e2e14+chromium-127.0.6533.100 (compiled)
info: VAAPI: API version 1.22
info: FFmpeg VAAPI H264 encoding supported
and the version print is still the same too
pacman -Qs obs
local/obs-studio-stable 31.0.1-1.10
Free, open source software for live streaming and recording - Browser enabled
local/ruby 3.3.7-2
Use pacman -Qi obs , -Qs list all possible packages.
DR;TL the hole thread.
@wirr did you use octopi? Why?
because i’m noob and then things like this happen :sweat_smile:
wirr@wirr in ~ took 1s
[⚡] × pacman -Qi obs
Fehler: Paket »obs« wurde nicht gefunden
I have the same error messages in the terminal, but OBS works.
Looks like the actual error occurs when loading ffmpeg, there should actually be more of ffmpeg codec´s loading:
Post the output of:
pacman -Qs ffmpeg
pacman -Qs ffmpeg
local/ffmpeg 2:7.1-6
Complete solution to record, convert and stream audio and video
local/ffmpeg4.4 4.4.5-2
local/ffmpegthumbs 24.12.2-1 (kde-applications kde-multimedia)
FFmpeg-based thumbnail creator for video files
local/gst-libav 1.24.12-3
Multimedia graph framework - libav plugin
local/qt6-multimedia-ffmpeg 6.8.2-1
FFMpeg backend for qt6-multimedia
to add, i uninstalled obs with octopi, checked with pacman -r obs (+obs-studio-stable) and then used pacman -S obs-studio-stable to install it again, but still the same error
That is all correct.
Make a backup of ~/.config/obs-studio and then delete the obs-studio folder and try again. Maybe it is just a config issue.
i uninstalled again with pacman, and deleted the config folder(should be default anyways) , after that reinstalled, but still the same error :frowning:
wirr@wirr in ~ as 🧙 took 8s
╰─λ obs
error: Failed to rename basic scene collection file:
filesystem error: cannot rename: Datei oder Verzeichnis nicht gefunden [/home/wirr/.config/obs-studio/basic/scenes.json] [/home/wirr/.config/obs-studio/basic/scenes/Unbenannt.json]
info: CPU Speed: 4960.611MHz
info: Physical Memory: 31237MB Total, 7267MB Free
speakers:        2
fps:               30/1
format:            NV12
Maybe I’m wrong, but to me this looks a bit similar to this issue:
There, they suggest installing:
If not working, it might be the case to enter a new issue there (obs-studio github)…
I also had a look at this earlier because I also suspected nVidia.
I tried to recreate it earlier on bare metal (intel/nvidia), no matter what I do (install/uninstall vdpau/vaapi/gstreamer/libva/etc), OBS works without issues. I cannot reproduce the error.
Edit:
for comparison, my log:
info: CPU Name: Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
info: CPU Speed: 3150.923MHz
info: Physical Cores: 4, Logical Cores: 4
info: Physical Memory: 7821MB Total, 1077MB Free
info: Kernel Version: Linux 6.13.5-zen1-1-zen
speakers:        2
info: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
fps:               30/1
format:            NV12
error: os_dlopen(/usr/lib/obs-plugins/frontend-tools.so->/usr/lib/obs-plugins/frontend-tools.so): libluajit-5.1.so.2: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
warning: Module '/usr/lib/obs-plugins/frontend-tools.so' not loaded
error: VAAPI: Failed to initialize display in vaapi_device_h264_supported
error: VAAPI: Failed to initialize display in vaapi_device_av1_supported
info: FFmpeg VAAPI AV1 encoding not supported
error: VAAPI: Failed to initialize display in vaapi_device_hevc_supported
info: FFmpeg VAAPI HEVC encoding supported
info: [obs-nvenc] NVENC version: 12.2 (compiled) / 13.0 (driver), CUDA driver version: 12.80, AV1 supported:false
error: os_dlopen(/usr/lib/obs-plugins/obs-webrtc.so->/usr/lib/obs-plugins/obs-webrtc.so): libdatachannel.so.0.21: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
warning: Module '/usr/lib/obs-plugins/obs-webrtc.so' not loaded
info: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.5.4 | RPC Version: 1)
info: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.8.2 | Qt version (run-time): 6.8.2
info: [obs-websocket] [obs_module_load] Linked ASIO Version: 103002
warning: DEPRECATION: obs_frontend_get_global_config is deprecated. Read from global or user configuration explicitly instead.
info: [obs-websocket] [obs_module_load] Module loaded.
