linux-zen 5.18.3
nvidia 515.48.07
cuda 11.7
I used handbrake-nvenc (built from aur)
it only utilizes 11%(max) of GPU and 94% CPU
when I try using shutter-encoder (built from aur ) it fails to enocde video with error-log
Kernel: 5.18.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=805adb07-9a50-4814-ae9c-07a7e0484a19 rw rootflags=subvol=@
quiet loglevel=3 mitigations=off systemd.unified_cgroup_hierarchy=1
splash
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1
Type: Laptop System: Acer product: Nitro AN515-54 v: V1.33
Mobo: CFL model: Octavia_CFS v: V1.33 serial: <superuser required>
UEFI: Insyde v: 1.33 date: 11/17/2020
ID-1: BAT1 charge: 45.2 Wh (100.0%) condition: 45.2/57.5 Wh (78.6%)
volts: 16.8 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: none
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Acer Incorporated ALI driver: nvidia v: 515.48.07
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.18.3-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
bus-ID: 1-14:3 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 4 state: up address: <filter>
Local Storage: total: 1.14 TiB used: 544.02 GiB (46.5%)
model: 2200 MTFDHBA256TCK size: 238.47 GiB block-size: physical: 512 B
rev: P1MA003 temp: 54.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: ACM1
used: 122.81 GiB (51.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.46 GiB used: 5.4 MiB (0.0%)
System Temperatures: cpu: 84.0 C pch: 86.0 C mobo: N/A
Processes: 296 Uptime: 11h 34m wakeups: 12 Memory: 15.46 GiB
used: 7.88 GiB (50.9%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1181 lib: 305
Shell: fish v: 3.4.1 running-in: konsole inxi: 3.3.17
e[1;34mGaruda (2.6.3-2):e[0m
e[1;34m System install date:e[0m 2022-06-09
e[1;34m Last full system update:e[0m 2022-06-12 e[1;31m↻
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m No/Undetected
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m
Something is wrong I can feel it NVENC used to give constant 150+ fps on 1080p24fps decode
