> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-chaotic-nvidia-tkg-prime-render-offload 2021.02.01 false PCI
local/chaotic-nvidia-opencl-tkg 460.67-1
NVIDIA's OpenCL implemention for 'nvidia-utils-tkg'
local/egl-wayland 1.1.6-1
EGLStream-based Wayland external platform
local/gwe 0.15.3-1
A system utility for controlling NVIDIA GPUs
local/lib32-chaotic-nvidia-opencl-tkg 460.67-1
NVIDIA's OpenCL implemention for 'lib32-nvidia-utils-tkg'
local/lib32-libvdpau 1.4-1
Nvidia VDPAU library
local/lib32-nvidia-utils 465.24.02-1
NVIDIA drivers utilities (32-bit)
local/libvdpau 1.4-1
local/libxnvctrl 465.24.02-1
NVIDIA NV-CONTROL X extension
local/mhwd-nvidia 460.67-1
mhwd-nvidia pci id
local/mhwd-nvidia-390xx 390.141-1
mhwd-nvidia-390xx PCI ID database
local/nvidia 465.24.02-1
NVIDIA drivers for linux
local/nvidia-dkms 465.24.02-1
NVIDIA drivers - module sources
local/nvidia-prime 1.0-4
NVIDIA Prime Render Offload configuration and utilities
local/nvidia-settings 465.24.02-1
Tool for configuring the NVIDIA graphics driver
local/nvidia-utils 465.24.02-1
local/nvidia-xrun-git 0.3.83.g270b6c0-1
Script to run dedicated X server with discrete nvidia graphics (git version)
/etc/X11/xorg.conf.d/01-intel-backlight.conf
Section "Device"
Identifier "Card0"
Driver "intel"
Option "Backlight" "intel_backlight"
EndSection
/etc/X11/xorg.conf.d/20-touchpad.conf
Section "InputClass"
Identifier "libinput touchpad catchall"
MatchIsTouchpad "on"
MatchDevicePath "/dev/input/event*"
Driver "libinput"
Option "Tapping" "on"
Option "NaturalScrolling" "on"
Option "MiddleEmulation" "on"
Option "DisableWhileTyping" "on"
EndSection
/etc/X11/xorg.conf.d/90-mhwd.conf
## Generated by mhwd - Manjaro Hardware Detection
/etc/modules-load.d/mhwd-gpu.conf
nvidia
nvidia-drm
nvidia-uvm
/etc/modprobe.d/mhwd-gpu.conf
blacklist nouveau
blacklist ttm
blacklist drm_kms_helper
blacklist drm
options nvidia "NVreg_DynamicPowerManagement=0x02"
/etc/modprobe.d/nobeep.conf
# Prevent annoying beep from the pc speaker.
blacklist pcspkr
/etc/modprobe.d/noime.conf
# Intel VPRO remote access technology driver.
blacklist mei
blacklist mei_meβ
-- Journal begins at Sun 2021-02-14 16:27:38 +08, ends at Tue 2021-04-20 12:53:18 +08. --
Apr 20 12:48:13 systemd-modules-load[238]: Failed to find module 'acpi_call'
Apr 20 12:48:14 kernel:
Apr 20 12:48:15 kernel: /var/lib/snapd/snaps/hello_38.snap: Can't open blockdev
Apr 20 12:48:15 kernel: /var/lib/snapd/snaps/core_10859.snap: Can't open blockdev
Apr 20 12:48:15 kernel: /var/lib/snapd/snaps/core_10823.snap: Can't open blockdev
Apr 20 12:48:15 kernel: /var/lib/snapd/snaps/core18_1988.snap: Can't open blockdev
Apr 20 12:48:15 kernel: /var/lib/snapd/snaps/vlc_x1.snap: Can't open blockdev
Apr 20 12:48:15 kernel: /var/lib/snapd/snaps/gtk-common-themes_1514.snap: Can't open blockdev
Apr 20 12:48:15 kernel: /var/lib/snapd/snaps/snapd_11107.snap: Can't open blockdev
Apr 20 12:48:15 kernel: /var/lib/snapd/snaps/snapd_11036.snap: Can't open blockdev
Apr 20 12:48:15 kernel: /var/lib/snapd/snaps/qt513_19.snap: Can't open blockdev
Apr 20 12:48:15 systemd[1]: Failed to mount Mount unit for core, revision 10823.
