Nvidia settings not working
  Kernel: 5.19.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=866e0b23-19e5-43ac-802b-ce0f5de6cac2
    rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
  Desktop: KDE Plasma v: 5.25.4 tk: Qt v: 5.15.5 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: MONSTER product: ABRA A7 V12.5 v: N/A serial: <superuser required> Chassis:
    type: 10 serial: <superuser required>
  Mobo: MONSTER model: ABRA A7 V12.5 serial: <superuser required> UEFI: INSYDE v: 1.07.10TFB24
    date: 12/06/2021
  ID-1: BAT0 charge: 47.3 Wh (100.0%) condition: 47.3/47.2 Wh (100.4%) volts: 16.4 min: 14.4
    model: Notebook BAT type: Li-ion serial: <filter> status: full
  Info: model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP arch: Tiger Lake gen: core 11
    built: 2020 process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x40
  Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache: L1: 480 KiB desc: d-6x48
    KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 2182 high: 4189 min/max: 800/4500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 1224 2: 800 3: 4189 4: 4181 5: 799 6: 800 7: 800 8: 4017 9: 4098
    10: 801 11: 3686 12: 800 bogomips: 64512
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling, PBRSB-eIBRS: SW
    sequence
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: CLEVO/KAPOK driver: i915 v: kernel
    arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:9a68 class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: CLEVO/KAPOK driver: N/A
    alternate: nouveau, nvidia_drm, nvidia non-free: 515.xx+ status: current (as of 2022-07)
    arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f9d class-ID: 0300
  Device-3: Chicony USB2.0 Camera type: USB driver: uvcvideo bus-ID: 1-8:2 chip-ID: 04f2:b729
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 compositor: kwin_x11 driver: X:
    loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP1 model: BOE Display 0x0a15 built: 2021 res: 1920x1080 hz: 144
    dpi: 128 gamma: 1.2 size: 380x210mm (14.96x8.27") diag: 437mm (17.2") ratio: 16:9
    modes: 1920x1080
  OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.7 direct render: Yes
  Device-1: Intel Tiger Lake-H HD Audio vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel
    alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
  Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
  Sound Server-1: ALSA v: k5.19.6-zen1-1-zen running: yes
  Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:43f0 class-ID: 0280
  IF: wl
nvidia-settings application does not open and does not return any errors
Add ibt=off kernel parameter
How can I do that?
In addition to the suggestion above, whose how-to could be easily found in the forum, anyway reported below:
  • sudo micro /etc/default/grub, add ibt=off at the end of the line starting with GRUB_CMDLINE_LINUX_DEFAULT, save and exit
  • sudo update-grub and reboot
I see in your inxi's that you changed a lot of kernels (e.g. lts, xanmod, zen) so your dkms might be in troubles. So you could try a:
sudo dkms autoinstall and, in case of errors, check the log file indicated by the results.
I did but it still doesn't work. Could it be a problem with the drivers?
Did what? ibt=off, dkms autoinstall or both?
For the dkms autoinstall it would be useful to see the terminal output and, if applicable, the error log.
I added ibt=off and did dkms autoinstall, no errors.
But still nvidia setting is not working.
2022-09-06_18-11
Shouldn't he have other options?
Your driver is not loaded. That’s the problem in my opinion. But I don’t have other suggestions…
Can you help me how to download?
Try with the HW assistant (Garuda Welcome - > Garuda Settings Manager - > Hardware Configuration) and autoinstall drivers.
Altrrnatively the same command executed by the HW assistant:
sudo mhwd -a pci nonfree 0300
PLease, read.
Skipping already installed config ‘video-nvidia-prime-render-offload’ for device: 0000:01:00.0 (0300:10de:1f
9d) Display controller nVidia Corporation TU117M [GeForce GTX 1650 Mobile / Max-Q]
Skipping already installed config ‘video-nvidia-prime-render-offload’ for device: 0000:00:02.0 (0300:8086:9a
  1. Display controller Intel Corporation TigerLake-H GT1 [UHD Graphics]
I think I did something wrong while deleting or installing the drivers.
Who knows? I don't have deep knowledge of Nvidia stuff, I don't use Nvidia. Until someone else jumps in, maybe recheck the ibt=off process, since it was not shown in the inxi in the recently trashed topic.
Lead me to
If you start KDE on Nvidia graphics instead of Intel you should get more options. Also send garuda-inxi again.
Did you try with prime-run?
Worked with lts kernel
