Hello Garuda Community,
How do you install NVM on garuda dragonied KDE?
I tried installing it using yay as well as directly cloning the git repo of nvm and using makepkg command.
I observed no problem during installation and everything happened perfectly fine but when I try to see if my nvm is installed or not in my Konsole using the nvm --version command, I get the below response
find-the-command: "nvm" is not found locally, searching in repositories
I'm pretty sure it has been installed. Anyway, I tried removing and installing again and again but with no success.
╭─nishantk@nishant in ~ took 1ms
╰─λ garuda-inxi
Kernel: 5.19.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=54117679-68e1-4d4a-a7e4-7002d502679c rw rootflags=subvol=@
resume=UUID=536be6bf-5b0d-4fbe-8200-1f2f8ca309af loglevel=3
Desktop: KDE Plasma v: 5.26.0 tk: Qt v: 5.15.6 info: latte-dock
Type: Desktop Mobo: Gigabyte model: H81M-S v: x.x
serial: <superuser required> UEFI: American Megatrends v: F2
date: 08/19/2015
Info: model: Intel Core i7-4790 bits: 64 type: MT MCP arch: Haswell
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3651 high: 3959 min/max: 800/4000 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3592 2: 3592 3: 3959
4: 3592 5: 3687 6: 3595 7: 3600 8: 3592 bogomips: 57466
vulnerable
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm
built: 2010 ports: active: none empty: VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0412 class-ID: 0300
Device-2: NVIDIA GK208B [GeForce GT 710] vendor: Micro-Star MSI
driver: nouveau v: kernel non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Fermi 2 code: GF119/GK208
process: TSMC 28nm built: 2010-16 pcie: gen: 2 speed: 5 GT/s lanes: 4
link-max: lanes: 8 ports: active: VGA-2 empty: DVI-D-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:128b class-ID: 0300 temp: 49.0 C
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: nouveau,crocus gpu: nouveau
s-diag: 414mm (16.31")
Monitor-1: VGA-2 model: HP 19ka serial: <filter> built: 2016
res: 1366x768 hz: 60 dpi: 85 gamma: 1.2 size: 410x230mm (16.14x9.06")
diag: 470mm (18.5") ratio: 16:9 modes: max: 1366x768 min: 720x400
OpenGL: renderer: NV106 v: 4.3 Mesa 22.2.1 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-3: NVIDIA GK208 HDMI/DP Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 4
link-max: lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
Sound API: ALSA v: k5.19.7-zen2-1-zen running: yes
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 3-6:5 chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlp0s20u6 state: up mac: <filter>
Local Storage: total: 1.16 TiB used: 13.56 GiB (1.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
type: SSD serial: <filter> rev: 0009 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000VM002-1ET162
speed: 6.0 Gb/s type: HDD rpm: 5900 serial: <filter> rev: SC12
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk
model: Cruzer Blade size: 29.81 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 206.19 GiB size: 206.19 GiB (100.00%) used: 13.56 GiB
(6.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 206.19 GiB size: 206.19 GiB (100.00%) used: 13.56
GiB (6.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 206.19 GiB size: 206.19 GiB (100.00%) used: 13.56
ID-5: /var/tmp raw-size: 206.19 GiB size: 206.19 GiB (100.00%) used: 13.56
ID-1: swap-1 type: zram size: 15.53 GiB used: 210.8 MiB (1.3%)
ID-2: swap-2 type: partition size: 17.08 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 50.0 C mobo: N/A gpu: nouveau temp: 49.0 C
Processes: 295 Uptime: 3h 43m wakeups: 0 Memory: 15.53 GiB used: 6.55 GiB
(42.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1201 libs: 314
Garuda (2.6.8-1):
System install date: 2022-10-17
Last full system update: 2022-10-17 ↻