Apr 20 12:48:15 systemd[1]: Failed to mount Mount unit for core, revision 10859.
Apr 20 12:48:15 systemd[1]: Failed to mount Mount unit for core18, revision 1988.
Apr 20 12:48:15 systemd[1]: Failed to mount Mount unit for gtk-common-themes, revision 1514.
Apr 20 12:48:15 systemd[1]: Failed to mount Mount unit for hello, revision 38.
Apr 20 12:48:15 systemd[1]: Failed to mount Mount unit for qt513, revision 19.
Apr 20 12:48:15 systemd[1]: Failed to mount Mount unit for snapd, revision 11036.
Apr 20 12:48:15 systemd[1]: Failed to mount Mount unit for snapd, revision 11107.
Apr 20 12:48:15 systemd[1]: Failed to mount Mount unit for vlc, revision x1.
Apr 20 12:48:16 systemd-tmpfiles[448]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
Apr 20 12:48:18 wpa_supplicant[699]: nl80211: kernel reports: Attribute failed policy validation
Apr 20 12:48:18 wpa_supplicant[699]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Apr 20 12:48:18 wpa_supplicant[699]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Apr 20 12:48:26 sddm-helper[2677]: gkr-pam: unable to locate daemon control file
Apr 20 12:48:32 systemd-coredump[3112]: Process 3091 (paleofetch) of user 1003 dumped core.
Stack trace of thread 3091:
#0 0x00007f2abd88105e __strncpy_avx2 (libc.so.6 + 0x16305e)
#1 0x000055ac2cd97537 n/a (paleofetch + 0x3537)
#2 0x000055ac2cd9619f n/a (paleofetch + 0x219f)
#3 0x00007f2abd745b25 __libc_start_main (libc.so.6 + 0x27b25)
#4 0x000055ac2cd963ce n/a (paleofetch + 0x23ce)
Apr 20 12:48:38 bluetoothd[698]: profiles/input/device.c:ioctl_is_connected() Can't get HIDP connection info
Apr 20 12:48:38 bluetoothd[698]: profiles/input/device.c:control_connect_cb() connect to 23:41:23:EC:34:9B: Too many links (31)
Apr 20 12:48:43 bluetoothd[698]: profiles/input/device.c:control_connect_cb() connect to 23:41:23:1A:34:9B: Host is down (112)
Apr 20 12:48:48 bluetoothd[698]: profiles/input/device.c:control_connect_cb() connect to 23:41:23:30:34:9B: Host is down (112)
Apr 20 12:48:53 bluetoothd[698]: profiles/input/device.c:control_connect_cb() connect to 23:41:23:4F:34:9B: Host is down (112)
Apr 20 12:48:53 bluetoothd[698]: profiles/input/device.c:control_connect_cb() connect to 23:41:23:45:34:9B: Device or resource busy (16)
Apr 20 12:48:53 bluetoothd[698]: profiles/input/device.c:control_connect_cb() connect to 23:41:23:7A:34:9B: Device or resource busy (16)
Apr 20 12:48:58 bluetoothd[698]: profiles/input/device.c:control_connect_cb() connect to 23:41:23:D9:34:9B: Host is down (112)
/var/log/Xorg.0.log
[ 7.106] Current Operating System: Linux Jinglebell 5.11.14-zen1-1-zen #1 ZEN SMP PREEMPT Wed, 14 Apr 2021 12:06:37 +0000 x86_64
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 7.106] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Apr 20 12:48:17 2021
[ 7.115] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 7.115] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 7.115] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 7.583] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 7.594] (EE) intel(0): Unrecognised backlight control interface 'acpi_video0'
[ 7.609] (II) Initializing extension MIT-SCREEN-SAVER
[ 309.233] (EE) event7 - MSFT0001:01 06CB:7F28 Touchpad: client bug: event processing lagging behind by 30ms, your system is too slow
[ 309.965] (EE) event7 - MSFT0001:01 06CB:7F28 Touchpad: client bug: event processing lagging behind by 13ms, your system is too slow
/var/log/Xorg.1.log
[ 121.248] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 121.249] Current Operating System: Linux Jinglebell 5.11.5-zen1-1-zen #1 ZEN SMP PREEMPT Tue, 09 Mar 2021 18:56:30 +0000 x86_64