info:   Loaded Modules:
info:     text-freetype2.so
info:     rtmp-services.so
info:     obs-x264.so
info:     obs-websocket.so
info:     obs-vst.so
info:     obs-transitions.so
info:     obs-qsv11.so
info:     obs-outputs.so
info:     obs-nvenc.so
info:     obs-libfdk.so
info:     obs-filters.so
info:     obs-ffmpeg.so
info:     obs-browser.so
info:     linux-v4l2.so
info:     linux-pulseaudio.so
info:     linux-pipewire.so
info:     linux-jack.so
info:     linux-capture.so
info:     linux-alsa.so
info:     image-source.so
info:     decklink-output-ui.so
info:     decklink-captions.so
info: Available Encoders:
info:   Video Encoders:
info:   - ffmpeg_svt_av1 (SVT-AV1)
info:   - ffmpeg_aom_av1 (AOM AV1)
info:   - ffmpeg_vaapi_tex (FFmpeg VAAPI H.264)
info:   - hevc_ffmpeg_vaapi_tex (FFmpeg VAAPI HEVC)
info:   - obs_nvenc_h264_tex (NVIDIA NVENC H.264)
info:   - obs_nvenc_hevc_tex (NVIDIA NVENC HEVC)
info:   - obs_qsv11_v2 (QuickSync H.264)
info:   - obs_qsv11_hevc (QuickSync HEVC)
info:   - obs_x264 (x264)
info:   Audio Encoders:
info:   - ffmpeg_aac (FFmpeg AAC)
info:   - ffmpeg_opus (FFmpeg Opus)
info:   - ffmpeg_pcm_s16le (FFmpeg PCM (16 Bit))
info:   - ffmpeg_pcm_s24le (FFmpeg PCM (24 Bit))
info:   - ffmpeg_pcm_f32le (FFmpeg PCM (32 Bit Float))
info:   - ffmpeg_alac (FFmpeg ALAC (24 Bit))
info:   - ffmpeg_flac (FFmpeg FLAC (16 Bit))
info:   - libfdk_aac (libfdk AAC)
info: ==== Startup complete ===============================================
info: All scene data cleared
info: ------------------------------------------------
info: pulse-input: Server name: 'PulseAudio (on PipeWire 1.2.7) 15.0.0'
info: pulse-input: Audio format: s32le, 48000 Hz, 2 channels
info: pulse-input: Started recording from 'alsa_output.pci-0000_00_1f.3.analog-stereo.monitor' (default)
info: [Loaded global audio device]: 'Desktop-Audio'
info: pulse-input: Started recording from 'alsa_input.pci-0000_00_1f.3.analog-stereo' (default)
info: [Loaded global audio device]: 'Mikrofon-/AUX-Audio'
info: Switched to scene 'Szene'
info: Loaded scenes:
info: - scene 'Szene':
info: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds (source: Desktop-Audio)
info: adding 21 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Desktop-Audio)
nvidia-smi:
|    0   N/A  N/A             913      G   /usr/lib/Xorg                             4MiB |
|    0   N/A  N/A            6607      G   obs                                      29MiB |
@wirr try booting with a different kernel and then try to start OBS.
If you have no other kernel installed:
sudo pacman -S linux-zen linux-zen-headers
then reboot and select the kernel in GRUB.
ohh, yes i think you are right, didn’t run dmesg so far, but it prompts some segfaults:
[20348.437167] obs[1046385]: segfault at d8 ip 000074132a2e6634 sp 00007ffe909d25a8 error 4 in libX11.so.6.4.0[27634,74132a2d6000+94000] likely on CPU 14 (core 2, socket 0)
[20348.437176] Code: 84 00 00 00 00 00 f3 0f 1e fa 8b 47 1c c3 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 8b 47 74 c30f 1f 84 00 00 00 00 00 f3 0f 1e fa <48> 8b 87 d8 00 00 00 c3 0f 1f 40 00 f3 0f 1e fa 48 63 f6 48 c1 e6
[20458.646905] obs[1052016]: segfault at d8 ip 00007983c04e6634 sp 00007ffcf9d62688 error 4 in libX11.so.6.4.0[27634,7983c04d6000+94000] likely on CPU 14 (core 2, socket 0)
[20458.646913] Code: 84 00 00 00 00 00 f3 0f 1e fa 8b 47 1c c3 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 8b 47 74 c30f 1f 84 00 00 00 00 00 f3 0f 1e fa <48> 8b 87 d8 00 00 00 c3 0f 1f 40 00 f3 0f 1e fa 48 63 f6 48 c1 e6
[29907.486932] obs[1216016]: segfault at d8 ip 00007d60d50e6634 sp 00007ffc7e119e98 error 4 in libX11.so.6.4.0[27634,7d60d50d6000+94000] likely on CPU 1 (core 1, socket 0)
[29907.486941] Code: 84 00 00 00 00 00 f3 0f 1e fa 8b 47 1c c3 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 8b 47 74 c30f 1f 84 00 00 00 00 00 f3 0f 1e fa <48> 8b 87 d8 00 00 00 c3 0
thanks, im going to try that tomorrow :blush:
that was it, there was a conflict between libva-nvidia-driver-0.0.13-1 and libva-vdpau-driver-0.7.4-7 a which i allowed to uninstall vdpau, run an update, rebooted and now obs is loading normally again…
thanks for the help :grin:
