Nvidia RTX2060 Super drivers do not work
Hi there!
I just finished installing Garuda for the first time. It works great untill I run the Garuda Setup Assistant and it updates and asks me if I want to install nvidia drivers.
If I don’t, the OS runs normally, albeit with a few animation bugs here and there. If I do install it, it stops detecting my monitors and the resolution doesn’t go higher than 800x600, and then I have issues uninstalling the installed drivers.
This is a fresh install, straight from an ISO downloaded from the website today.
I’m pretty new to Linux (Arch specifically) and am clueless as how to proceed. I have found other closed issues on similar matters back in 2022, but none of their solutions worked for me.
I have attempted reinstalling nvidia-dkms, nvidia-5xx-dkms (I forget the correct version, I can find it if it’s important), calling nvidia-all, etc etc.
Any help on this would be much appreciated!
root=UUID=b652edd7-a598-45e7-bbe6-99791107dfbd rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop Mobo: Gigabyte model: B550M AORUS ELITE
serial: <superuser required> UEFI: American Megatrends LLC. v: F16a
date: 11/03/2022
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2478 high: 3400 min/max: 2200/4662 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2876 2: 3400
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2911 10: 2200 11: 2200
12: 3400 13: 2200 14: 2874 15: 2200 16: 2200 bogomips: 108589
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] driver: nouveau v: kernel
non-free: 545.xx+ status: current (as of 2023-10; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 05:00.0 chip-ID: 10de:1f06
class-ID: 0300 temp: 41.0 C
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau d-rect: 3520x1080
display-ID: 0
Monitor-1: DVI-D-1 pos: primary,left res: 1600x900 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: right res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland:
drv: nouveau x11: drv: nouveau
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 23.2.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: NV166 device-ID: 10de:1f06 memory: 7.79 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: cpu name: llvmpipe (LLVM
16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 05:00.1 chip-ID: 10de:10f9 class-ID: 0403
bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api tools: N/A
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.79 TiB used: 9.86 GiB (0.5%)
model: WDS480G2G0C-00AJM0 size: 447.13 GiB block-size: physical: 512 B
fw-rev: 231800WD temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
tech: SSD serial: <filter> fw-rev: K1B3 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000VM002-1CT162
tech: HDD rpm: 5900 serial: <filter> fw-rev: SC23 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: DT 101 G2
size: 7.46 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00
scheme: MBR
ID-1: / raw-size: 125.59 GiB size: 125.59 GiB (100.00%)
used: 9.83 GiB (7.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 27.4 MiB (28.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 125.59 GiB size: 125.59 GiB (100.00%)
ID-4: /var/log raw-size: 125.59 GiB size: 125.59 GiB (100.00%)
ID-5: /var/tmp raw-size: 125.59 GiB size: 125.59 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.24 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.6 C mobo: 38.0 C gpu: nouveau temp: 41.0 C
Fan Speeds (rpm): N/A gpu: nouveau fan: 945
Processes: 401 Uptime: 17m wakeups: 0 Memory: total: 32 GiB
available: 31.24 GiB used: 3.17 GiB (10.1%) Init: systemd v: 254
pm: pacman pkgs: 1323 libs: 396 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-11-19
Last full system update: 2023-11-19
Turns out it was Wayland.
Saw a few other issues posted recently about the same problem, and switching to x11 did resolve the issue.
Thanks!
