Something really interesting happened. I tried switching to TTY and after I put my credentials in it came up with hundreds of warnings that nouveau is stalled at ffffffffffffffff. After that I can use the TTY with no issues though. I will try removing virt-manager in case that the issue.
Sure, I was able start KDE. I modified .xinitrc and put startplasma-x11 instead of startkde and it worked.I think something's wrong with SDDM. Give me a moment for the mhwd list.
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-390xx-dkms-bumblebee/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-390xx-dkms/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-340xx-dkms-bumblebee/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/graphic_drivers/nvidia-340xx-dkms/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
Warning: No installed PCI configs!
Warning: No installed USB configs!
Just as an update I installed the TKG dev packages from the repos and now everything works properly (system boots normally), I am installing some games right now to test. So far SW:KOTOR gets stuck in "Preparing to Launch",I'm also downloading Dragonball Z: Kakarot to test I will get back to you in like an hour.
Just as an ending note after installing TKG dev packages from Chaotic AUR and optimus-manager the system works phenomenally, all games work at high FPS. Thank you so much!