[ 121.250] (==) Log file: "/var/log/Xorg.1.log", Time: Fri Mar 12 11:36:56 2021
[ 121.250] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 121.250] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 121.250] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 121.699] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 121.723] (II) Initializing extension MIT-SCREEN-SAVER
[ 121.852] (EE) Failed to open authorization file "/tmp/serverauth.wxUjqb6bNn": No such file or directory
[ 227.571] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[ 227.571] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[ 227.571] (WW) xf86CloseConsole: VT_ACTIVATE failed: Input/output error
/var/log/Xorg.2.log
[ 2107.422] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[ 2107.424] Current Operating System: Linux Jinglebell 5.11.5-zen1-1-zen #1 ZEN SMP PREEMPT Tue, 09 Mar 2021 18:56:30 +0000 x86_64
[ 2107.424] (==) Log file: "/var/log/Xorg.2.log", Time: Fri Mar 12 11:26:58 2021
[ 2107.425] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 2107.425] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 2107.425] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 2107.428] (EE) /dev/dri/card1: failed to set DRM interface version 1.4: Permission denied
[ 2107.886] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 2108.165] (II) Initializing extension MIT-SCREEN-SAVER
[ 2108.332] (EE) /dev/dri/card1: failed to set DRM interface version 1.4: Permission denied
/var/log/Xorg.3.log
[ 2134.562] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[ 2134.563] Current Operating System: Linux Jinglebell 5.11.5-zen1-1-zen #1 ZEN SMP PREEMPT Tue, 09 Mar 2021 18:56:30 +0000 x86_64
[ 2134.563] (==) Log file: "/var/log/Xorg.3.log", Time: Fri Mar 12 11:27:25 2021
[ 2134.565] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 2134.565] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 2134.565] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 2134.568] (EE) /dev/dri/card1: failed to set DRM interface version 1.4: Permission denied
[ 2135.013] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 2135.258] (II) Initializing extension MIT-SCREEN-SAVER
[ 2135.439] (EE) /dev/dri/card1: failed to set DRM interface version 1.4: Permission denied
/var/log/Xorg.8.log
[ 125.223] Current Operating System: Linux Jinglebell 5.11.14-zen1-1-zen #1 ZEN SMP PREEMPT Wed, 14 Apr 2021 12:06:37 +0000 x86_64
[ 125.223] (==) Log file: "/var/log/Xorg.8.log", Time: Sun Apr 18 07:04:56 2021
[ 125.224] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 125.224] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 125.224] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 125.225] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
[ 125.228] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 125.230] (WW) Warning, couldn't open module nouveau
[ 125.230] (EE) Failed to load module "nouveau" (module does not exist, 0)
[ 125.230] (WW) Warning, couldn't open module mouse
[ 125.230] (EE) Failed to load module "mouse" (module does not exist, 0)
[ 125.230] (WW) Warning, couldn't open module kbd
[ 125.230] (EE) Failed to load module "kbd" (module does not exist, 0)
[ 127.883] (EE) intel(0): [drm] failed to set drm interface version: Permission denied [13].
[ 127.883] (EE) intel(0): Failed to claim DRM device.
[ 127.883] (EE) Screen(s) found, but none have a usable configuration.
[ 127.883] (EE)
[ 127.883] (EE) no screens found(EE)
[ 127.883] (EE)
[ 127.883] (EE) Please also check the log file at "/var/log/Xorg.8.log" for additional information.
[ 127.883] (EE)
[ 127.883] (EE) Server terminated with error (1). Closing log file.
