Hello!
I'm an old ubuntu user, migrating to Garuda.
I have installed garuda on my laptop with I7-5500U and Nvidia 920M. But when i play some video on youtube, the CPU takes 80~99% of usage, and sometimes freeze.
I installed proprietary GPU driver, but seems this is not in use. Can anyone help me fix this?
Thanks a lot!
Yes..
Kernel: 5.17.2-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=5d8c4fa2-dd16-48bd-ae9c-ed9766de18a3 rw rootflags=subvol=@
Type: Laptop System: Acer product: Aspire E5-573G v: V3.72
Mobo: Acer model: ZORO_BH v: Type2 - A01 Board Version
serial: <superuser required> UEFI-[Legacy]: Insyde v: 1.37 date: 02/16/2016
ID-1: BAT1 charge: 20.1 Wh (100.0%) condition: 20.1/37.0 Wh (54.3%)
volts: 17.1 min: 14.8 model: SANYO AL15A32 type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K540/K545
Info: model: Intel Core i7-5500U bits: 64 type: MT MCP arch: Broadwell
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2394 high: 2396 min/max: 500/3000 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2396 2: 2395 3: 2394
4: 2394 bogomips: 19154
Type: l1tf
Device-1: Intel HD Graphics 5500 vendor: Acer Incorporated ALI driver: i915
v: kernel ports: active: DP-1,HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:1616 class-ID: 0300
Device-2: NVIDIA GK208BM [GeForce 920M] vendor: Acer Incorporated ALI
driver: nvidia v: 390.147 alternate: nouveau pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 04:00.0
chip-ID: 10de:1299 class-ID: 0302
Device-3: Sunplus Innovation HD WebCam type: USB driver: uvcvideo
bus-ID: 2-7:4 chip-ID: 1bcf:2c81 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: intel gpu: i915 display-ID: :0
Screen-1: 0 s-res: 5206x1080 s-dpi: 96 s-size: 1376x285mm (54.17x11.22")
s-diag: 1405mm (55.32")
Monitor-1: DP-1 mapped: DP1 pos: right model: AOC 2270W serial: <filter>
built: 2019 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 547mm (21.5") ratio: 16:9 modes:
Monitor-2: HDMI-A-1 mapped: HDMI1 pos: center
model: LG (GoldStar) FULL HD built: 2016 res: 1920x1080 hz: 60 dpi: 102
gamma: 1.2 size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9
Monitor-3: eDP-1 mapped: eDP1 pos: primary,left
model: ChiMei InnoLux 0x15ca built: 2014 res: 1366x768 hz: 60 dpi: 102
gamma: 1.2 size: 340x190mm (13.39x7.48") diag: 394mm (15.5") ratio: 16:9
modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
v: 4.6 Mesa 22.0.1 direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
Device-3: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
bus-ID: 04:00.1 chip-ID: 10de:0e0f class-ID: 0403
Sound Server-1: ALSA v: k5.17.2-zen3-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0036 class-ID: 0280
Local Storage: total: 1.39 TiB used: 48.61 GiB (3.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Gigabyte model: GP-GSTFS31100TNTD
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: J1.3 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-1: / raw-size: 753.86 GiB size: 753.86 GiB (100.00%)
used: 48.61 GiB (6.4%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /home raw-size: 753.86 GiB size: 753.86 GiB (100.00%)
ID-3: /var/log raw-size: 753.86 GiB size: 753.86 GiB (100.00%)
ID-4: /var/tmp raw-size: 753.86 GiB size: 753.86 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.55 GiB used: 187.2 MiB (1.2%)
System Temperatures: cpu: 87.0 C mobo: N/A
Processes: 312 Uptime: 18h 2m wakeups: 42 Memory: 15.55 GiB
used: 9.43 GiB (60.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1554 lib: 386 Shell: Zsh v: 5.8.1
running-in: konsole inxi: 3.3.15
Garuda (2.6.1-1):
System install date: 2021-11-27
Last full system update: 2022-04-14 ↻
I see it's an old GPU and very old proprietary driver. I'm wondering if it even supports the hardware decoding with that driver. Did you check out Hardware video acceleration - ArchWiki ?
The wiki says 8 and new should be supported, but you might have to go through the effort of downloading/configuring the stuff to utilize it.
Yes, I have read this page, but some information is confused for me.
In my searchs, sometimes i see instructions to create X11/xorg.conf with many different parameters, in others, do not create xorg.conf. I realy need help to make the correct fix.
Yesterday, i have created de xorg.conf... and my screens are ugly and don't save anymore my preferences between restarts. (After this i have deleted xorg.conf and the visual is good again)
Thanks
DRauber:
390.147
Why did you pick 390xx instead of 470xx?
when i open Hardware Configuration on Garuda Settings Manager, it display
video-hybrid-intel-nvidia-390xx-dkms-bumblebee
video-nvidia-390xx-dkms
video-linux
I choose Auto Install Proprietary Driver and this version is installed...
Now it checked video-hybrid-intel-nvidia-390xx-dkms-bumblebee and video-linux as installed
Its wrong?
Finding the driver on nvidia's site, the version sugested is 340.1080
OMG, what is correct?
petsam
April 14, 2022, 3:26pm
9
Can you share a link of your info source? Archwiki says otherwise (as already suggested).
To run an application manually (there is no automatic way) on nvidia, use this way :
optirun [options] application [application-parameters]
TNE
April 14, 2022, 3:36pm
10
Sorry to interrupt this way, but this is a red herring. Firedragon/Firefox does not even have default hardware acceleration. Additionally, why would nvidia be used when the intel GPU is available? So all in all, the nvidia driver really has nothing to do with this.
And, if you actually read the inxi, you can see the NVIDIA driver is in fact being used.
Give this package of mine a shot, I'm not sure if it will work correctly on your system and/or firedragon, but why not try: AUR (en) - firefox-video-acceleration
optirun google-chrome-stable
[ 93.497673] [ERROR]The Bumblebee daemon has not been started yet or the socket path /var/run/bumblebee.sock
et was incorrect.
[ 93.497933] [ERROR]Could not connect to bumblebee daemon - is it running?
petsam
April 14, 2022, 4:06pm
15
Something seems not properly configured.
I've gone away of 390/bumblebee, using nouveau and can't remember troubleshooting it now.
I will let others help you on this. Sorry.
Bro
April 14, 2022, 8:57pm
16
Is there any more current BIOS available than your 2016?
system
Closed
April 28, 2022, 8:57pm
17
