I am not sure if anyone else has had this issue or if it will help anyone, but for some reason, after an update or series of updates I didn’t keep track of, I noticed OBS Studio stopped detecting all audio devices on my PC except for the BlackMagic capture card. I been having issues with my GPU/PC black screening to a revving fan an initially thought it was related.
After about 5-7 hours, I discovered OBS was just not playing well with Pipewire or PipePlumber. Everything else found my audio devices, even software and games installed with WINE as well as GPU Screen Recorder that I installed via flatpak had no issues aside from setting custom rmtp streams not making sense.
Anyway, if it helps anyone, the solution I found was to install
obs-pipewire-audio-capture
along with OBS studio and add the new “Audio Output Capture (Pipewire)” and “Audio Input Capture (Pipewire)” etc sources that obs-pipewire-audio-capture installs. I used yay to install both. Not sure if it was a pipewire-pulse or OBS studio update or something else, but the OBS just doesn’t seem to like pipewire.
OBS will pick up the audio from the obs-pipewire-audio-capture sources and all settings in the audio setting will carry over. However, any OSB native drop down you would normally select your audio devices from will still tell you the device is not connected.
My garuda-inxi
Kernel: 6.14.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1 clocksource: tsc
root=UUID=42ef2b61-b379-4699-8769-012b3204f15e rw rootflags=subvol=@
vt.default_blu=46,168,161,175,250,231,213,222,112,168,161,175,250,231,213,200 quiet
resume=UUID=84f0f255-b378-4591-bd1b-cc5f2aa4449c loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0 wm: kwin_wayland vt: 1
Type: Desktop System: Gigabyte product: X570 AORUS MASTER v: -CF serial: <superuser required>
Mobo: Gigabyte model: X570 AORUS MASTER serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends LLC. v: F38 date: 03/22/2024
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3 serial: <filter> charge: 100%
(should be ignored) rechargeable: yes status: discharging
Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2 gen: 2 level: v3 note: check
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x71 (113) stepping: 0
microcode: 0x8701034
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 4125 min/max: 550/4763 boost: enabled scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 4125 2: 4125 3: 4125 4: 4125 5: 4125 6: 4125 7: 4125 8: 4125
9: 4125 10: 4125 11: 4125 12: 4125 13: 4125 14: 4125 15: 4125 16: 4125 17: 4125 18: 4125
19: 4125 20: 4125 21: 4125 22: 4125 23: 4125 24: 4125 25: 4125 26: 4125 27: 4125 28: 4125
29: 4125 30: 4125 31: 4125 32: 4125 bogomips: 224013
Device-1: Intel DG2 [Arc A310] driver: i915 v: kernel alternate: xe arch: Xe-HPG code: Alchemist
process: TSMC n6 (7nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 1 ports: active: none
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 08:00.0 chip-ID: 8086:56a6
Device-2: Blackmagic Design DeckLink Quad HDMI Recorder driver: blackmagic-io v: 14.4.1a4
alternate: blackmagic_io pcie: gen: 3 speed: 8 GT/s lanes: 1 link-max: lanes: 8 bus-ID: 0d:00.0
chip-ID: bdbd:a14e class-ID: 0400
Device-3: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900 XTX/7900 GRE/7900M]
vendor: Sapphire NITRO+ driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: HDMI-A-5 empty: DP-3, DP-4, HDMI-A-4, Writeback-1 bus-ID: 13:00.0 chip-ID: 1002:744c
Device-4: Linux Foundation Webcam gadget driver: hid-generic,usbhid,uvcvideo type: USB rev: 3.1
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-3:2 chip-ID: 27c2:0536 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 compositor: kwin_wayland
driver: X: loaded: amdgpu,modesetting unloaded: radeon alternate: fbdev,intel,vesa
dri: radeonsi,iris gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-5 model: MEC-R-4-HV serial: <filter> built: 2015 res: mode: 3840x2160 hz: 120
scale: 100% (1) dpi: 85 gamma: 1.2 size: 1872x1053mm (73.7x41.46") diag: 1321mm (52") ratio: 16:9
modes: max: 3840x2160 min: 640x480
