nwg-panel 0.5.0 released
Includes the DwlTags module.
Autotiling 1.6 released
This may concern the users of sway w/ autotiling and Chaotic-AUR:
Fixed. Also posted an answer on the issue
I noticed. Thank you!
nwg-panel 0.5.5 released
nwg-displays released (request for testing)
Output management utility for sway, inspired by wdisplays and wlay.
This program is expected to:
- provide an intuitive GUI to manage multiple displays;
- save outputs configuration to a text file;
- save workspace → output assignments to a text file;
- support sway only.
Instead of configuring the outputs in the sway config file, you only need to include 2 files:
include outputs
include workspaces
The program has not been tested on HiDPI displays, as I don’t have any. Thanks in advance for feedback.
GitHub - nwg-piotr/nwg-displays: Output management utility for sway and Hyprland. (also available in AUR).
Ooo! I will definitely add this after a stable release.
nwg-look 0.1.2 released
Mostly feature requests:
- [bug] unnecessary/misplaced label removed
- added support for color scheme
- added (missing) exporting
~/.icons/default/index.theme - removed
-nargument, ‘Preferences’ tab and~/.config/nwg-look/configfile added instead - added exporting
~/.gtkrc-2.0 - added exporting
~/.config/xsettingsd/xsettingsd.conf
@nwg is this stable enough to use now? Would be a good replacement.
v0.0.1
I don't expect many updates / bug fixes. It's just 149 SLOC in python.
@SGS Just in case you had nothing better to do.
When I have no idea for a new code, I have to ask you for background training.
