Hello! I’ve been trying to get nvidia, wayland and HDR to play well, it’s not been successful so far though.
when trying to activate HDR on CP2027 The colors were either too washed out, or absolutely dark. on the desktop, when activating hdr, the colors do seem a little washed out too, but I think that’s because sdr compresses colors? Never used it before so I can’t tell.
This article states (from what I understand) that nvidia users need to install vk-hdr-layers-git in order to use HDR, so I tried that, however I couldn’t get past SDDM after the reboot. So I’m trying to figure out what can be the cause.
I’ve ruled out cable and monitor, before you ask, I’m using a displayPort cable, had to lower the refresh rate of the monitor in order to set HDR to on, so I assume more data is being sent, otherwise the display just resets to no-hdr.
just so we’re sure it’s not a dumb mistake on my part, I’ll paste an image of what the monitor configuration looks like from kde’s standpoint:
I’ve now reverted to the snapshot prior to installing vk-hdr, so there’s no urgency with this issue, just curiosity.
garuda-inxi:
Kernel: 6.15.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=9a5d2ff6-aac6-44da-bdad-b83a4b541903 rw rootflags=subvol=@
quiet loglevel=3 splash ibt=off
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.16.0
wm: kwin_wayland tools: avail: hypridle,hyprlock vt: 1 dm: SDDM
Mobo: ASUSTeK model: TUF GAMING X870-PLUS WIFI v: Rev 1.xx
UEFI: American Megatrends v: 0237 date: 07/22/2024
Info: model: AMD Ryzen 9 7950X bits: 64 type: MT MCP arch: Zen 4 gen: 4
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB
desc: 16x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3012 min/max: 425/5883 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3012 2: 3012 3: 3012
4: 3012 5: 3012 6: 3012 7: 3012 8: 3012 9: 3012 10: 3012 11: 3012 12: 3012
13: 3012 14: 3012 15: 3012 16: 3012 17: 3012 18: 3012 19: 3012 20: 3012
21: 3012 22: 3012 23: 3012 24: 3012 25: 3012 26: 3012 27: 3012 28: 3012
29: 3012 30: 3012 31: 3012 32: 3012 bogomips: 287443
Device-1: NVIDIA GA102 [GeForce RTX 3090] vendor: Gigabyte driver: nvidia
v: 575.64.05 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-4 empty: DP-3, DP-5, HDMI-A-2,
HDMI-A-3 bus-ID: 01:00.0 chip-ID: 10de:2204 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
active: HDMI-A-1 empty: DP-1,DP-2,Writeback-1 bus-ID: 73:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 51.0 C
gpu: amdgpu,nvidia,nvidia-nvswitch d-rect: 4480x1440 display-ID: 0
Monitor-1: DP-4 pos: right model: ViewSonic VX3218C-QHD serial: <filter>
built: 2024 res: mode: 2560x1440 hz: 120 scale: 100% (1) dpi: 93 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-2: HDMI-A-1 pos: primary,left model: Samsung C27F390
serial: <filter> built: 2015 res: mode: 1920x1080 hz: 72 scale: 100% (1)
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
drv: kms_swrast surfaceless: drv: nvidia wayland: drv: nvidia x11:
drv: nvidia inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3090/PCIe/SSE2
memory: 23.44 GiB display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 17 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3090 driver: nvidia v: 575.64.05
device-ID: 10de:2204 surfaces: N/A device: 1 type: integrated-gpu name: AMD
v: 25.1.7-arch1.1 device-ID: 1002:164e surfaces: N/A device: 2 type: cpu
name: llvmpipe (LLVM 20.1.8 256 bits) driver: mesa llvmpipe
v: 25.1.7-arch1.1 (LLVM 20.1.8) device-ID: 10005:0000 surfaces: N/A
Device-1: NVIDIA GA102 High Definition Audio vendor: Gigabyte
[Rembrandt/Strix] vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 73:00.1 chip-ID: 1002:1640
lanes: 16 bus-ID: 73:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.15.9-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
Device-2: MEDIATEK vendor: AzureWave driver: mt7925e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 14c3:7925
IF: wlp7s0 state: down mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:5
chip-ID: 13d3:3602 class-ID: e001 serial: <filter>
Local Storage: total: 4.51 TiB used: 1.42 TiB (31.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smart Modular Tech.
model: SHPP41-2000GM size: 1.82 TiB block-size: physical: 512 B
fw-rev: 51060A20 temp: 55.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Smart Modular Tech.
fw-rev: 51060A20 temp: 49.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
tech: SSD serial: <filter> fw-rev: J4.3 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37480G
tech: SSD serial: <filter> fw-rev: 66B5 scheme: GPT
used: 253.32 GiB (56.7%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 620 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 61.92 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 71.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
Memory: total: 64 GiB available: 61.92 GiB used: 7.76 GiB (12.5%)
Processes: 664 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.68 GiB services: org_kde_powerdevil,
Packages: 2895 pm: pacman pkgs: 2871 libs: 617 tools: gnome-software,
octopi, pacseek, paru, yay pm: flatpak pkgs: 24 Compilers: clang: 20.1.8
gcc: 15.1.1 alt: 14 Shell: Bash v: 5.3.3 default: fish v: 4.0.2
Garuda (2.7.4-1):
System install date: 2024-03-15
Last full system update: 2025-08-06