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0 drv: radeonsi
device: 1 drv: iris device: 2 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 7900 XTX (radeonsi navi31 LLVM 19.1.7 DRM 3.61
6.14.9-zen1-1-zen) device-ID: 1002:744c memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 15 device: 0 type: discrete-gpu name: AMD Radeon RX 7900 XTX
(RADV NAVI31) driver: mesa radv v: 25.1.1-arch1.2 device-ID: 1002:744c surfaces: N/A device: 1
type: discrete-gpu name: Intel Arc A310 Graphics (DG2) driver: mesa intel v: 25.1.1-arch1.2
device-ID: 8086:56a6 surfaces: N/A device: 2 type: cpu name: llvmpipe (LLVM 19.1.7 256 bits)
driver: mesa llvmpipe v: 25.1.1-arch1.2 (LLVM 19.1.7) device-ID: 10005:0000 surfaces: N/A
gpu: amd-smi, lact, radeontop wl: wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: Intel DG2 Audio driver: snd_hda_intel v: kernel pcie: speed: Unknown lanes: 63
link-max: gen: 1 speed: 2.5 GT/s bus-ID: 09:00.0 chip-ID: 8086:4f92 class-ID: 0403
Device-3: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 13:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-4: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 15:00.4
chip-ID: 1022:1487 class-ID: 0403
Device-5: Blue Microphones Yeti Stereo Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: b58e:9e84
API: ALSA v: k6.14.9-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.4 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 0a:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp10s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 0b:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp11s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-3: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: d000 bus-ID: 0c:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp12s0 state: down mac: <filter>
Device-4: Microsoft Xbox Wireless Adapter for Windows driver: N/A type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:3 chip-ID: 045e:02fe class-ID: 0000
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-5:2 chip-ID: 8087:0029 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2 lmp-v: 11 status:
Local Storage: total: 7.74 TiB used: 5.68 TiB (73.3%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital model: WD BLACK SN770 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD
serial: <filter> fw-rev: 731100WD temp: 40.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Western Digital model: WDS100T1XHE-00AFY0
serial: <filter> fw-rev: 614600WD temp: 36.9 C
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Western Digital model: WD BLACK SN850X 2000GB
serial: <filter> fw-rev: 620361WD temp: 41.9 C
ID-4: /dev/sda maj-min: 8:0 model: Gigaston Prime Series size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 8A0 scheme: MBR
ID-5: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 010
ID-6: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 QVO 2TB size: 1.82 TiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 1B6Q
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 658.85 GiB (36.7%) fs: btrfs
dev: /dev/nvme0n1p2 maj-min: 259:4
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 616 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 658.85 GiB (36.7%) fs: btrfs
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 658.85 GiB (36.7%) fs: btrfs
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 658.85 GiB (36.7%) fs: btrfs
ID-1: swap-1 type: partition size: 68.97 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:5
ID-2: swap-2 type: zram size: 62.7 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 63.9 C mobo: 40.0 C gpu: amdgpu temp: 52.0 C mem: 69.0 C
Fan Speeds (rpm): fan-1: 2964 gpu: amdgpu fan: 569
Memory: total: 64 GiB note: est. available: 62.7 GiB used: 37.62 GiB (60.0%)
Processes: 730 Power: uptime: 1h 51m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 25.06 GiB
Packages: 1721 pm: pacman pkgs: 1715 libs: 448 tools: octopi,pamac,paru pm: flatpak pkgs: 6
Compilers: clang: 19.1.7 gcc: 15.1.1 Client: Unknown Client: garuda-rani inxi: 3.3.38
System install date: 2025-05-25
Last full system update: 2025-06-01 ↻
type or paste code here
